BLTouch on Duet 3 Expansion XD1
Is it possible to connect the bl touch to the xd1 expansion board, or is it not supported?
Best, -
@phaedrux yes I mean the 1xd expansion board
@rabbit yes you should be able to use IO0 or IO2 to support a BLTouch because both support PWM on the output pin. It's probably never been tested, but it uses the same code as the tool board, which definitely supports BLTouch.
@dc42 Hi,
I had a typo in my config. now it works fine.
Thanks for the great support. -
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
