Software 3.5.1 released
@PDBeal I am still using the 12864 displays because I avoid SBC as an unnecessary complication
@PDBeal yes we will release PanelDue 3.5 soon, based on the existing RC. We also have a new, more capable screen under development and that will eventually replace PanelDue in our product range.
@dc42 said in Software 3.5.1 released:
@PDBeal
yes we will release PanelDue 3.5 soon, based on the existing RC. We also have a new, more capable screen under development and that will eventually replace PanelDue in our product range.Finally! Looking forrward to hearing & seeing more about that!
@dc42 Onto 3.6!! Whatโs next on the feature roadmap? Any hints?
@Alex-cr : I have tried this release. I face a lot of bad command errors suddenly while printing. When I check Gcode line, it is fine. If i revert to 3.4.6, I don't face much bad command errors while printing. Did you face anything like that?
@JayT said in Software 3.5.1 released:
Can you give some more detail about what exactly you're seeing and where you see it?
Wooo, Lets goo!
A lot of nice changes across the board. I especially like the DWC change for the text editor. Applying input shaping to smaller segments has also produced a noticeable increase in print quality, very nice indeed.I have however noticed a weird behaviour with the resume.g, which I have made a seperate thread for(https://forum.duet3d.com/topic/35544/resume-g-activating-twice-with-fw3-5?_=1713890021060)
If i simulate the gcode, I get some errors like bad command or message box stating expected integer after Y.
Sometimes error says "C1 " instead of G1. When I look back at the line number in Gcode, Line looks ok.
Is it a problem with Slicer & after error Reprap fixes it ?
Because when I run it the second time, or simulate second time, bad command error either does not come at all, or it comes at a different line.My problems are similar as posted in the thread :
https://forum.duet3d.com/topic/35553/bad-command-error-using-rrf-3-5-0-and-3-5-1-using-duet2-wifi/2
@JayT What board are you using?
I have duet2-wifi.
Can you start a thread for your issue and include as much detail as possible?
Hello
got this message"Error in start-up file macro line 5: in file macro line 5 column 17: M307: expected number after 'K'" " on startup after updating to 3.5.1.
I first thought it was a problem in config-override or config file but in my config ther is no M307 with K and this is my Config-override:
; config-override.g file generated in response to M500 at 2024-04-20 19:05
M307 H0 R0.123 K0.236:0.000 D11.52 E1.35 S1.00 B0
M307 H1 R2.660 K0.303:0.000 D5.15 E1.35 S0.75 B0 V23.9
; Probed axis limits
M208 S0 Z359.81
; Z probe parameters
G31 K0 P25 X42.0 Y21.0 Z2.40The Printer is working good but message on startup is boring.
Can someone tell me where i have to search for the M307 command? -
@alwaysom said in Software 3.5.1 released:
Can you identify exactly where line5 column17 is in this instance?
@Phaedrux : done.
I'm going to lock this thread now. If you're experiencing issues after upgrading to 3.5.1, please create a new thread with your issue and please include as much detail as possible.
undefined Phaedrux locked this topic
