My duetwifi seems to have died :(
Well at least it was successful?
m115
SENDING:M115
FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-23M587 S"24G" P"mypassword" never returns. Nothing on wifi router.
Trying to set up the wifi and no workie
There are pretty specific steps for upgrading to 1.20 from an older firmware. It's a bit of a change from previous updates. Did you follow those steps?
Ok when I send the above it switches my password to uppercase by the look of it. M552 S1 says wrong password
as far as I know.
Ok so this is a 3rd set of instructions!
OK so its all upper case so I need to find something else to send commands with
M98 P/macros/SetNetwork
Warning: Macro file /macros/SetNetwork not found.<lf>ok<lf>Warning: Macro file /macros/SetNetwork not found.<lf>ok <lf>hmmm something wrong here…</lf></lf></lf></lf> -
M552 S1
ok<lf>WiFi module started <lf>M587
Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle <lf>?It can see 24G so wifi hardware must be OK?
I know the password is correct.</lf></lf></lf></lf></lf></lf></lf></lf>
M587 S"G24" P"xxxxxxx"
M587: Failed to add SSID to remembered list<lf>ok <lf>?</lf></lf> -
OK I am failing to get an IP address.
(COM7) Remembered networks:<lf>24G IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>24G_IOT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>G24 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle</lf></lf></lf></lf></lf></lf>
OK I tried a new network,
(COM7) M587 S"G24_IoT" P"stevenjones"
(COM7) ok <lf>(COM7) M552 S1
(COM7) ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle <lf>I cant see it being a wrong password!</lf></lf></lf></lf> -
1. How are you sending the M587 command? If you are using Pronterface or a similar USB host program, it is probably converting the characters in the password to uppercase.
2. Check that your router encryption is set to WPA2-PSK.
(COM7) M122
(COM7) === Diagnostics ===<lf>Used output buffers: 1 of 32 (1 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0<lf>Board ID: 08DAM-999TL-MQ4S4-6JTDG-3S86M-T5GRZ<lf>Static ram used: 15448<lf>Dynamic ram used: 98720<lf>Recycled dynamic ram: 520<lf>Stack ram used: 3576 current, 4896 maximum<lf>Never used ram: 11488<lf>Last reset 00:23:17 ago, cause: power up<lf>Last software reset details not available<lf>Error status: 0<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 29.4, current 37.7, max 38.0<lf>Supply voltage: min 0.1, current 1.1, max 1.2, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok, SG min/max not available<lf>Driver 1: ok, SG min/max not available<lf>Driver 2: ok, SG min/max not available<lf>Driver 3: ok, SG min/max not available<lf>Driver 4: ok, SG min/max not available<lf>Date/time: 1970-01-01 00:00:00<lf>Cache data hit count 1617411415<lf>Slowest main loop (seconds): 0.099954; fastest: 0.000035<lf>==<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf> -
Ok lets flash back to 1.19.2.
(COM8) M997 S0
(COM8) RepRapFirmware for Duet WiFi Version 1.19.2 dated 2017-09-01<lf><lf>Executing config.g…Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 651C.<lf><lf>Done!<lf>RepRapFirmware for Duet WiFi is up and running.<lf>WiFi module started<lf>WiFi reported error: Wrong password while tryiand,
(COM8) Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload s <warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.="">(COM8) M115
(COM8) Trying to connect at 460800 baud: success<lf>Erasing 245264 bytes...<lf>Uploading file...<lf>5% complete<lf>10% complete<lf>15% complete<lf>20% complete<lf>25% complete<lf>30% complete<lf>35% complete<lf>40% complete<lf>45% complete<lf>50% complete<lf>55% complete<lf>60% complete<lf>65% complete<lf>70% complete<lf>75% complete<lf>80% complete<lf>85% complete<lf>90% complete<lf>95% complete<lf>Upload successful<lf>ok<lf>FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01<lf>ok <lf>(COM8) M115
(COM8) FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19.2 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-09-01<lf>ok</lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf> -
(COM8) M122
(COM8) === Diagnostics ===<lf>Used output buffers: 1 of 32 (2 max)<lf>=== Platform ===<lf>RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0<lf>Board ID: 08DAM-999TL-MQ4S4-6JTDG-3S86M-T5GRZ<lf>Static ram used: 21176<lf>Dynamic ram used: 95768<lf>Recycled dynamic ram: 1840<lf>Stack ram used: 4048 current, 5116 maximum<lf>Never used ram: 7172<lf>Last reset 00:04:20 ago, cause: software<lf>Last software reset reason: not available<lf>Error status: 1<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 35.4, current 37.2, max 38.1<lf>Supply voltage: min 1.0, current 1.1, max 1.2, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok<lf>Driver 1: ok<lf>Driver 2: ok<lf>Driver 3: ok<lf>Driver 4: ok<lf>Date/time: 1970-01-01 00:00:00<lf>Slowest main loop (seconds): 1.965744; fastest: 0.000031<lf>=== Move ===<lf>MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0<lf>Scheduled moves: 0, completed moves: 0<lf>Bed compensation in use:<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf> -
(COM7) M552 S1
(COM7) ok <lf>(COM7) M587
(COM7) Remembered networks:<lf>24G<lf>24G_IOT<lf>G24<lf>G24_IoT<lf>ok<lf>WiFi reported error: Wrong password while trying to connect to 24G<lf>Wifi module is idle</lf></lf></lf></lf></lf></lf></lf></lf> -
OK finally worked, well I have an IP…
