Extract temp to external display
@tecno
In DWC it is here: -
I have menu and creates Display folder and files in it. Still no go
But does not show in left column ?
@tecno
Put all menu files directy into menu folder. You don't need the subfolder display. -
Done and still no go. Is M918 P2 enough to initialize the display?
https://docs.duet3d.com/User_manual/Reference/Gcodes#m918-configure-direct-connect-display
Maybe check the contrast parameter
That is different to mine..... -
Tried another set of cables = no go
Is it maybe so that there is no firmware, if so what files do I need?
@tecno
Maybe swapped wiring?
Check if EXP1 + EXP2 on board and the display are plugged in correctly. -
@tecno
This is what it looks like in my menu folder
Cables are inserted OK . My menu folder is like yours.
Did you ever load in FW in your display board?
Tried those settings also, next to be a pin detective and see if there is something in wireing.
Thanks for help, appreciated.
Will try more tomorrow.
Pinout seems to be OK.
Is this display 5V and not compatible with Mini5+ ?
Why is there no DISPLAY in the left menu?
@tecno
It's under System. Have a look at the screenshot I have posted yesterday. -
@tecno did you get it working?
Unfortunately no
Is there anybody out there (Pink Floyd) that can help me?
@tecno
Can we have some picures of the wiring?
