New firmware 1.20 Release Candidate 2 - please try it!
Just wanted to download 1.20RC3 but got confused, because all the directories are named 1.19RC3….
Which directories?
Which directories?
It can be a bit confusing:
https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-Ethernet/EdgeFilename is DuetEthernetFirmware-1.20RC3.bin Version says: 1.19RC3
4. Various DWC issues, which I believed are resolved in DWC 1.20-RC3.Some have been resolved but the extruder position issue that I reported above is still outstanding.
Ian, we're not sure whether this is a DWC issue or a RRF issue. So please can you set up a situation in which this issue is visible. Then send M408 S2 and M408 S3 and report the responses. Also report what DWC is displaying and what you think it should display instead.
David/Chris et al,
So powering up the Duet, the Machine Status Panel (on Machine Control Page, top right of DWC) shows me the 5 extruder drives labelled DO, D1, D2,D3 and D4 which is correct. Under each drive is shown the "position" which to start with is 0.0 for all 5 of them. I set the active temperature for all tools to 180deg C (they all share the same heater) to allow normal extrude. Once up to temperature under "Extruder Control" I then select Extruder Drive 0, Feed Amount 20, Feed Rate 5 and hit the button "Extrude". Visibly I observes that drive 0 rotates. After the 20mm of filament has been extruded, the position of the extruder drives is now Drive 0 = 0.0, Drive 1=0.0, Drive 2 = 20.0, Drive 3= 0.0, Drive 4 = 0.0. Expected behaviour would be for Drive 0 to show 20.0 (this is the one that that has just extruded 20mm of filament), and the other 4 drives to show 0.0. Especially Drive 2 because like the other 4 drives, it hasn't been commanded to move nor has it physically moved yet after extruding 20mm of filament from Drive 0, Drive 2 show the "position" has changed form 0.0 to 20.0.
Responses as follows:
15:30:59
M408 S2
{"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0,0.0,20.0,0.0,0.0],"xyz":[0.000,0.000,0.000]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,100.00,100.00,100.00,100.00,49.80,49.80,0.00],"speedFactor":100.00,"extrFactors":[100.00,100.00,100.00,100.00,100.00],"babystep":0.000},"sensors":{"probeValue":525,"fanRPM":0},"temps":{"bed":{"current":21.9,"active":0.0,"state":0,"heater":0},"current":[21.9,180.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,2,0,0,0,0,0,0],"heads":{"current":[180.0],"active":[180.0],"standby":[0.0],"state":[2]},"tools":{"active":[[180.0],[180.0],[180.0],[180.0],[180.0],[180.0]],"standby":[[0.0],[0.0],[0.0],[0.0],[0.0],[0.0]]},"extra":[{"name":"MCU","temp":31.4},{"name":"Duet\Duex","temp":30.8},{"name":"Z Stepper","temp":19.7},{"name":"LeftLowerXYStepper","temp":21.3},{"name":"RightLowerXYStepper","temp":21.1},{"name":"LeftUpperXYStepper","temp":21.4},{"name":"RightUpperXYStepper","temp":20.9}]},"time":1324.0}15:32:59
M408 S3
{"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0,0.0,20.0,0.0,0.0],"xyz":[0.000,0.000,0.000]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,100.00,100.00,100.00,100.00,49.80,49.80,0.00],"speedFactor":100.00,"extrFactors":[100.00,100.00,100.00,100.00,100.00],"babystep":0.000},"sensors":{"probeValue":525,"fanRPM":0},"temps":{"bed":{"current":22.2,"active":0.0,"state":0,"heater":0},"current":[22.2,180.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[0,2,0,0,0,0,0,0],"heads":{"current":[180.0],"active":[180.0],"standby":[0.0],"state":[2]},"tools":{"active":[[180.0],[180.0],[180.0],[180.0],[180.0],[180.0]],"standby":[[0.0],[0.0],[0.0],[0.0],[0.0],[0.0]]},"extra":[{"name":"MCU","temp":31.4},{"name":"Duet\Duex","temp":30.9},{"name":"Z Stepper","temp":19.7},{"name":"LeftLowerXYStepper","temp":21.2},{"name":"RightLowerXYStepper","temp":21.0},{"name":"LeftUpperXYStepper","temp":21.4},{"name":"RightUpperXYStepper","temp":20.8}]},"time":1444.0,"coldExtrudeTemp":160,"coldRetractTemp":90,"tempLimit":290,"endstops":3968,"firmwareName":"RepRapFirmware for Duet Ethernet","geometry":"coreXYUV","axes":3,"axisNames":"XYZUV","volumes":2,"mountedVolumes":1,"name":"TallCoreXY","probe":{"threshold":700,"height":-0.50,"type":1},"tools":[{"number":0,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":1,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":2,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":3,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":4,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]},{"number":5,"name":"","heaters":[1],"drives":[0,1,2,3,4],"axisMap":[[0],[1]],"fans":1,"offsets":[0.00,0.00,0.00]}],"mcutemp":{"min":15.9,"cur":31.4,"max":31.8},"vin":{"min":24.4,"cur":24.6,"max":24.7}}Edit. Similar behaviour happens when I use the other extruders and during printing. That is to say, Drive 3 shows the value for drive 1, drive 4 shows the value for drive 2. So Drives 0 and 1 always show 0.0.
Which directories?
Looks like I got the file commit comment wrong! Version 1.20RC4 coming soon anyway.
