Software bundle 3.4.0 stable released!
@zapta given that the input shapers supported by RRF have effective bandwidths of up to 3:1, it's not necessary to do anything as complex as that.
To get a 3:1 ratio of resonant frequencies on the X and Y axes, and assuming X and Y axes use belts of approximately equal width, length and tension, you would need a mass ratio of 9:1. That's higher than you are likely to get even in a large bed slinger.
@dc42, thanks for the explanation.
@dc42 - this release seems to be breaking my Nozzle Heater on the 1LC.
@dc42 Hey David. Thanks to you and others for all the work you are putting into reprap.
As a Prusa user I am use to being spoon fed firmware and Slicer settings. Is there a Reprap Slicer that the community finds works best?
Thanks again. -
@damaged_goods I use Prusa Slicer - it works perfectly fine.
@damaged_goods said in Software bundle 3.4.0 stable released!:
For what printer and what Duet board? Duet3d Mini5 on Prusa MK3?
I have a MB6HC with a SBC-Rasbarry Pi 4.
I am using the apt-get update / apt-get upgrade. It says that nothing to upgrade. But when I try the M115 command it says firmware 3.2.2
Do I do something wrong?
I have been following the documentation.
@boa Thank you,
@zapta It's a custom built very large printer with a duet 3 MB6HC.
@schickfus can you open a separate thread for your issue please
@jay_s_uk ok
@damaged_goods I use SuperSlicer. https://github.com/supermerill/SuperSlicer/releases
It has thumbnails compatible with the PanelDue.
undefined chrishamm unpinned this topic
@dc42 said in Software bundle 3.4.0 stable released!:
Thumbnail
Anyone know how to get thumbnail generation in Cura?
@tfjield Install the RRF plugin for Cura.
@tfjield said in Software bundle 3.4.0 stable released!:
https://github.com/Kriechi/Cura-DuetRRFPlugin/releases/tag/v1.2.5
@tfjield That plugin allows you to send the gcode files directly to the printer, yes, and also will embed the thumbnail. I believe you can also save the gcode file locally.
@tfjield it will ask you to link to a printer, but after you sliced a file you will see a little caret on the blue "Send to ..." button where you can choose to save the file locally.
@oliof
After I installed it, I now have 4 options after slicing:- Simulate on xxx
- Print on xxx
- Upload to xxx
- Save to Disk
If I choose Save to Disk, it looks like the plugin is bypassed and the thumbnail isn't generated. All of the other 3 options appear to require my printer to be online.
Is this correct, or am I doing something wrong?
