Retraction for E3D Volcano and Direct Bondtech BMG
I ran something like 0.8mm retraction on a standard E3D, but now I'm using a Volcano with a 0.6mm nozzle and have no idea where to start testing retraction settings. I've read 4mm to 7mm, but that seems quite high.
Does anyone have a similar setup and want to share retraction details?
I have exactly the same setup on volcano with 0.6mm nozzle - yet using a titan aero.
I almost settled on something, but I definitely have to take another look at it.
There are two methods I usually go to:
the four cubes https://www.thingiverse.com/thing:1159886 the pointy things https://www.thingiverse.com/thing:909901
But I haven't heard of this 4 to 7mm thing.
I have a P3Steel with Bondtech BMG and standard E3Dv6 (0.4 mm) and a Hypercube Evo with Zesty Nimble and switching between standard E3Dv6 (0.25 mm) and Volcano with 0.6 mm nozzle. I run 0.8 mm retraction at 40 mm/s on all three and it seems to work fine.
I would guess the BMG and Nimble are quite similar since they are both geared direct extruders. But the Nimble is set up with much lower jerk and acceleration.
@saffi said in Retraction for E3D Volcano and Direct Bondtech BMG:
That sounds like the retraction you would need for a Bowden extruder, not direct drive.
@dc42 Thanks, I'll bump it back down to my standard 0.8mm settings and try again. Maybe I need a bit of coasting or negative restart distance to get rid of the small defects near retraction points.
From what I've been able to gather 2mm seems to be a good starting point for a direct drive volcano.
It's an old thread, but my own retraction test was based on this thread, so I want to share my findings here
I ran several retraction tests with PETG and retraction length between 0.4 and 2.4mm. Forget it, stringing here, stringing there... well, you know the song
Then changed to PLA and I was able to see differences.
But I got by far the best result , when I canceled Z-hop.
It was set to Z0.2. My Z-axis is slow with low acceleration, so it takes a while to raise the nozzle.I thought, it was worth mentioning...
@o_lampe said in Retraction for E3D Volcano and Direct Bondtech BMG:
Makes sense to me. When it lifts it pulls a little string with it. Wipe on z hop could maybe help. But best to avoid z hop if at all possible.
@Phaedrux said in Retraction for E3D Volcano and Direct Bondtech BMG:
I haven't found a way yet to use Z-hop only on first layer. At least not in RRF.
Suggestion: adding a taper off parameter for Z-hop, like in mesh compensation. -
use firmware retract
then use prucerslicer layer change g code to disable z hob via g code after the first layer -
@Veti
Nice workaround!,
I've thought about using z-hop option from slic3r, but then it wouldn't lift and retract simulanteously. Your idea is better.
