Solved Printer don't heat after longer in IDLE state 3.4b7+1
This is the same error we reported here: https://forum.duet3d.com/topic/26463/bed-heater-stops-working-after-being-idle-for-some-time
For me it is happening on both Duet 2 wifi and Duet 3 Mini 5+; I'm pretty sure it was not always both heaters (Bed & hotend).
I don't remember having the issue on b6. -
Its also happening to me with firmware Beta7+2 using duet3 + 3HC
I just finished one print job, loaded up another, had a cup of coffee and then clicked start.
20 mins later it still wasnt started and the bed was cold yet the print status was in printing state
undefined MikeDC referenced this topic
Same here, after one print is done I can not heat up hotend nor bed (from drop down menu and/or sending M104/M140)
Duet 2 WiFi fw3.4b7
Quite convinced I didn't had this issue with fw3.4b6, to confirm this I've downgraded now and will print a thing or too. Will report back.
Also I'll upgrade my Duet 2 Ethernet tomorrow or so and see if that's the case with Ethernet variant too.
All those of you experiencing this issue, please can you answer the following:
Does this issue only occur after you have done a print and then left the machine idle for some time?
Does it affect the bed heater, the tool heater, or both?
How does your GCode print file end? In particular:
- Does it turn off the bed heater using M140 ?
- Does it turn off the tool heater(s) using M104 ? Or does it set the temperatures low using G10? Or neither?
- Does it use M0 ?
- What (if anything) do you have in your stop.g file?
no, it has happened to me if i have left the printer on for a long time without printing and it has happened after a print if left powered on for a long time before starting a 2nd print
its only affected the bed heater for me
end g-code
M122 ; debug following print
M104 S0
M140 S0
;Retract the filament
G92 E1
G1 E-10 F50
G28 X0 Y320 -
my stop.g
G91 ; relative moves M140 S0 ; turn off bed M106 S0 ; part cooling fan off G1 E-1 F300 ; retract the filament a bit before lifting the nozzle, to release some of the pressure G1 Z+10.0 E-2 ; move Z up a bit and retract filament even more M104 S0 G28 X0 ; move X to min endstops, so the head is out of the way G90 G1 Y300 F2000 M84 ; steppers off M42 P2 S0 ; set heatbed contactor off M300 P300 S4000 ; play beep sound
Also,
I have a macro to turn on off my heatebed contactor, even turning the heatebed contactor off/on with m42 it still will not heat the bed.
i have to power off/on the machine. -
@dc42 said in Printer don't heat after longer in IDLE state 3.4b7+1:
Yes, but I have to say that I don't have tested it without a print this I can do today I will post the result this evening
in my case, Both
G90 ; Switch to relative mode G1 E-5 f3600 ; retrac filamnet G91 ; Switch to absolute mode M104 S0 ; turn off extruder M140 S0 ; turn off bed G91 ; use relative coordinates G1 Z5 F1200 H2; lift nozzle by 5mm G90 ; use absolute coordinates G28 X0 ; home X axis G1 Y195 ; move Y axis to end position M106 P0 S0 ; Bauteilkhler aus M106 P2 S0 ; beleuchtung aus M107 ; turn off fan
Yes
Yes
Does it use M0 ?
No
stop.g is empty
@mikedc M140 S0 and M104 S0 will not turn the heaters off; only change the target temperature to zero. Could it be that this generates a heater fault when it fails to reach that temperature? The release notes mention that earlier versions did set the heaters to the "off"-state after a finished print while the current (beta) version does not if there is a stop.g file present.
- Haven't tried to do next job earlier than 30mins after 1st finished, I'll see if I can spot next print finish to test straight away.
- Both, although I haven't tried cold bed print, always both heaters are on.
- Just M104 and M140 to zero, XY home and M84
- This is fairly new build so it's as generic as it gets out of online configurator.
On the previous post of mine, after downgrade to 3.4.0b6 on Duet 2 WiFI it works fine and 3.4.0b7 Duet 2 Ethernet has the same issue.
Ta
Kris
@dc42 My printer was 9 hours in idle state without a print job and the heating works
Basically, if the temp of the hot end goes below 18C or so. If I remove power for 24+ hours and then fire the machine up it will occur.
Mine just effects my hot end on my 1LC. My bed heater on my 6HC works fine.
Yes to all 3 questions.
4.stop.g
G1 E-3.0 F1500 ; clear extruder G91 G1 Z5.0 F20000 ; move Z from part G90 M104 S0 ; Extruder heater off M140 S0 ; Bed heater off M141 S0 ; Chamber heater off M106 P3 S0 ;turn off lights M106 P2 S0 ;turn off MCU fans M106 P0 S0 ; Turn part fan off M106 P6 S0 ; turn off Nevermore fan M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M98 P"/macros/print_scripts/goto_bucket.g" ;go to park position over bucket
I finished a long print around 3 hours ago today and left the printer idle afterwards.
I have just tried another print,
My main contactor does switch on but the bed is not heating.
i cancelled the print and thought i would do a couple of tests.
I can heat the nozzle manually and disable the nozzle heater
I have full control of it from both paneldue and dwcthe bed heater no control on temperature
i can manually turn the contactor on and off both by the paneldue and dwc
i can appear to enable / disable the bed heater
but it just doesnt heat up.Only a full power reset will allow it to work again
@mikedc This is fixed in 3.4.0beta7+4, see https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-2-files.
is this a different b7+2 to what i am on ?
I used b7+2 to fix the z on expansion card issue but i still have this issue with bed not heating up after idle -
@mikedc yes. the latest builds on that thread are now 3.4b7+5
ahh now b7+4 thankyou :)))I will install after my print has finished
undefined SIam has marked this topic as solved
@dc42 It looks good ! Thanks for fixing this issue
for me, b7+4 don't resolve problem
@bastien New version have been published since b7+4, I believe the last one is +7
I don't remember having this error lately.You should be able to download b7+7 from here:
https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files/17?_=1642785164011
Need to scroll to get the link. -
it's ok with b7+7, thanks
