Software bundle 3.4.0 stable released!
@dc42 Awesome!
I'm not able to update currently but a couple questions.
Is the Input Shaping plugin be installed by default? Also, will the Input Shaping page be updated to give more detail any time soon?
Thanks!
@nightlonk42 said in Software bundle 3.4.0 stable released!:
@fcwilt
Awesome!I'm not able to update currently but will the Input Shaping plugin be installed by default?
Also, will the Input Shaping page be updated to give more detail?Thanks!
I have no idea. I haven't yet worked up the courage to install 3.4.
This post is deleted! -
I found the one below. Not sure if it was installed by 3.4 or was there before. Also, IIRC there was another 'external' accelerometer plugin which doesn't seem to be installed. (The TrueImage popup is a system artifact, not related to DWC).
@nightlonk42 @zapta You can find the plugins (except for the closed loop plugin beta that is still on its own repo) here: https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.4.0 You can expect more improvements for the input shaper tuning soon.
I'm already looking forward to 3.5
Been a happy 3.4 early adopter for quite some time now and Input Shaping brings so much to the table. Exciting times! Hopefully the IS Plugin gets to the point of comfort and ease-of-use as in Klipper!
Hopefully the trend to better motion planning continues, keep up the good work!
@chrishamm those look neat, I can't seem to be able to install them though?
I get this error message:
InvalidOperationException in InstallPlugin: Cannot perform command because the plugin service is not started
Any tips?
Thanks!
@chrishamm, do the extra plug-ins work with stand alone duet? (Asking because they have DSF in their path)
@zapta only the motion one is SBC only
Thanks for this update.
I can see the thumbnails on the pc using webcontrol.
But i see no thumbnails on the PanelDue.
On the PanelDeu is the latest firmware 3.4.1-pre2.
The slicer i have is Prusaslicer and thumbnails are 160x160. -
@mike3d note: PanelDue can only use QOI format. PrusaSlicer 2.4.1 not creating yet QOI.
@mike3d you can get Windows and Mac binaries of a fork of Prusa Slicer that supports QOI format from https://github.com/n8bot/PrusaSlicer/releases/tag/version_2.5.0-alpha0%2Bn8-release1. This version also has the option to retrieve the machine parameters from the Duet via http, if you have configured it for upload via http. Thanks to user @bot for implementing all of this.
@fractalengineer Have a look at the DSF upgrade notes for v3.3, it sounds like you missed them.
@dc42 said in Software bundle 3.4.0 stable released!:
This is big news. Especially on the Duet integration part.
Thanks @chrishamm, I was able to install the external input shaping plugin. Next will figure out how to use it.
BTW, if most of the external plugins are not DSF specific, maybe remove DSF from their path on github?
@bberger I have submitted a Pull Request to PrusaSlicer to include those integrations: https://github.com/prusa3d/PrusaSlicer/pull/8087
Is there a roadmap for RRF 3.5 available? What will be its focus?
@ctilley79 Looking at the Github commit history, independent gcode streams seems to be the main feature being developed right now.
Failed up to Upgrade from 3.2.2 to 3.4.0
Wifi card is stuck in Starting mode. no actual IP working.
Help!Do I need to revert back to 3.2.2 or reset back to factory or what?
Please advise -
@stevenl said in Software bundle 3.4.0 stable released!:
Please adviseYou may need to reflash the wifi module. Try sending M997 S1 from the USB terminal.
