Software bundle 3.4.0 stable released!
@damaged_goods I use Prusa Slicer - it works perfectly fine.
@damaged_goods said in Software bundle 3.4.0 stable released!:
Is there a Reprap Slicer that the community finds works best?
For what printer and what Duet board? Duet3d Mini5 on Prusa MK3?
I have a MB6HC with a SBC-Rasbarry Pi 4.
I am using the apt-get update / apt-get upgrade. It says that nothing to upgrade. But when I try the M115 command it says firmware 3.2.2
Do I do something wrong?
I have been following the documentation.
@boa Thank you,
@zapta It's a custom built very large printer with a duet 3 MB6HC.
@schickfus can you open a separate thread for your issue please
@jay_s_uk ok
@damaged_goods I use SuperSlicer. https://github.com/supermerill/SuperSlicer/releases
It has thumbnails compatible with the PanelDue.
@dc42 said in Software bundle 3.4.0 stable released!:
Thumbnail
Anyone know how to get thumbnail generation in Cura?
@tfjield Install the RRF plugin for Cura.
@tfjield said in Software bundle 3.4.0 stable released!:
https://github.com/Kriechi/Cura-DuetRRFPlugin/releases/tag/v1.2.5
@tfjield That plugin allows you to send the gcode files directly to the printer, yes, and also will embed the thumbnail. I believe you can also save the gcode file locally.
@tfjield it will ask you to link to a printer, but after you sliced a file you will see a little caret on the blue "Send to ..." button where you can choose to save the file locally.
@oliof
After I installed it, I now have 4 options after slicing:- Simulate on xxx
- Print on xxx
- Upload to xxx
- Save to Disk
If I choose Save to Disk, it looks like the plugin is bypassed and the thumbnail isn't generated. All of the other 3 options appear to require my printer to be online.
Is this correct, or am I doing something wrong?
@tfjield short answer: the "Save to Disk" option is from plain Cura - not my plugin. If you want a dedicated "Save to Disk with thumbnails"-like option, let's move the conversation to a new thread.
