Extract temp to external display
So this would be OK to use? MKS Mini12864 V3
@tecno yes that display is suitable.
So I got two displays now to play with, need help to what files to copy to SD card and config lines.
1 Bigtree-tech MINI12864 V.1.0
2. Bigtree-tech RepRapDiscount full graphic smart controllerAdvice much appreciated
@tecno said in Extract temp to external display:
12864
The second one may have problems with the logic level.
Background info here
https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Connecting_a_12864_mono_graphics_LCD_display_with_rotary_encoderThe second one works for me with a level shifter
https://forum.duet3d.com/topic/23034/12864-display-st7920-on-duet-3-mini5
But I would recommend to use the first one.
ThenM918 P2
must be set in config.g
For the menu files see here:
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_12864_menu
I use this version
https://github.com/jadonmmiller/UltimateDuetMenuSystem
There is also a demo video.
You can download the archive here:
https://github.com/jadonmmiller/UltimateDuetMenuSystem/releases/download/V1.10/V1.10_UltimateDuetMenuSystem.zipExtract the files and upload them via DWC to the display folder.
https://docs.duet3d.com/en/User_manual/Reference/Duet_Web_Control_Manual#main-menu -
@DIY-O-Sphere
This is what I have in config
M575 P1 S0 B57600 ; enable support for PanelDue
M918 P2 ; configure direct-connect display
M550 P"BigDelta"So how do I create DISPLAY and copy the files there?
@tecno
Sorry,
DWC link is outdated.....I haven't found the upload in the current version.....
Pull the SD card and create an folder called "menu"
@tecno
In DWC it is here: -
I have menu and creates Display folder and files in it. Still no go
But does not show in left column ?
@tecno
Put all menu files directy into menu folder. You don't need the subfolder display. -
Done and still no go. Is M918 P2 enough to initialize the display?
https://docs.duet3d.com/User_manual/Reference/Gcodes#m918-configure-direct-connect-display
Maybe check the contrast parameter
That is different to mine..... -
Tried another set of cables = no go
Is it maybe so that there is no firmware, if so what files do I need?
@tecno
Maybe swapped wiring?
Check if EXP1 + EXP2 on board and the display are plugged in correctly. -
@tecno
This is what it looks like in my menu folder
Cables are inserted OK . My menu folder is like yours.
Did you ever load in FW in your display board?
Tried those settings also, next to be a pin detective and see if there is something in wireing.
Thanks for help, appreciated.
Will try more tomorrow.
