Printing speed just slow motion
In the slicer (Cura) I set a print speed of 30 mm/s. However, the printer printed in absolute slow motion. What can be the reason?
You're going to have to post your config.g file so people can look at your settings.
Also, it's helpful to post the output from the Diagnose command M122
I would guess that the printer profile you are using has some speed commands for marlin in the start gcode that is setting the speed to a lower minimum than you have in config.g
Check your slicer start gcode and remove any speed commands and make sure it's set to RepRap gcode flavor.
This post is deleted! -
@Phaedrux
Hi, here is my starting g-code. Which of these should I delete?M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
Many greetings,
Don -
@axiom delete the M201 and M203 lines.
I'd delete these as well
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk -
@Phaedrux
I deleted all 4 lines... and what can I say... amazing speed!!
Thank you both
Many greetings,
DonPS: New puzzles are just appearing again (progress display and filament consumption...but first the printer is running and I can devote myself to the insulation and construction space closure)
