Solved 3.4rc1 Mini 5+ bltouch not retracting
For good measure can you share your config.g, and the results of M122?
I downgraded to 3.4b6 to get a print done but here is config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Ender 3" ; set printer name M918 P1 E4 F2000000 ; configure direct-connect display M929 P"log.txt" S1 ; Enable logging ;M552 S1 ; Enable network ; Drives M569 P0.0 S1 D3 V0 F4 ; physical drive 0.0 goes backwards, stealthchop enabled M569 P0.1 S0 D3 V0 F4 ; physical drive 0.1 goes backwards, stealthchop enabled M569 P0.2 S1 D3 V0 F4 ; physical drive 0.2 goes backwards, stealthchop enabled M569 P0.3 S0 D3 V0 F4 ; physical drive 0.3 goes forwards, stealthchop enabled M569 P0.4 S0 D3 V0 F4 ; physical drive 0.4 goes forwards, stealthchop enabled M569 P0.5 S1 D3 V0 F4 ; physical drive 0.5 goes backwards, stealthchop enabled M569 P0.6 S1 D3 V0 F4 ; physical drive 0.6 goes backwards, stealthchop enabled M584 U0.0 X0.3 Y0.4 Z0.5:0.6 E0.1:0.2 ; set drive mapping M350 U16 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 U80.00 X80.00 Y80.00 Z400.00 E413.4:413.4 ; set steps per mm M566 U450 X450 Y450 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 U9000.00 X9000.00 Y9000.00 Z480.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 U2500.00 X2500.00 Y2500.00 Z20.00 E500.00:500.00 ; set accelerations (mm/s^2) M906 U1000 X1000 Y1000 Z1000 E1200:1200 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M915 X Y S5 F1 R0 H150 ; Stall detection XY log on stall M915 Z S3 F1 R2 H200 ; Stall detection Z pause on stall M915 P0.1:0.2 S5 F1 R0 ; Stall detection E0,E1 do nothing ; Axis Limits M208 U-80.8 X-212 Y-150.6 Z0 S1 ; set axis minima M208 U213.8 X95 Y100 Z230 S0 ; set axis maxima ; Endstops M574 U2 S1 P"io0.in" ; configure active-high endstop for high end on Y via pin io0.in M574 X1 S1 P"io5.in" ; configure active-high endstop for low end on X via pin io6.in M574 Y1 S1 P"io6.in" ; configure active-high endstop for low end on Y via pin io5.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Filament runout sensors M591 D0 P1 C"^io3.in" S0 ; Left extruder runout ;M591 D1 P1 C"^io2.in" S0 ; Right extruder runout ; Z-Probe M950 S0 C"io1.out" ; create servo pin 0 for BLTouch M558 P9 C"^io1.in" B1 H5 F480 T6000 ; set Z probe type to bltouch and the dive height + speeds disable heaters when probing G31 P500 X66 Y12 Z1.8 M557 X-110:110 Y-110:110 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"pt1000" ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 280C M308 S2 P"temp2" Y"pt1000" ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S300 ; set temperature limit for heater 2 to 280C ; Fans M950 F0 C"out5" Q1000 ; create fan 0 on pin out5 and set its frequency M106 P0 C"Part Coling T0" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"!out3+out3.tach" Q1000 M106 P1 C"Hotend Fan T0" S64 X64 H1 T45 M950 F2 C"out6" Q1000 ; create fan 2 on pin out6 and set its frequency M106 P2 C"Part Cooling T1" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off M950 F3 C"!out4+out4.tach" Q1000 M106 P3 C"Hotend Fan T1" S64 X64 H2 T45 ; Tools M563 P0 S"Left Tool" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"Right Tool" D1 H2 F2 X3 ; define tool 1 using U axes for X G10 P1 X0 Y2 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined M307 H0 R0.281 C428.8 D4.28 S1.00 V23.9 ; Miscellaneous ;M911 S21 R23 P"M913 X0 Y0 G10 P0 R0 S0 G91 M83 G1 Z3 E-5 F10000" ; set voltage thresholds and actions to run on power loss M572 D0 S0.05 ; Guestimate pressure advance setting M207 S0.5 F2400 ; Retraction 0.5mm @40mm/s M671 X-145:145 Y0:0 S3 F1 ; leadscrew co-ordinates M81 C"ps_on" ; Turn off power supply (makes power switch show in webui) ; Load from config-override.g M501
deployprobe.g:
M280 P0 S10 ; deploy BLTouch
In 3.4rc1 the probe now deploys but doesn't retract after probing.
