pwm controlled waterpump
@cosmowave
The tacho signal will be your biggest problem, if you want to use it as closed-loop feedback.
Duet2 isn't capable to read fast signals from external sources.
You could probably use it as a sign of life signal or attach an external RPM meter? -
@cosmowave
Not sure if it's the same type of pump but on my duet wifi I have this setup;water pump M950 F1 C"!fan1+^exp.pb6" Q25000 ; create fan 1 (water pump) on inverted pin fan1 and set its frequency. Set RPM to E3 stop with pullup enabled M106 P1 C"Water Pump" H1 L0.5 X1 B1.2 T50:60 ; set fan 1 name and value. Thermostatic control is turned on. Monitoring hotend sensor ; water temp monitor & fan M950 F2 C"!fan2+^exp.e3_stop" Q25000 ; create fan 2 on pin fan2 and set its frequency M308 S5 P"e1temp" Y"thermistor" A"Water temp" T10000 B3950 ; Configure Water temp sensor M106 P2 C"Radiator Fan" H5 L0 X1 B1.2 T33:38 ; set fan 4 value, turn on at 30% if the water temperature reaches 30C, and increase to full speed gradually as the temperature rises to 40C
@cosmowave most likely the pump takes a standard open drain PWM input. In which case you can connect it as you would connect a 4-wire fan. However, as it draws about 1.7A, you can't power it from the internal 12V supply of a Duet 3 or Duet 3 Mini assuming you are using 24V VIN. So you will need an external buck regulator to provide 12V.
Thanks for your answers.
@o_lampe
It will be ok as a "sign of live" signal. Closed-loop control is not really necessary
I will also try an external flow-meter and temp sensor. But again, also for checking if flow is present.@dc42
I d'like to power (+12VDC,GND) the pump directly from my 12V power supply.
Only the pwm and tacho signal goes to the duet. -
@cosmowave
Definitely a different pump to me but similar idea.
I use this
https://www.aliexpress.com/item/4000034575710.html
I power mine from an external 12v supply as the duet is on 24v.
DWC looks like his
I monitor the pump in daemon.g
@cosmowave said in pwm controlled waterpump:
Has your pump also a pwm control input?
Yes it does.
Essentially I treat it as a thermostatically controlled fan.
Same with the radiator fan.
In my case the radiator fan doesn't ever turn off completely as it has a minimum possible PWM (didn't realise till I got it).EDIT
I should note that the indicated speed is the impeller speed.
If a hose blew, it would still show as running. I need to put a flow sensor on the return near the radiator as well. -
@dc42 said in pwm controlled waterpump:
Is it possible to power the pump from the bed heater output?
I use a SSR (3-32VDC in) for my bed.
Is it possible to set the bed heater output constantly on, without linking to a temp sensor? -
You can invert the pin name with a ! to have it on by default.
@Phaedrux
oh yes. That's easy!
Thanks -
@phaedrux said in pwm controlled waterpump:
But is it possible to create the (bed) heater, which i'd like to use for powering my water pump (always on), without linking it to a temp sensor?
With M950, the T parameter seems not to be optional... -
Well you can link it to any temp sensor you like with any temp range you like. So in effect any sensor could allow it to be enabled or disabled.
I suppose you could define it as a GPIO pin to control the water pump with an M42 command instead of as a heater, then it's just on or off.
@cosmowave
Maybe define it as a spindle? That way you don't need a temp sensor and can set RPM directly. (as percentage of max RPM) -
@o_lampe But is "spindle on/off" M3 / M5 not CNC/laser specific ? Can i use the commands in printer mode?
Why do you need to PWM control this cooling unit? I use similar as @OwenD SSR to switch on the pump. Always ON
M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency Hotend Cooling Waterpump M106 P1 S1
@tecno I'd like the idea to control the speed of the pump... also for reliability.
