Software bundle 3.5.0rc.4 now available
Thanks, was able to make progress by making that suggested runonce.cfg a macro instead and running from PanelDue. It was not executed automatically, presumably as it only gets "run once" a network is connected (ie the thing thats broken) per the docs. But Im back in operation again! I took the opportunity to move to a newer faster SDCard and now I have a nice little macro to reset Wifi should I need it in future.PS: I must have had the old Wifi Firmware version and just not have noticed, which caused this to begin with!
@Kodachrome I'm glad you are up and running again. When version 1.x WIFI firmware is upgraded to version 2.1 it is supposed to copy the access point details over because they are stored in a different way, but it appears that this doesn't always work.
@Kodachrome Have you ever had a version of the 2.1 WiFi firmware installed on your printer before? That might explain why the credentials did not get transferred over.
@dc42 said in Software bundle 3.5.0rc.4 now available:
Duet in standalone mode I have included a release zip for this version. This means that you can simply upload file Duet2and3Firmware-3.5.0-rc.4.zip
Just reporting I have done a fair bit of testing with the latest version on a cartesian printer with Duet2 wifi in standalone mode. I uploaded Duet2and3Firmware-3.5.0-rc.4.zip which installed without issues.
Printing well using both Input Shaping and Pressure Advance. No Wifi issues.
Thank you!
@tas thanks for your feedback!
@dc42 Interestingly, I got the virus detection warning in Windows today when I downloaded DuetWebControl-SD.zip from the RepRapFirmware repo but not the archive downloaded from the DuetWebControl repo.
@Nate-Nygren thanks for the report. I assume this is windows 11?
@T3P3Tony Correct
@Nate-Nygren please try again now, they have been re-uploaded with a different date stamp
More generally if anyone has the right sort of special Microsoft account required to report these as false positives that would be a help.
@T3P3Tony
The new one didn't get flagged.
We would like as many users as possible to test this release, so in order to simplify installation for users of Duet in standalone mode I have included a release zip for this version.
Initial prints on my (standalone mode) Railcore with IS and PA enabled have been all good.
@paralepsis thanks for the feedback.
It's been working flawlessly without issues (other than my self imposed ones) on my Duet 3 Mini & 1LC in standalone mode
@Exerqtor thanks for the feedback!
3.5rc4
I'm getting H1 Heater faults which I had no issues with my hypercube. I have to clear out the faults and then H1 heats up and I have no problems during print. The faults only happen when I try try to prewarm the bed and extruder. I ran M303 on both the bed and the extruder. No problem on the extruder but I do get a yellow warning on the bed. I even tried tuning at a lower temp and same thing on the bed. When I updated my firmware the wifi quit working and I had to use the terminal software with cable to get it working again. when I watch the graph during print the temps are staying in a straight line. -
@BlitzReg What version of RRF (and the WiFi firmware) did you have installed before this upgrade?
Today i try to Update my Board.
But:
Now i only can connect with ssh.
No connect per LAN or WLAN possible.How can i restart the update prozess?
On DWC i see this:
@CrazyCreator see here
@chrishamm omg ... really? the hard way?
