Unipolar/bipolar steppers.
Forgot to add that the 42BYGHW811B bipolar motor has a rate volatage of 3.1volts.
Yes you should be able to use all of those motors.
Well i finally got to trying out the unipolar motors. I cant seem to make them work. Do i have to change something in the software side of things to make it work? So far the steppers just shake in one place.
Thank you for help -
@Deluxe:
Thank you for helpThat usually means the phases are not connected in the correct pairs. How have you connected them to the Duet?
Well i did it the same way as with the other bipolar steppers. But whatever combination i use doesnt seem to work.
And they worked fine. But the unipolar doesnt strangely. I have no experience with unipolars, i bought it by mistake but cant return it.
@Deluxe:
Well i did it the same way as with the other bipolar steppers. But whatever combination i use doesn't seem to work.
You haven't answered the question in a way that gives me enough information to make a suggestions. What I need is:
1. A link to the motor datasheet;
2. A photo of how you have connected them, or at least a description of the order in which you have connected the wires to the Duet's connector (assuming that the wires come straight from the motor, not from a connector on the motor).
Hello.
1.This is the link to the motors datasheet : https://www.ebay.com/itm/wantai-1pc-Nema17-Stepper-Motor-70OZ-IN-2-5A-42BYGHW811B-Dual-shaft-worldwide-/2220670546252.I dont know how to add a photo but i did the wiring the same way as here: http://reprap.org/mediawiki/images/thumb/d/d7/Duet_0.8.5_Duex4_wiring_0.2.svg/640px-Duet_0.8.5_Duex4_wiring_0.2.svg.png
Motor just shakes in place but doesnt move.
The eBay link you gave is to a bipolar stepper motor, but you said that the problem you are having is with a unipolar motor.
Yeah i was mistaken. I did think it was unipolar, does that make it unusable?
Bipolar stepper motors are the correct sort to use. Suggestions:
- Check that you have the wires in the correct order, i.e. black and green at one end of the connector, and red and blue at the other end;
- Check that the crimp connections on the connectors are good, using a multimeter if you have one;
- If the above checks pass, try a different motor output in case you have a blown driver.