Machine was completely powered off after the update.
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.0rc1 (2022-02-09 10:27:22) running on Duet 3 Mini5plus WiFi (SBC mode) Board ID: W4ZW4-V296U-D65J0-40KM0-LR03Z-H6928 Used output buffers: 1 of 40 (14 max) === RTOS === Static ram: 103652 Dynamic ram: 102128 of which 0 recycled Never used RAM 35788, free system stack 134 words Tasks: SBC(ready,3.9%,504) HEAT(notifyWait,0.0%,356) Move(notifyWait,0.0%,292) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,1.1%,114) MAIN(running,93.8%,558) IDLE(ready,0.4%,29) AIN(delaying,0.8%,264), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:08:35 ago, cause: software Last software reset at 2022-02-09 18:36, reason: User, GCodes spinning, available RAM 36076, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 MCU revision 3, ADC conversions started 515901, completed 515899, timed out 0, errs 0 Step timer max interval 1489 MCU temperature: min 27.5, current 37.5, max 37.8 Supply voltage: min 0.5, current 24.3, max 24.3, under voltage events: 1, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: pos 3760, standstill, SG min 0, read errors 0, write errors 2, ifcnt 13, reads 44146, writes 25, timeouts 0, DMA errors 0, CC errors 0 Driver 1: pos -1280, standstill, SG min 0, read errors 0, write errors 2, ifcnt 10, reads 44148, writes 23, timeouts 0, DMA errors 0, CC errors 0 Driver 2: pos 3560, standstill, SG min 0, read errors 0, write errors 2, ifcnt 10, reads 44147, writes 23, timeouts 0, DMA errors 0, CC errors 0 Driver 3: pos 17104, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44140, writes 29, timeouts 0, DMA errors 0, CC errors 0 Driver 4: pos 0, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44142, writes 29, timeouts 0, DMA errors 0, CC errors 0 Driver 5: pos 0, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44142, writes 29, timeouts 0, DMA errors 0, CC errors 0 Driver 6: pos 0, standstill, SG min 0, read errors 0, write errors 2, ifcnt 15, reads 44140, writes 29, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2022-02-09 18:46:07 Cache data hit count 1160425780 Slowest loop: 60.47ms; fastest: 0.08ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 6, maxWait 48307ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 39, completed 39, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: ok === CAN === Messages queued 4633, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 2578/0/0 Tx timeouts 0,0,2577,0,0,2054 last cancelled message type 4514 dest 127 === SBC interface === Transfer state: 4, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 20857/20857 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x0f624 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server v3.4-rc1 Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 40.50, max time between full transfers: 47.1ms, max pin wait times: 46.5ms/6.9ms Codes per second: 0.45 Maximum length of RX/TX data transfers: 3592/1136
Further debug...
I replaced my bltouch with a multimeter set to measure frequency and duty cycle.
Reset the board by pressing the reset button
Measured 0% duty
Sent M280 P0 S90
Measured 7.35% duty at 50Hz
Send M280 P0 S180
no change in measurement
sent m280 P0 s270
no change in measurement.
reset board.
sent m280 p0 s270
measured 12% duty at 50Hz
sent m280 p0 s90
Thus i think my issue is the same as this thread:
https://forum.duet3d.com/topic/27139/rrf-3-4-0beta7-5-sbc-servo-only-responding-once-after-reset
With 3.4b6
Reset the board by pressing the reset buttonMeasured 0% duty
Sent M280 P0 S90
Sent M280 P0 S180
Send M280 P0 S270
Sent M280 P0 S90
So updating servo positions multiple times in 3.4b6 works
@serbitar I can confirm that this is a bug in 3.4.0rc1. It affects the use of port IO1 on the Duet 3 Mini to connect a servo or BLTouch, but not IO2 or IO3. Are you able to use either of those ports for now? Note that IO3 is shared with the 12864 backlight control.
Ah! I will sacrifice one of the runout sensors to put it on io3 and give it a go, thanks.
Works great on io3 thanks again.
@serbitar I've put corrected firmware for the Mini5+ at https://www.dropbox.com/sh/hx23neagiljflv2/AADxC8_URWgoU_NYcYP8b7XCa?dl=0.
bltouch back on io1 with your updated build works. fantastic! thanks!
