New firmware 1.20 Release Candidate 2 - please try it!
I just ran simulation mode on a 2MB file that will use 473,819.3mm of filament. It was sliced with a 0,9mm nozzle, 0.7mm layer height at 20mm/sec print speed. The simulation reckons it'll be printed in 1 minute and 1 second. (I wish).Firmware Name: RepRapFirmware for Duet Ethernet
Firmware Electronics: Duet Ethernet 1.0 + DueX5
Firmware Version: 1.20RC2 (2017-12-13)
Web Interface Version: 1.20-RC3Edit. Ignore all that - it was me being stupid (no change there then)
Hi Dc42
I have try most of the channel on the WiFi router, but still the same, Some time after 1 hour, but then to go into a loop on / off. We dont have Any problems with other WiFi equipment on the 2.4GKent
When I try to connect to DWC I get this error:
Could not establish a connection to the Duet firmware! Please check your settings and try again.I'm able to ping the DuetWiFi, wifi signal is -59, it's on a static Ip and I confirmed that the mac address is correct . Am I missing something obvious?
1. Did you install DuetWiFiServer.bin twice as suggested in the upgrade notes?
2. If you send M552 S1 from USB or PanelDue then it will report success/failure of the attempt to connect to your router.
M552 S1 from USB and PanelDue says connection the router. As far as I can tell everything sees each other and I can get on to DWC but it will not connect.
DuetWiFiServer ver. 1.20B10 Installed twice(+)
Web Interface ver. 1.20-RC3
Duet FirmWare ver. 1.20RC3
DuetWifi HardWare ver. 1.0 -
my Z height is now messed up. Yes I ran the macro to do a mesh level. even AFTER that, any print starts at a negative Z.
I try to raise the Z, but it gets delayed and then over compensated by me because of the delay. -
This morning was the first time I've used M916. I had a heater fault due to a bad thermistor connection. After investigating, and clearing the faults, M916 worked as expected. I had to pause the print to fix something else and it did not run my pause.g (which would move the print head away, nor resume.g, which would rehome all axes etc. The machine stopped moving but only in the last position. Ultimately, I canceled the print and cancel.g was not run either. It seems that it is ignoring certain system files after M916.
Does anybody else use FW1.20 with Duet 0.85 and DueX4?
With my hardware configuration FW1.20 doesn't even start up (it seem Duet is struggling to get an IP).
FW 1.19 runs with occasional resets (can happen even midprint).FW 1.18.1 runs with no problems at all.
DC42 was mentioning too low memory with my config, but I have no idea what exactly is causing this issues.
Anyone using interpolation for the drivers notice a difference? I swear my machine is much louder now but I did move it so it's hard to tell for sure.
@AS-3D:
@AS-3D:
I got a Problem to open a Directory on G-Code Files:
[[language]] A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message: Version: 1.20-RC3 Message: Uncaught TypeError: Cannot read property 'match' of undefined URL: http://d-bot.local/js/dwc.js Line: 2015:27 Error object: {}
Only this Directory makes Problemes everything else works.
Is there anything unusual about that directory, for example its name?
Got it, i used letters like äüß and he converted that to strange Symbols.
After renaming everything works again.What browser were you using when this happened? I cannot reproduce it with Firefox and Chromium.
Edit: Just found a possible cause for this, I'll fix that in the final v1.20.
4. Various DWC issues, which I believed are resolved in DWC 1.20-RC3.Some have been resolved but the extruder position issue that I reported above is still outstanding.
Ian, we're not sure whether this is a DWC issue or a RRF issue. So please can you set up a situation in which this issue is visible. Then send M408 S2 and M408 S3 and report the responses. Also report what DWC is displaying and what you think it should display instead.
Just wanted to download 1.20RC3 but got confused, because all the directories are named 1.19RC3….
Which directories?
Which directories?
It can be a bit confusing:
https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-Ethernet/EdgeFilename is DuetEthernetFirmware-1.20RC3.bin Version says: 1.19RC3
David/Chris et al,
So powering up the Duet, the Machine Status Panel (on Machine Control Page, top right of DWC) shows me the 5 extruder drives labelled DO, D1, D2,D3 and D4 which is correct. Under each drive is shown the "position" which to start with is 0.0 for all 5 of them. I set the active temperature for all tools to 180deg C (they all share the same heater) to allow normal extrude. Once up to temperature under "Extruder Control" I then select Extruder Drive 0, Feed Amount 20, Feed Rate 5 and hit the button "Extrude". Visibly I observes that drive 0 rotates. After the 20mm of filament has been extruded, the position of the extruder drives is now Drive 0 = 0.0, Drive 1=0.0, Drive 2 = 20.0, Drive 3= 0.0, Drive 4 = 0.0. Expected behaviour would be for Drive 0 to show 20.0 (this is the one that that has just extruded 20mm of filament), and the other 4 drives to show 0.0. Especially Drive 2 because like the other 4 drives, it hasn't been commanded to move nor has it physically moved yet after extruding 20mm of filament from Drive 0, Drive 2 show the "position" has changed form 0.0 to 20.0.
