Unsolved [3.4.0b7] Firmware update changes 1LC temp
No issue with bed thermistor here:M308 S0 P"0.temp0" Y"thermistor" T100000 B4725 C7.06e-8
@dc42 Hi, no, don't get more accurate.
@marshal Here is the documentation from RatRig
This post is deleted! -
@serge thanks, so this is not an issue with firmware 3.4.0beta7 in particular.
Have you run temperature input calibration on input temp0 of the main board (where the bed heater is connected)?
@dc42 No, i don't.
Did you think i have to modify the B3950 to B4725 ?
I don't know what thermistor is for B3950. -
@serge try running ADC calibration on that input, see https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings#Section_Semi_automatic_calibration.
@serge I made the modification to the B4725, and the bed temperature seems to be much more real now.
I think i will try whith this value now. -
I have upgraded back to b7, (sbc mode), but apt spit an error:
Setting up reprapfirmware (3.4-b7-1) ... Unhandled exception. System.Collections.Generic.KeyNotFoundException: The given key '' was not present in the dictionary. at System.Collections.Generic.Dictionary`2.get_Item(TKey key) at DuetControlServer.Utility.Firmware.UpdateFirmwareRemotely() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Utility/Firmware.cs:line 425 at DuetControlServer.Program.CheckForAnotherInstance() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 349 at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 100 at DuetControlServer.Program.<Main>(String[] args) Aborted
I'll appreciate if someone can throw some insight on what might be wrong with the SBC upgrade mode..
Meanwhile I have manually updated the 6HC and 1LC firmwares (B7-1) from the thread here. Temperature reads normal for me again now. Will give the new firmware a try to see if anything else pops up
edit: here is M121 B121 output:
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.4.0beta7+1 (2021-12-22 18:45:45) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 2152, free system stack 2762 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,115) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,27) TMC(delaying,3.0%,57) MAIN(running,91.8%,351) IDLE(ready,0.0%,26) AIN(delaying,5.0%,142), total 100.0% Last reset 00:06:32 ago, cause: software Last software reset time unknown, reason: AssertionFailed, available RAM 3392, slot 1 Software reset code 0x0120 ICSR 0x00000000 SP 0x2000415c Task Freestk 129 bad marker Stack: 00000544 00022ffc 00019b65 20003134 00016cff 20003134 000163d1 20000ed0 00000000 00000001 00008275 200071c8 200071c8 200071e0 00000000 20000f50 00011647 000223b8 00022474 00021ac8 00019b05 200071c8 200071c8 20000f50 000083ed 200071d8 000009c7 Driver 0: pos 0, 414.0 steps/mm,standstill, SG min 2, read errors 0, write errors 1, ifcnt 177, reads 64992, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 1/6, peak Rx sync delay 599, resyncs 0/1, no step interrupt scheduled VIN voltage: min 24.7, current 24.8, max 24.8 MCU temperature: min 37.8C, current 37.9C, max 38.4C Last sensors broadcast 0x00000002 found 1 205 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 8154, send timeouts 0, received 3564, lost 0, free buffers 37, min 37, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0 === Filament sensors === Interrupt 4 to 12us, poll 6 to 572us Driver 0: pos 36.21, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
undefined Marshal referenced this topic
I was referred to this thread by Marshal.I have a similar problem with a PT1000 reading low at ambient temperature on an LC1 toolboard, after fitting a new E3D one to replace a thermistor.
The PT1000 reads 1071 Ohms at ambient, which should be 18.4'C
(My heating runs at 18'C so pretty close).The tool with the PT1000 shows around 8 - 10'C lower than the other two tools, at room temperature; presently its showing 10.5 while the other tools and bed are showing from 18 to 21'C.
I have just loaded the beta7-1 toolboard firmware and power cycled the machine; no change.
