Periodicity of ringing
Yes, short acceleration/deceleration periods are most effective at exciting ringing.
If you can, please measure the ringing frequency or frequencies. It's the speed at which you printed the perimeters (in mm/sec) divided by the observed wavelength of the ringing (in mm).
I've found this to be a really good model to test for ringing as it rotates the walls from 0 to 45 degrees as it raises.
https://www.thingiverse.com/thing:2798485
@mrehorstdmd In case you missed it above, I also went and created an Excel table that will help calculate the new accel value. Ringing Calculator.xlsx
@phaedrux said in Periodicity of ringing:
Thanks, I'm printing that now. As the layer time is so short, when printing it in PLA I have found it necessary to scale it up to 2x size and add some infill. I selected 3 perimeters to avoid the infill showing on the outside and leaving a pattern that could be confused with ringing.
When I've done some more tests, I'll make the 2.02alpha build with dynamic ringing cancellation available.
I've used that test piece to measure the predominant ringing frequencies of my printers:
Cartesian (Ormerod): 24Hz
Delta (Kossel): 44Hz
SCARA: 12.5HzNext step is to reprint them with DRC enabled.
I ran a 100 mm cube print on my coreXY machine with speed at 50, 100, 150 and 200 mm/sec, and acceleration at 1000, 2000, 3000, 4000, and 5000 mm/sec^2.
It was hard to find lighting that made it easy to see all the weirdness because the print warped quite a bit (ABS, single wall, straight sides- not much to be done about it), but at 150mm/sec, A=3000 mm/sec^2 and at 200 mm/sec, A=4000, the ringing all but disappears. There are some other weird ripples in the 200 mm/sec layers that I suspect are related to extruder settings, not XY motion settings. Jerk was 100 in X and Y.
All the ringing is on the start of motion in the Y direction after finishing a move in the X direction. There is some very minor ringing on the X parallel sides, but appears to be completely gone at 50 mm/sec, A=1000 and 2000 mm/sec^2, and several other settings. Where it is visible, the amplitude is so low I probably wouldn't complain about it.
There are some random bumps scattered all over the surface- not sure what's causing those.
I may try the same test with the cube rotated 45 degrees on the plate to see what happens when only one motor is driving the motion on each side.
Have you measured the ringing frequency? See my earlier response.
I printed out that twisting test piece on the Kossel XL and downstream of the corners I get expected ringing with a wavelength of around 1mm. But I also notice on each side a similar pattern but with a wavelength of around 5mm. It looks like it has the same amplitude on all four sides and amplitude doesn't appear to alter with the twist. The part was printed with 3 walls and no infill.
@burtoogle said in Periodicity of ringing:
Can you post a photo? Are you sure that the 5mm pattern isn't infill showing through, if you used infill?
@burtoogle Could the additional 5mm pattern coincide with an oscillation from a travel move?
@dc42 I cut the print up and put it under a microscope to measure - I counted as many waves as I could in each speed acceleration combo then divided the total distance by the wave count to get the wavelength:
the "x" entries are where the amplitude was so small or the duration so short I couldn't measure it - i.e. not really a print quality issue.
The X axis values were generally high frequency, and very short lived, very small amplitude and I couldn't get any useful/reliable numbers from them.
It's interesting that the period values mostly tend to cluster around 0.02 sec. Something is resonating at about 50 Hz...
A pair of lead acid car batteries would be good for 45Ah which would do 1.2kW for an hour. I expect most printers draw less than this,especially when prewarmed. 27.6V maybe an issue though.
If you were planning to do this regularly then deep cycle batteries would be needed. I'm just thinking about a perfect ripple free 24VDC source for a test as I suspect if you look at any switch mode power supply (especially cheaper ones) on the oscilliscope you'll see a 50Hz wobble if you look close enough, but it may not be an issue.
Just checked. Duet 2 limited to 25VDC input. May find the car batteries dip under this on load, but as our heaters can be PID the the load cand drop to low levels which may let the voltage go over. You'd need a DC-DV regulator I think.
Photo just about shows both 1mm and 5mm pitch patterns - printed with 3 walls and no infill.
@mrehorstdmd said in Periodicity of ringing:
Try adding a column to your table for acceleration time, calculated as (speed - jerk)/acceleration. You should find that the 'x' columns in your table correspond to the acceleration time being close to a multiple of the ripple period.
for testing, someone who uses 12 V and have this 50 Hz pattern could test this easier with a 12 V car battery. Maybe someone has this constellation.
If it has influence, you don't need to base it solely to a DC source. You can e. g. use some flywheel solution between AC source and your DC target, without storing the energy, just to transform and straighten.
@joergs5 said in Periodicity of ringing:
Doh! Ha ha, yes of course! Was thinking too much on how I could access if a ripple on the DC is a problem before doubling the PSU budget!
@dc42 ummm, not so much... multiple, yes, but not necessarily whole number multiple.
Maybe my measurements of the ripple aren't so great. I made a couple new test prints that are easier to read:
The one on the left tests individual motors in the corexy mechanism. The ringing looks identical on all sides of that print, as one would expect since the moving mass is the same and the motors and currents are the same. A couple settings generate some ripple effects at the end of motion.
The other print will be easier to measure than my original because it is warped. I used 3 perimeters and the ringing in each perimeter layer reinforces the ringing in the next perimeter, so even the ringing wavelengths I couldn't read before look like they are now readable.
These prints are 50 mm on a side, so at acceleration =1000 they only hit 200 mm/sec for a few mm at the center of the side.
I will measure and create a new spreadsheet...
My theory is that it is the delta's frame wobbling and so I taped a 2-axis accelerometer to the top of the delta frame and captured some spectra while twatting the top of the frame and, lo and behold, there is a nice resonance peak at around 7.5 Hz which equates to 5.33 mm wavelength, pretty much spot on.
So my next move is to put a load of mass on the top of the delta frame to push the resonant frequency down and see what effect that has. Stay tuned (haha)
Adding 3Kg (bag of Oats!) to the top of the delta frame reduced the resonant frequency to 4.66 Hz. Now to print something and check whether the wavelength has increased as expected and see if the amplitude has changed at all.
I printed exactly the same twisted test piece gcode - this time with the 3Kg mass on top of the delta frame and as far as I can tell it has completely eradicated the low frequency ringing. I can't see it no matter how I hold the part under the light and I can't feel it when I run my finger over the part. The 5mm wavelength ringing on the earlier part is easy to feel by comparison. Obviously, this is only a test with one part but I think it warrants further investigation.
