Solved Printer don't heat after longer in IDLE state 3.4b7+1
Basically, if the temp of the hot end goes below 18C or so. If I remove power for 24+ hours and then fire the machine up it will occur.
Mine just effects my hot end on my 1LC. My bed heater on my 6HC works fine.
Yes to all 3 questions.
4.stop.g
G1 E-3.0 F1500 ; clear extruder G91 G1 Z5.0 F20000 ; move Z from part G90 M104 S0 ; Extruder heater off M140 S0 ; Bed heater off M141 S0 ; Chamber heater off M106 P3 S0 ;turn off lights M106 P2 S0 ;turn off MCU fans M106 P0 S0 ; Turn part fan off M106 P6 S0 ; turn off Nevermore fan M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M98 P"/macros/print_scripts/goto_bucket.g" ;go to park position over bucket
I finished a long print around 3 hours ago today and left the printer idle afterwards.
I have just tried another print,
My main contactor does switch on but the bed is not heating.
i cancelled the print and thought i would do a couple of tests.
I can heat the nozzle manually and disable the nozzle heater
I have full control of it from both paneldue and dwcthe bed heater no control on temperature
i can manually turn the contactor on and off both by the paneldue and dwc
i can appear to enable / disable the bed heater
but it just doesnt heat up.Only a full power reset will allow it to work again
@mikedc This is fixed in 3.4.0beta7+4, see https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-2-files.
is this a different b7+2 to what i am on ?
I used b7+2 to fix the z on expansion card issue but i still have this issue with bed not heating up after idle -
@mikedc yes. the latest builds on that thread are now 3.4b7+5
ahh now b7+4 thankyou :)))I will install after my print has finished
undefined SIam has marked this topic as solved
@dc42 It looks good ! Thanks for fixing this issue
for me, b7+4 don't resolve problem
@bastien New version have been published since b7+4, I believe the last one is +7
I don't remember having this error lately.You should be able to download b7+7 from here:
https://forum.duet3d.com/topic/26787/unofficial-rrf-3-4-0beta7-4-files/17?_=1642785164011
Need to scroll to get the link. -
it's ok with b7+7, thanks
