BtnCmd-DWC Plugin - Customise DWC - v01.03.05 20-09-24
@stout said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.03 28-12-21:
Pity, then the plug in don't change the background colour? -
No. It only gives you colour control over the buttons and panels you create yourself. You can also add standard DWC panels, and re-size them, but not change the colour of them
Can you tell me the name of the zip file you uploaded to DWC please.
And if you want to, please try installing this version as a check.
@stout That version in the picture is version 0.10.03, I mentioned earlier you need 0.9.06.
The filenames are BtnCmd_[DWC Ver]_[BtnCmd Ver].zip
You asked for the zip file I uploaded and gave you a snapshot of it!
I installed BtnCmd_DWC3.3_Beta.0.9.04.zip without any problem. I then checked the SD, deleted the just installed files and copied 0.10.03 manually. when I started it, I got this:
So I copied over the css files from 0.9.0.4 but let the 0.10.03 on the SD-card and it's starting up again though the old version.
I'll play around with it as I am going to use one more Duet 3 for a CNC with an iPad.
@stout 0.10.03 isn't supported in 3.3.0. you either have to install the last supported version (0.9.06) or upgrade to 3.4rc1 so you can use 0.10.03
I have published Beta 0.10.06 for DWC 3.4RC1
Changes:
Fixed rendering issue input panels.
Updates to how BtnCmd works with new DWC features.
Added Auto Backup feature - please see wiki for more info. -
Published 0.10.07
Changes :
- Various Bug Fixes
- New Input Panel Options
Input panels for global variables can now be configured as sliders, switches, selection lists, or input fields:
Please see this wiki page for more details
Hi is there away to take data via i2c or serial to display in a "text Box"? or an option to Poll data/request via serial ?
@moth4017 The plugin can display data from the Object Model, it does not have access to anything else.
I have published 0.10.08.
Change Log:
Added Console Panel
Notes:
This will be the last version of the plugin to include the events functionality. I am depreciating this feature as the introduction of 'tab sleeping' by many of the main browsers causes issues for this feature, plus the functionality no longer aligns with the core of BtnCmd. -
Awesome plugin!
Trying to make a little organized flow and ran into a sizing bug with custom panels.
I made a custom panel with a object model value and resized it. I save the custom panel but it does not save. Looking at the backup json file confirms this, and if I manually edit, it will be displayed properly.
Thanks
@mrwulff I cannot replicate this behaviour.
I tell a lie - I have just replicated it - let me look into it.
@mrwulff I found the issue. I will push an update out later once I have run some quick sanity checks.
@mrwulff Published v0.10.09
Changes:
- fixed resizing issue with custom panels
- removed Event feature
As previously noted in the last release - this version depreciates the Event system from BtnCmd. I have depreciated this feature as the introduction of 'tab sleeping' by many of the main browsers causes issues for this feature, plus the functionality no longer aligns with the core of BtnCmd.
Published Beta 0.10.10 for DWC 3.4
Changes:
- Updated Alt Web Cam panel to align with recent DWC webcam changes
- Removed >= 5000 ms update interval requirement from Alt Web Cam Panel settings
- Added CNC Panels :
- CNC Info Panel
- CNC Movement Panel
- CNC Spindle Speed Panel
- Added CNC detection - Available Panels will now be filtered based on FFF/CNC operating mode
@mintytrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.10 08-06-22:
I want to try your plugin for a CNC/Laser combo machine I'm currently building. Will there be a difference in panel availability, if I switch back_and_forth from laser- to CNC-mode too?
Or is there a combo mode possible that would show laser panels and CNC at the same time? -
@o_lampe I released an update 2 mins ago to allow the Panels in both Laser & CNC mode
Is there someplace to download different configurations of entire layouts of panels and buttons.
or a way to load user created custom panels themselves.would be great if we could share various configurations to get us 90% of the way there.
@adamfilip said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.11 11-06-22:
would be great if we could share various configurations to get us 90% of the way there.There is no functionality to share custom panels/layouts. Only the backup and restore feature. I will add the request to the wish list, and look into it.
Released BtnCmd Beta 0.10.12
https://github.com/MintyTrebor/BtnCmd/releasesChange-Log:
Added Import / Export feature
Changed Backup Icon actions
Notes on Import / Export:
Importing Layouts and custom panels designed on a different screen resolution may result in objects displaying incorrectly. This limitation cannot be changed. -
