Cyclic Z-Step Issue
This post is deleted! -
@phaedrux Here is my config file
I am indeed using bang-bang mode. Would that have this effect though? That seems pretty intense of an effect for the prints, unless bang-bang mode is affecting the head's heating/movement?; Configuration file for Duet WiFi (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool on Sun Sep 23 2018 14:52:19 GMT-0400 (Eastern Daylight Time); General preferences
G21 ; Work in millimeters
M555 P1 ; Set firmware compatibility to look like RepRapFirmare;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 R139.7 L300 B139.7 H361 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them; Network
M550 PRostock Max V2 ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P1 S0 ; Drive 1 goes backwards (compensation for wiring)
M92 X80 Y80 Z80 E91.725 ; Set steps per mm (originally E663)
M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops; Z-Probe
M558 P4 H5 F120 T15000 ; Set Z probe type to switch and the dive height + speeds
G31 P100 X0 Y0 Z-0.2 ; Set Z probe trigger value, offset and trigger height
M557 R139.7 S20 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
Bang Bang mode could definitely be the culprit. Quickest way to test is to print PLA with the bed-heating disabled.
adavidm
Bang-Bang heater mode on the bed heater is a very common reason for such banding. Rapid heating, followed by rapid cooling, can cause enough flex/warping/expansion to over squish a layer. Consider that even a difference of 0.05mm is 25% of a 0.2mm layer.
As @adavidm said, the easiest way to test is to print PLA either without the heated bed, or turn it off after the first layer and see if the bands persist.
Regardless, it's a good idea to do a PID tuning of your heaters to get consistent temps.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
Gents! Bang-Bang was definitely the culprit. I ran a PID calibration and tuning today and then redid my 3D benchy and the issue was gone completely! I thank you for your input as it was a very quick fix and got me back to my original rambo quality + a little extra. Now I just need to fine tune some things with the rest of the printer and I should be at max quality! Here is the before and after adjustment; night and day difference! https://www.facebook.com/photo.php?fbid=10156400087908673&set=a.437377588672&type=3&theater
If you have any additional input to other little tuning suggestions based on the print quality, I'd love to hear them! I already know that retraction will have to be adjusted for the stringing, probably a coast for that back left corner build-up (I use a fixed location for each starting layer to minimize surface blemishes), and increase top layer thickness as I have small gaps, but some of the random blemishes have me a little curious. You can see one on the good quality boat near center-middle. That and one half of the arches/circles come out clean while the other half come out somewhat unsightly (left/right halves, not top/bottom halves). Heck, that could be all a product of where I have the fixed starting point! More testing tomorrow -
Glad that solved it for you!
Only advice I can give you for best results is to target 70-85% of max rated current for your motor current, and then to experiment with jerk and acceleration values. Then try to dial in a good pressure advance value.
Happy tuning.
Hey all! So I come back with a question. I'm seeing the same issue, however it's not nearly as frequent. Picture shows the frequency. The bed is rock steady at 60C with PID control. Same process used for whole print too (sliced in Simplify3D). Any input is appreciated! Seems like a temperature thing but unsure.
Photo: https://ibb.co/gRj3yp -
@mobiusone if you look at the gcode preview can you see if those bands match up with sections where the layer start seam also match up?
Also check that heater power compensation for VIN voltage variation is enabled. To do this, send M307 H1 and see whether the calibration voltage is approximately the same as your VIN voltage (in which case it is enabled), or zero (disabled).
Thanks for the input! I'll take a gander when I get home. Going to be reprinting this item again due to other issues that arose so I'll have time to check all these items as well.