Thanks Ian, it's clear that RRF is sending the wrong information. It's using the number of visible axes where it should be using the number of total axes. I'll fix it in RC4.
Oh. Does that mean it is co-incidental with my creating the additional U and V axes? I have to say that I don't usually take much notice of the extruder drive position, otherwise I would have spotted it sooner.
Apologies to Chris. Hope he didn't spend too much time chasing this "Red Herring".
What am i doing wrong ?
I installed the 1.20RC3 and webserver
but lost wifi signal ?SENT: M115
READ: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20RC3 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-16 -
Which firmware version were you upgrading from?
Yes. If you send M584 P5 to make the additional axes visible, I think the extruder positions will magically correct themselves.
i updated from RC1 to RC2 then it stopped running with wifi and i used the new www file to fix the problem
now i can only control my printer via wifi for 5 minutes(with constant disconnects) and i was able to start a print
but the printer stopped beeing able to connect via webhost
only seldomly beeing able to connecti would love to post my current version but it wont let me connect
its FW RC2
Wifi Beta10 i believe
and RC3 WebclientDid you install DuetWiFiFirmware twice as recommended in the upgrade notes?
Yes i did and it works for a few seconds but i just connected wanted to set the temp then it disconnected and doesnt let me connect again
6:34:03 PMDisconnected.
6:32:41 PMConnection established!
6:32:40 PMPage Load complete!I restarted the Duet and i was able to connect
then i disconnected while i was doing autocalibrationAgain another restart!
this time i was quick !!!
6:46:57 PMEndstop adjustments X-0.26 Y0.61 Z-0.35, tilt X0.00% Y0.00%
Diagonal 291.060, delta radius 144.058, homed height 380.282, bed radius 200.0, X 0.829°, Y 0.399°, Z 0.000°File 0:/gcodes/Step_1_-Single-Wall_Box.gcode selected for printing
6:46:56 PMM32 0:/gcodes/Step_1-_Single-Wall_Box.gcode
Calibrated 6 factors using 13 points, deviation before 0.248 after 0.105
6:45:41 PMConnection established!
6:45:41 PMPage Load complete!The Print itself looks good but i cannot connect with the printer so i cannot see the status nor do anything with my printer except restarting or waiting for the print to finish..
after the restart it works for a certain ammount of time
i have restarted the device and reconnected
then i have set bed temperature 1 minute later it was dead and didnt respond to pings while still heating to temperature and beeing responsive with a cable and pronterfacethe disconnects are making using the printer almost impossible
I reinstalled the Firmwares
I started by reuploading both bins on the SD connecting the Printer with Pronterface and then Installing the Firmware first then the Wifiserverit worked for 5 minutes then the same problems appeared
Confirmed. Sending M584 P5 makes the 20.0mm value magically jump two places to the left from D2 to D0. With the U and V axes visible, any commanded extrusion amount increments the position for the correct drive, Thanks.
Flashing RC3 yesterday wifi seemed to work properly and worked a few seconds after power up now and then this:
[...] Recv: Error retrieving WiFi status message Recv: Error retrieving WiFi status message Recv: Error retrieving WiFi status message Recv: Error retrieving WiFi status message Recv: Error retrieving WiFi status message Recv: Error retrieving WiFi status message Recv: Error retrieving WiFi status message [...]
Wifi debug does not give me any more info. Web server is dead.
M999 resets and I get connected to wifi:
Recv: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20RC3 ELECTRONICS: Duet WiFi 1.0 + DueX5 FIRMWARE_DATE: 2017-12-16 Recv: ok Recv: Wifi module is connected to access point Tomato24, IP address 192.168.1.111
Then 15-20 seconds later without doing anything is crashes again with lots of "Recv: Error retrieving WiFi status message"
This is a new one for me.
@strips, please follow the instructions at https://www.duet3d.com/forum/thread.php?pid=32944#p32944.
David, that is what I did.
Connected to DuetWifi by USB (octoprint in bigbox). The M111 S1 P14 really does not give my anything after it failed. I need to try again and enable before it fails to see if I get anything before.
Funny… not changing anything today everything works
So I have to call this one off for the moment
Please try the new 1.20RC4 and DWS 1.20RC1 that I have just released.
The Machine Properties tab is not reporting the motor currents in RC4 or RC3. Not sure about earlier versions. Could be a DWC thing too I suppose?
1. Use M140 H0:2:3:4 to configure multiple bed heaters, instead of M140 P0 H0, M140 P1 H3 etc.
Thoughts?That sounds very good to me.
Hi I still a lot of problems to Connect, to my DuetWifi board, is just go on and off.
I Have install the new 1.20RC4 and DWS 1.20RC1, but NO, the only drifrence from RC3 I can see, is it now only reconnect once, the it say WiFi reported error: Timed out while trying to connect to ….This is from Pronterface, and running a M111 S1 P14
Connecting...
Printer is now online.
WiFi reported error: Lost connection, auto reconnectingM111 S1 P14
SENDING:M111 S1 P14
Debugging enabled for modules: WiFi(14)
Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
WiFi reported error: Timed out while trying to connect to Nordbygaard
WiFi: sleep enable,type: 2
WiFi: sl
WiFi: scandone
WiFi: usl
WiFi: state: 5 -> 0 (0)
WiFi: rm 0
WiFi: pm close 7
WiFi: del if0
WiFi: usl
WiFi: mode : nullAny ide, what this can be?
