Only probe where the part will be printed
@Proschi78
I'm unsure where the code you have posted is located.
Please try the following in your Prusa Start GCode.
Don't call any other macros from Prusa!M118 S"Begin slicer start g code" ;M104 S0 R0 P{current_extruder} ;Dummy Set temps to zero to stop slicer adding them T{current_extruder} ; select tool used on first layer M703 ; load config file for [filament_type] G90 ; Switch to using Absolute Coordinates M82 ; set extruder to absolute mode M568 P{current_extruder} R{"{heat.coldExtrudeTemperature+5}"} S{first_layer_temperature[current_extruder]} A1 ; (set extruder to stanby to soften any protruding filament before probing ) M106 P{current_extruder} S0 ;Start with fan off M118 S"Heating Bed" G4 S1 M140 S{first_layer_bed_temperature[current_extruder]} R{bed_temperature[0]-20}; Set fast bed temp & standby - Standby is 20 degrees less than normal. M116 ; Wait for bed before doing mesh probe. M561 ; clear any bed transform M291 S0 T3 P"Homing..." G28 ; Home all M400 ; wait for last move M98 P"0:/sys/mesh.g" A{first_layer_print_min[0]} B{first_layer_print_max[0]} C{first_layer_print_min[1]} D{first_layer_print_max[1]} N60 ; set N to your desired distance between probe points G29 S1 ; load small mesh G1 Z3 F2000 ; Move to Z3 for height clearance before Intro line G92 E0 ; set position ; intro line G1 Z0.35 F6000 ; G1 X60 Y-2 F6000 ; G1 X140 Y-2 E20 F200 ; G1 x160 y-2 F5000 G1 Z5 F2000 ; Move to Z5 to prevent dragging nozzle and scratching bed G1 x170 y-2 F2000 G92 E0 ; set position G1 F9000.0 ; M106 P3 S33 M117 Printing...
Error: in file macro line 6 column 59: meta command: expected numeric operands Cancelled printing file 0:/gcodes/Part 27 - Part 2.gcode, print time was 0h 2m 20.12.2022, 21:53:49 M32 "0:/gcodes/Part 27 - Part 2.gcode" File 0:/gcodes/Part 27 - Part 2.gcode selected for printing Begin slicer start g code Heating Bed
If I exclude M98 then normal mesh leveling and printing work.
M118 S"Begin slicer start g code" ;M104 S0 R0 P{current_extruder} ;Dummy Set temps to zero to stop slicer adding them T{current_extruder} ; select tool used on first layer M703 ; load config file for [filament_type] G90 ; Switch to using Absolute Coordinates M82 ; set extruder to absolute mode M568 P{current_extruder} R{"{heat.coldExtrudeTemperature+5}"} S{first_layer_temperature[current_extruder]} A1 ; (set extruder to stanby to soften any protruding filament before probing ) M106 P{current_extruder} S0 ;Start with fan off M118 S"Heating Bed" G4 S1 M140 S{first_layer_bed_temperature[current_extruder]} R{bed_temperature[0]-20}; Set fast bed temp & standby - Standby is 20 degrees less than normal. M116 ; Wait for bed before doing mesh probe. M561 ; clear any bed transform M291 S0 T3 P"Homing..." G28 ; Home all M400 ; wait for last move ;M98 P"0:/sys/mesh.g" A{first_layer_print_min[0]} B{first_layer_print_max[0]} C{first_layer_print_min[1]} D{first_layer_print_max[1]} N60 ; set N to your desired distance between probe points G29 G29 S1 ; load small mesh G1 Z3 F2000 ; Move to Z3 for height clearance before Intro line G92 E0 ; set position ; intro line G1 Z0.35 F6000 ; G1 X60 Y-2 F6000 ; G1 X140 Y-2 E20 F200 ; G1 x160 y-2 F5000 G1 Z5 F2000 ; Move to Z5 to prevent dragging nozzle and scratching bed G1 x170 y-2 F2000 G92 E0 ; set position G1 F9000.0 ; M106 P3 S33 M117 Printing...
@Proschi78
Hi, I use SuperSlicer, but I think in prusa Slicer it should also work.
in my startcode I added this line:M557 X{first_layer_print_min[0]}:{first_layer_print_max[0]} Y{first_layer_print_min[1]}:{first_layer_print_max[1]}
maybe this will help you too.