Responses as follows:
15:30:59
M408 S2
{"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0,0.0,20.0,0.0,0.0],"xyz":[0.000,0.000,0.000]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,100.00,100.00,100.00,100.00,49.80,49.80,0.00],"speedFactor":100.00,"extrFactors":[100.00,100.00,100.00,100.00,100.00],"babystep":0.000},"sensors":{"probeValue":525,"fanRPM":0},"temps":{"bed":{"current":21.9,"active":0.0,"state":0,"heater":0},"current":[21.9,180.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,2,0,0,0,0,0,0],"heads":{"current":[180.0],"active":[180.0],"standby":[0.0],"state":[2]},"tools":{"active":[[180.0],[180.0],[180.0],[180.0],[180.0],[180.0]],"standby":[[0.0],[0.0],[0.0],[0.0],[0.0],[0.0]]},"extra":[{"name":"MCU","temp":31.4},{"name":"Duet\Duex","temp":30.8},{"name":"Z Stepper","temp":19.7},{"name":"LeftLowerXYStepper","temp":21.3},{"name":"RightLowerXYStepper","temp":21.1},{"name":"LeftUpperXYStepper","temp":21.4},{"name":"RightUpperXYStepper","temp":20.9}]},"time":1324.0}15:32:59
M408 S3
{"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0,0.0,20.0,0.0,0.0],"xyz":[0.000,0.000,0.000]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,100.00,100.00,100.00,100.00,49.80,49.80,0.00],"speedFactor":100.00,"extrFactors":[100.00,100.00,100.00,100.00,100.00],"babystep":0.000},"sensors":{"probeValue":525,"fanRPM":0},"temps":{"bed":{"current":22.2,"active":0.0,"state":0,"heater":0},"current":[22.2,180.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,2,0,0,0,0,0,0],"heads":{"current":[180.0],"active":[180.0],"standby":[0.0],"state":[2]},"tools":{"active":[[180.0],[180.0],[180.0],[180.0],[180.0],[180.0]],"standby":[[0.0],[0.0],[0.0],[0.0],[0.0],[0.0]]},"extra":[{"name":"MCU","temp":31.4},{"name":"Duet\Duex","temp":30.9},{"name":"Z Stepper","temp":19.7},{"name":"LeftLowerXYStepper","temp":21.2},{"name":"RightLowerXYStepper","temp":21.0},{"name":"LeftUpperXYStepper","temp":21.4},{"name":"RightUpperXYStepper","temp":20.8}]},"time":1444.0,"coldExtrudeTemp":160,"coldRetractTemp":90,"tempLimit":290,"endstops":3968,"firmwareName":"RepRapFirmware for Duet Ethernet","geometry":"coreXYUV","axes":3,"axisNames":"XYZUV","volumes":2,"mountedVolumes":1,"name":"TallCoreXY","probe":{"threshold":700,"height":-0.50,"type":1},"tools":[{"number":0,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":1,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":2,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":3,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":4,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":5,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]}],"mcutemp":{"min":15.9,"cur":31.4,"max":31.8},"vin":{"min":24.4,"cur":24.6,"max":24.7}}Edit. Similar behaviour happens when I use the other extruders and during printing. That is to say, Drive 3 shows the value for drive 1, drive 4 shows the value for drive 2. So Drives 0 and 1 always show 0.0.
Which directories?
Looks like I got the file commit comment wrong! Version 1.20RC4 coming soon anyway.
Thanks Ian, it's clear that RRF is sending the wrong information. It's using the number of visible axes where it should be using the number of total axes. I'll fix it in RC4.
Oh. Does that mean it is co-incidental with my creating the additional U and V axes? I have to say that I don't usually take much notice of the extruder drive position, otherwise I would have spotted it sooner.
Apologies to Chris. Hope he didn't spend too much time chasing this "Red Herring".
What am i doing wrong ?
I installed the 1.20RC3 and webserver
but lost wifi signal ?SENT: M115
READ: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20RC3 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-16 -
Which firmware version were you upgrading from?
Yes. If you send M584 P5 to make the additional axes visible, I think the extruder positions will magically correct themselves.
i updated from RC1 to RC2 then it stopped running with wifi and i used the new www file to fix the problem
now i can only control my printer via wifi for 5 minutes(with constant disconnects) and i was able to start a print
but the printer stopped beeing able to connect via webhost
only seldomly beeing able to connecti would love to post my current version but it wont let me connect
its FW RC2
Wifi Beta10 i believe
and RC3 WebclientDid you install DuetWiFiFirmware twice as recommended in the upgrade notes?
Yes i did and it works for a few seconds but i just connected wanted to set the temp then it disconnected and doesnt let me connect again
6:34:03 PMDisconnected.
6:32:41 PMConnection established!
6:32:40 PMPage Load complete!I restarted the Duet and i was able to connect
then i disconnected while i was doing autocalibrationAgain another restart!
this time i was quick !!!
6:46:57 PMEndstop adjustments X-0.26 Y0.61 Z-0.35, tilt X0.00% Y0.00%
Diagonal 291.060, delta radius 144.058, homed height 380.282, bed radius 200.0, X 0.829°, Y 0.399°, Z 0.000°File 0:/gcodes/Step_1_-Single-Wall_Box.gcode selected for printing
6:46:56 PMM32 0:/gcodes/Step_1-_Single-Wall_Box.gcode
Calibrated 6 factors using 13 points, deviation before 0.248 after 0.105
6:45:41 PMConnection established!
6:45:41 PMPage Load complete!The Print itself looks good but i cannot connect with the printer so i cannot see the status nor do anything with my printer except restarting or waiting for the print to finish..
after the restart it works for a certain ammount of time
i have restarted the device and reconnected
then i have set bed temperature 1 minute later it was dead and didnt respond to pings while still heating to temperature and beeing responsive with a cable and pronterfacethe disconnects are making using the printer almost impossible
I reinstalled the Firmwares
I started by reuploading both bins on the SD connecting the Printer with Pronterface and then Installing the Firmware first then the Wifiserverit worked for 5 minutes then the same problems appeared
