Led on the duet mother board lights up
Hi I have had a duet wifi for a wile now but recently have had a problem with the led lighting up when I move my y axis and x axis even when there's no power going to the board I use a ac relay for a keenovo 800 watt silicone bed
Can you give us some more detail?
See here for how to help us help you: https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-helpWhen you move the axis by hand, the motors become generators and create a current of their own which flows back into the board and lights up the LEDs. If you do this too fast you can generate enough current to cause damage.
Otherwise I can't figure out what issue you're trying to describe.
@phaedrux ill try to explain it a little better i have had this duet 2 wifi for over a year working great but recently i tried to hook up a a berd air part cooling pump directly to the pwm fan output and i think i blew the fan port or something because now ever time that turn off the power compleatly and i then try to move my x/y axis manually with my hand the little red led illumates near the usb in and i hear like high pitched wine as well when the led iillumantes
Yes it sounds like something isn't right. Does it work when the berd air is not running? If so, I would stop using that until you figure this out to prevent more permanent damage.
How exactly do you have the pump connected?
@bigwood247 said in Led on the duet mother board lights up:
That's normal. When you move the motors by hand they act as generators. The stepper driver chips feed the power they generate into the fused side of the VIN supply.
