Software bundle 3.4.1RC1 now available
@boa i had an issue with 3.4 where the firmware got wiped from the board.
plug a USB in and see if a BOSSA port appears. If so, reflash the firmware -
@alex-cr There is no need to update them because they target 3.4 and not 3.4.0. If you run into problems, try to download and reinstall the affected plugin(s).
@dc42 We finally had time to install this on a machine. No issues so far, but testing has just begun. Something we'd really like to see addressed in 3.4.1 is fixing job progress when thumbnails are used as the current calculation appears to count the thumbnails as part of the print job, skewing the results.
@oozebot said in Software bundle 3.4.1RC1 now available:
This should only be an issue when the print file is small. It won't be changed in 3.4.1 but is already on the list for 3.5.
@dc42 Thanks for the response. I do want to point out that it does affect larger jobs as well when multiple thumbnails are embedded. However, this isn't a showstopper - just something we'd like to see addressed soon as we really like the thumbnail feature!
@chrishamm said in Software bundle 3.4.1RC1 now available:
After reinstall they worked again. Thanks for the help!
Having issues with the 3.4.0-b1 input shaping plugin not wanting to install on DWC 3.4.1-rc1 for some reason
EDIT: found out that the plugin was looking for DWC 3.4.0, changed it to 3.4 and repacked it so now it works
it still contains the following BUG:
https://forum.duet3d.com/topic/27288/rrf-3-4-beta-7-tool-offsets-issue
Regards Christian (CR-3D)
@cr3d no it doesnt
@cr3d I have replied to the thread that you linked to.