@danym21 Error: in GCode file line 182 column 7: M221: expected number after 'S'
Extruder pressure advance: 0.065, 0.000
Error: in file macro line 8 column 8: M557: unknown value 'first_layer_print_min^'can you give me your whole start code ?
and mesh.g ? -
@Proschi78
start G-Code:G90 ; use absolute coordinates ;M83 ; extruder relative mode ;BED_MESH_CALIBRATE AREA_START={first_layer_print_min[0]},{first_layer_print_min[1]} AREA_END={first_layer_print_max[0]},{first_layer_print_max[1]} ;MINX:{first_layer_print_min[0]} ;MINY:{first_layer_print_min[1]} ;MAXX:{first_layer_print_max[0]} ;MAXY:{first_layer_print_max[1]} M557 X{first_layer_print_min[0]}:{first_layer_print_max[0]} Y{first_layer_print_min[1]}:{first_layer_print_max[1]} M82 ; absolute extrusion mode M104 S140 T0 M140 S[first_layer_bed_temperature] ; set bed temp M190 S[first_layer_bed_temperature] ; wait for bed temp G32 ; home all G1 X-14 Y-10 F10000 ; Reset speed and extrusion rates M200 D0 ; disable volumetric e M220 S100 ; reset speed M221 S100 D0 ; reset extrusion rate M109 S{first_layer_temperature[initial_extruder]+extruder_temperature_offset[initial_extruder]} ; wait for extruder temp G92 E0.0 ;G1 X150.0 E20 F1000.0 ; intro line G1 E20 F1000.0 ; intro line G1 X0.0 Y0.0 Z0.1 F1000.0 ; go outside print area ;G1 X5 Y0 G92 E0.0 G1 X2 Y2 Z0.2 E0 F18000 ; new G1 X60 Y2 E9.0 F1800 ;intro Line ;G1 X200.0 E30 F500 ; second Part intro Line G92 E0.0 G1 Z5 E-{retract_length[0]} F{retract_speed *60} G1 X{first_layer_print_min[0]} Y{first_layer_print_min[1]} Z{first_layer_height} F30000 G1 E{retract_length[0]} F{retract_speed*60} G92 E0.0
I do not use a mesh.g this does not exists on my system
my bed.g:; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 09 2020 01:08:02 GMT+0100 (Mitteleuropäische Normalzeit) M561 ; clear any bed transform G4 P100 G28 ; home G0 Z10 F4200 G0 F60000 G30 P0 X5 Y155 Z-99999 ;Orbiter G30 P1 X302 Y155 Z-99999 S2 ;Orbiter G30 P0 X5 Y155 Z-99999 ;Orbiter G30 P1 X302 Y155 Z-99999 S2 ;Orbiter G91 ;Relative positioning G1 Z5 F1500 ;Raise Z 5mm G90 ;Absolute positioning G0 X45 Y-5 F60000 G29 ;Probe the heatbed and generate heightmap G91 ;Relative positioning G1 Z5 F1500 ;Raise Z 5mm G90 ;Absolute positioning G4 P100 G0 X0 Y0 F60000 ;Go to Parking Position
some settings in config.g that maybe relevant for:
... M671 X-52:377 Y155:155 S2.5 ; leadscrews at left (connected to Z) and right ... M557 X10:300 Y10:300 P6:6; S40 ; define mesh grid ( the normal full size mesh config)
jetzt gehts
now it works -
@Proschi78
@danym21 Do you also have start codes for other slicers?
@Proschi78
no, sorry
but on S3d maybe have a look to this variables:
I do not know what is in, but you can test with a smal object and check then the gcode file[build_size_x] [build_size_y] [build_size_z] .... [next_position_x] [next_position_y] [next_position_z]
they are mentioned here:
https://community.ultimaker.com/topic/11328-simplify3d-hidden-undocumented-placeholders-for-post-processing-scripts/ -
@danym21 thanks I'll test that tomorrow
@danym21 said in Only probe where the part will be printed:
@Proschi78
what can I do with this start code so that it is probing in mesh like A5 in normal mesh?
Best off five ? -
@Proschi78 said in Only probe where the part will be printed:
ke A5 in no
the A5 needs to be in the config.g where you configure the probe type
look for M558
https://docs.duet3d.com/User_manual/Reference/Gcodes#m558-set-z-probe-type -
@danym21
I know that and I also have it in the config.g
but if I start a print and it only creates the mesh where the printed part is, then it only runs once in zM558 P1 C"io3.in" H5 A5 S0.009 F150 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z1.730; set Z probe trigger value, offset and trigger height M557 X30:330 Y-3:210 P9
@Proschi78
mhm, this makes no sense for me, do you have a M558 on some other positions? like in the the bed.g or config-override.g?I will test this when I have time for, I normaly use only one probe per point.
Just want to share the solution I made for this a couple of months ago (posted here)
as well.It works with PrusaSlicer/SuperSlicer, Cura and Ideamaker. Instructions are included as well.
https://github.com/MaikoHermans/RRF-PAM -
Has anyone managed to do it with simplify v5?
@Proschi78
I would like to know the same
