Panel Due firmware 1.20 released
Thanks for pointing this out. What's happened is that the additional button for configuring the dimming behaviour has pushed the Save & Restart button down a row, so it is now under the Light/Dark selector. I'll fix this in the next release.
I have a CPLD and dimming settings do not do anything, screen never dims.
I was looking in the wiki for the update instructions and they don't appear to be there.
Is this the only place they exist?
hi,
after updating Panel Due to version 1.20(15b1)…. dont conect with Duet... at power on Panel Due show the message conecting in upper right of screen...
I have checked wiring continuity, and is correct.
The screen power on, but dont show info of Duet... Before the update works well...I can downgrade? where i can find an older version.... and what version is confirmed to work?
i have: Panel Due 3 + 5" Screen.
I have instaled this firmware: https://github.com/dc42/PanelDueFirmware/releases/download/1.20/PanelDue-v3-5.0.bin
Yes.
hi,
I can't see any reason why it won't connect. Did you remember to reconnect the cable between PanelDue and your Duet after upgrading the firmware? Perhaps there is a bad crimp connection in the cable, and disconnecting/reconnecting the cable disturbed it.
I've noticed a few times that the 4 macro slots on the main screen will sometimes display the wrong macros if you have gone to the macro screen and entered a subfolder. When you go back to the main screen without going back up a level to the main macro folder it will try and show the first 4 macros from the subfolder rather than the main folder. This leads to the macro names being cut off and displaying incorrectly, and if you try and launch a macro you get an error saying the macro doesn't exist, because it isn't in the subfolder.
I hope that makes sense.
Thanks for reporting that, I'll fix it in the next release.
DC42 – ping, is dimming supposed to work in the C version? because for me it does nothing.
I don't think the C version supports dimming via the LED_A pin the way the other displays do. It might support dimming via the controller chip, but I would need the details to be able to program it.
This post is deleted!
