Duet overhaul of Builder Extreme 2000 3D Printer
Hi Everyone ,
I am currently updating/overhauling a Builder Extreme 2000. With the following parts a Duet 3 MB 6XD , Raspberry Pi 4 Model B , PanelDue 5i , Duet 3 Toolboard 1LC , Revo Hemera XS , Duet Magnetic filament monitor and a BL Touch. I have removed the old MB and am now starting to wire the drivers to the new MB.
This is my first time ever working on a 3D printer so please be understanding if not everything seems logical!
I feel as if this may be the first Industrial Builder Brand printer to get a Duet overhaul?
Any advice or wisdom would be greatly appreciated
Thank You. -
@900turbo, welcome to the forum!
Most of the information you need should be the wiki at https://docs.duet3d.com/. See the wiring diagrams for your Duet components in particular. To get connected to your 6XD board, see https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet.
Feel free to ask here if anything isn't clear, or if you have any questions. We are here to help.
I wish you success with your overhaul project.
You might find this helpful: https://docs.duet3d.com/en/User_manual/Overview/Adapting
@Phaedrux Thank You this was very helpful , currently i cannot locate any datasheet for the motors online , sending M501 did not result in a current configuration either.
@dc42 Thank you so much!
I have successfully got power to the mainboard using the existing PSU , so have updated the firmware and am now making a start on the wiring. For the Duet 3 Toolboard 1LC where would I supply power from the MB am I correct in saying that OUT_0 would be correct. The RJ11 side of it makes sense to me.
Thank you. -
@900turbo power the toolboard directly from the PSU rather than out0 as that connection is typically used for beds.
@900turbo as @jay_s_uk says, power it directly from the PSU. It can run on a different PSU from the one powering the 6HC, and at a different voltage if necessary. If you do this, there should be a common ground for both PSUs.
Don’t use OUT0; on the 6HC it is turned off by default at startup, and you need the toolboard to be powered at startup to make contact with the mainboard.