I have also run the temperature calibration, which made a slight adjustment according to the status, but did not have any noticeable effect on the ambient reading.25/12/2021, 08:54:03 M308 S1 L999 Measured L correction for port "20.temp0" is 0 25/12/2021, 08:51:56 M308 S1 H999 Measured H correction for port "20.temp0" is -10
M122 B20 result:
25/12/2021, 09:04:07 M122 B20 Diagnostics for board 20: Duet TOOL1LC rev 1.0 or earlier firmware version 3.4.0beta7+1 (2021-12-22 18:45:45) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 3620, free system stack 2788 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.1%,103) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) TMC(notifyWait,3.0%,57) MAIN(running,91.9%,329) IDLE(ready,0.0%,40) AIN(delaying,5.0%,142), total 100.0% Last reset 00:23:27 ago, cause: power up Last software reset data not available Driver 0: pos 0, 409.0 steps/mm,standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 48493, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 0/5, peak Rx sync delay 215, resyncs 0/0, no step interrupt scheduled VIN voltage: min 23.8, current 23.8, max 23.9 MCU temperature: min 23.4C, current 27.7C, max 27.8C Last sensors broadcast 0x00000002 found 1 17 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 27894, send timeouts 0, received 23664, lost 0, free buffers 37, min 37, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: none I2C bus errors 4509, naks 4509, other errors 4509
M308 S1 result
25/12/2021, 09:05:33 M308 S1 Sensor 1 (T0) type PT1000 using pin 20.temp0, reading 10.4, last error: sensor open circuit, R:2200.0 L:0 H:-10
Hope this is useful?
If there are any other tests I can do, please let me know.
Original thread here:
https://forum.duet3d.com/topic/26521/temperature-wrong-after-fitting-pt1000 -
@dc42 i just build a new printer with the dyze 500 C thermistor. I am using the 3.4 B6 on toolboard and duet mini. But the temp of the thermistor is always 15-20 degrees off. I testet it with an external K type thermometer. I see that there was the problem with B7 but could it affect the dyze at B6 too? I am now on holiday but back soon. Will flash 3.3 then ASAP and will compare.
@rjenkinsgb Have you try the semi automatic calibration ?
https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings -
@serge said in [3.4.0b7] Firmware update changes 1LC temp:
Yep, I mentioned I had done that and the output from it was the first insert above.
@rjenkinsgb said in [3.4.0b7] Firmware update changes 1LC temp:
Do you mean beta7+1 ?
If you are certain that your PT1000 is reading correctly (which depends on how accurate your multimeter is), you can adjust the M308 L parameter manually to correct the PT1000 reading at low temperatures.
@dc42 said in [3.4.0b7] Firmware update changes 1LC temp:
If you are certain that your PT1000 is reading correctly (which depends on how accurate your multimeter is), you can adjust the M308 L parameter manually to correct the PT1000 reading at low temperatures.Yes, that's the version; I was not paying attention - though I should have seen it in the M122 output...
OK on the M308 - but what's the likelihood of it being significantly off at working temperatures?
I do trust the meter, it's a calibrated Fluke 187.
@dc42 I'll add to the mystery as I just updated 3 machines - all in SBC mode with a 6hc and a toolboard.
The first is an older machine with a Slice thermistor on temp0 (and temp1 is not utilized). It reported "Heater 1 fault: failed to read sensor: sensor open circuit" after upgrading to 3.4b7. Manually upgrading the toolboard to 3.4b7+1 resolved the issue and the temp reported by toolboard temp0 is equal 3.4b6.
The second machine is using a Slice PT1000 on temp0 and a thermistor on temp1. After upgrading to 3.4b7, both temps remained equal to 3.4b6. The temps remained the same after upgrading to 3.4b7+1.
The third machine is identical to the second machine - the only difference is the Raspberry Pi image has been upgraded to Bullseye for testing. After upgrading to 3.4b7, temp0 rapidly fluctuated between 9-15c (where it should read ~22c). Temp1also rapidly fluctuated between 18-22c (where it should read ~25c). Manually upgrading to 3.4b7+1 resolved the issue for both temp0 and temp1.
To add another data point. Similar to my original post. I went ahead and updated to beta 7+2 to see if it fixed a heating issue on my 1LC and the temp dropped to about 4C at ambient again. Switching bat to 7+1 reverts the temp to normal(18C) ambient values.
@alex-cr thanks for that. Something strange is happening, possibly related to the alignment of a particular piece of code that reads the ADC. Unfortunately all the tool boards I have here don't show any difference between firmware versions, so I can't reproduce this.
@dc42 have you tried it with the HT thermistors?
Best
