6XD - AC Servo drive (single-ended and differential signal)
@dc42 Hi!
Ok, will place an order for the additional Duet HW, hopefully I will manage all connections without any issues.
Thank you,
@Zdenko Can you upload a picture of how you installed the resistors ?
@Zseven Hi,
It is a bit messy as all of it is outside of the encolure now, there are two resistors, one for STEP and one for DIR, I soldered them on the wire terminals and insert them in a connector, you will need to put some shrinking tube so that you don't short the pins/wires.
@dc42 Hi,
I received Duet 3 Mini5+ and Duet 3 Mini 2+, I managed to get it working without any issues for now, first I was super scared as the conveyor width stepper was making super weird noise then I researched a bit and found out that I needed this:
M569 P05.0 D3 H50 v50 S0; Conveyor_Width
M915 P05.0 T50After adjustment, the motor is working well, no more weird noises, now I need to finish 3 "Zones" of the conveyor, and sensors and put all the electronics in the Industrial enclosure, this should all be easy.
https://www.youtube.com/watch?v=PELvjKmPtk0&feature=youtu.be
This combination of Duet 3 Mini5+,Duet 3 Mini 2+,6XD and 2x3HCs, was a super nice decision, thank you.
Zdenko,
@Zdenko Thank you very much !
Hello ,
I have this servo controller, can I connect it directly to the 6Xd ? Because that stands for Puls and Signal max 3.6V. -
Or is it better to go via open-collector ?
@Zseven sadly there is no standard interface for external drivers or servo drives. There are at least 4 different ones:
- Opto isolated inputs requiring 5V input at 5 to 10mA, intended to be driven by open collector/open drain outputs.
- Standard 3V differential inputs as used by RS422/RS485 systems.
- Differential inputs but requiring more than 3V drive (e.g. Clearpath servos need 5V).
- As #1 but requiting 24V drive, intended to be driven by PLCs.
The most common is #1 so Duet 6XD supports it directly. Duet 1XD supports #1 and #3, and will generally work with #2 as well because the inputs don't normally mind being overdriven a little (if they do then series resistors can be added).
From the information you posted, it appears to me that your drivers support #2 and #4. The 6XD doesn't support either directly, because the open drain outputs are rated to 5V not 24V.
We made provision on the 6XD to add a daughter board to generate different signal levels, but we haven't produced any such daughter boards yet.
@dc42 What other information do you need?
Can't I just convert the 5v to 3v with a 10ohm resistor?
I have a 6xd board ..that is supposed to drive xyz with servo motors .
I have chosen these faithfully as they have a save torque off function. So that the drives can offer when the door is open.
Render from the printer that ist in work
Here is the plan from the documentation
I have spoken to the manufacturer on the phone.
The documentation is wrong. They say it has to be at least 2.8-3.6 volts and a maximum of 5 volts. -
hi,
I am trying to use the same AC servo drive and motor, but i am a bit lost with the motion controller settings.
Could you let me know what's your's.
I am trying to connect this using a 1xd formelly used to run an external nema driver but i am here lost with AC servo motors.
For now it is wired in single ended mode, would you recommend differential mode ?thanks for the help !
