Smoothed fan PWM wiring
I've already seen a few posts about using low-pass filters for converting fan PWM outputs to a smooth-ish DC voltage, but I've got a few more specific questions.
Here's some info on my components:
- 24V supply
- 24V / 0.5A / 12W radial blowers (yes, they are big fans)
- Duet 2 + Duex5
I want to use 2 of those fans for a static part cooling system in my Toolchanger. Since these are not PWM fans and they work really well when just controlled by voltage (start to turn around 6V@0.1A), I was thinking about smoothing the PWM signal and have a better time driving the fans.
I was reading in another post by @dc42 that a low-pass filter with an indcutor gives the best results in this scenario and was wondering which specific components I should choose.
My main concern is the rather large power draw of the fans (almost 30W overall), so I need some help spec'ing the components correctly.I plan on connecting the fans in parallel to one of the heater outputs of the Duex, is that alright?
Can someone help me?
Anyone? Maybe @dc42 ?
I cannot help you with this sort of thing.
There was a member who was selling "smoothing" devices. Perhaps you can find his posts.
@diamondback @fcwilt it was @zapta
@PCR did build some too
@diamondback you will need an inductor with inductance of at least 1mH and with both rated current and saturation current at least 1A. Perhaps this one https://www.digikey.co.uk/en/products/detail/bourns-inc/2124-V-RC/775402. Also a 10uF capacitor rated at 35V or more.
You will need to use either a fan output on the Duet (not the DueX, because you can't select a high PWM frequency on the DueX), or a heater output. If you use a heater output then you will also need an external flyback diode. If you use a fan output then unless your Duet is quite old, it will be included on the Duet.
@dc42 Thaks a lot David, I ordered the components. Also good tip about the flyback, did not have that on my mind...
@dc42 I've wired everything up and it's working very well! Thanks again!
One question though, What effect does the PWM frequency have? Is a specific value needed other than "as high as possible"? -
@diamondback about 65khz i think
@diamondback
65535 -
@diamondback said in Smoothed fan PWM wiring:
One question though, What effect does the PWM frequency have? Is a specific value needed other than "as high as possible"?The smoothing is only effective at high PWM frequencies (you would need a larger inductor for it to work at lower frequencies). The maximum PWM frequency supported is 65535 Hz.
