M571 not recognizing extruder moves
I am trying to set up
M571
"output on extrude" on my current machine, however I am a bit stuck.The output of the pin never changes, whether I am extruding manually or from gcode.
I have tried several ways and different pins all without successM571 S1 P"0.out8" M571 S1 P"out8" M571 S1.0 P"0.out8" M571 S1 P"0.out7" M571 P"out7" S1 (you get the idea)
I can successfully invert the output pin with the
modifier and measure my VIN voltage, but the pin is not changing when the extruder is active.The extruder is driven by a 1XD board with CAN address 23:
M569 P20.0 S1 ; X forward on 20 M569 P21.0 S1 ; Y forward on 21 M569 P22.0 S0 ; Z forward on 22 M569 P23.0 S0 ; E forward on 23 M569 P24.0 S0 ; U forward on 24
I have figured out that I cannot use the 1XD as output, I get the following error when I try:
M571 P"23.out1" S1 Error: M571: Remote ports are not supported by this command
I suspect that I haven't configures the tool correctly, but I cannot figure out what to change:
M563 P0 D0 ; Define tool 0
If I enter the drive number differently I get an error:
M563 P0 D23.0 Error: M563: bad drive number
Does Anyone have an Idea?
Thanks!Attached the full config file:
config.g -
I've re-posted your config file using the </> tags - it saves folks from having to download it.
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 03 2020 17:01:27 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves ;Recommended by 1XD manual G4 S1 ;wait for expansion boards to start ; Drives M569 P20.0 S1 ; X forward on 20 M569 P21.0 S1 ; Y forward on 21 M569 P22.0 S0 ; Z forward on 22 M569 P23.0 S0 ; E forward on 23 M569 P24.0 S0 ; U forward on 24 M584 X20.0 Y21.0 Z22.0 E23.0 R0 ; set drive mapping for linear axes M584 U24.0 R1 ; set drive mapping for rotational axes ; "fast mode" to allow for a step rate of more than 55kHz M569 P20.0 T2.5:2.5:5:0 ; set pulse timing for X to "fast mode" M569 P21.0 T2.5:2.5:5:0 ; set pulse timing for Y to "fast mode" M569 P22.0 T2.5:2.5:5:0 ; set pulse timing for Z to "fast mode" M569 P23.0 T2.5:2.5:5:0 ; set pulse timing for E to "fast mode" M569 P24.0 T2.5:2.5:5:0 ; set pulse timing for U to "fast mode" ;CONCRETELAB VALUES ;M350 X1 Y1 Z1 E1 U1 I1 ; Configure microstepping with interpolation ;M92 X100 Y100 Z100 E100 U100 ; Set steps per mm ;M566 X3000 Y3000 Z100 U1200 E3000 ; Set maximum instantaneous speed changes (mm/min) ;M203 X15000 Y15000 Z2500 U6000 E50000 ; Set maximum speeds (mm/min) ;M201 X300 Y300 Z100 E1500 U300 ; Set accelerations (mm/s^2) ;PARKER VALUES ;M350 X16 Y16 Z16 E16 U16 I1 ; Configure microstepping with interpolation M92 X180 Y72 Z614 E106 U525 ; Set steps per mm M566 X800 Y800 Z80 E3000 U3000 ; Set maximum instantaneous speed changes (mm/min) M203 X15000 Y15000 Z2000 E36000 U7500 ; Set maximum speeds (mm/min) M201 X300 Y300 Z100 E1500 U5000 ; Set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z000 E-99999 U-99999 S1 ; set axis minima M208 X5000 Y5000 Z3000 E999999 U999999 S0 ; set axis maxima ; Endstops M574 X0 ; no X endstop M574 Y0 ; no Y endstop M574 Z0 ; no Z endstop M574 E0 ; no E endstop M574 U0 ; no U endstop M574 V0 ; no U endstop ; Z-Probe M558 P8 C"22.io0.in" H20 F750 T15000 R1 ; Set Z probe type to switch and the dive height + speeds G31 P500 X0 Y-200 Z156 ; Set Z probe trigger value, offset and trigger height M557 X0:3200 Y0:4200 S500 ; Define probing grid size and spacing M376 H500 ; define compensation taper ; Heaters M140 H-1 ; Disable heated bed ; Tools M563 P0 D0 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Miscellaneous T0 ; Select first tool M302 P1 ; Allow cold extrusion ; Homing outputs M950 P0 C"20.out1" ; Homing request pin for X ;M950 P1 C"21.out1" ; Homing request pin for Y ;M950 P2 C"22.out1" ; Homing request pin for Z ;M950 P4 C"24.out1" ; Homing request pin for U ;M950 P5 C"25.out1" ; Homing request pin for V ; increase movement queque buffer size M595 P240 S500 ; output on extrude ;M571 P"0.out7" S1 ; enable output on extrude M571 S1 P"0.out8" ; ENABLE panelDUE M575 P1 S1 B57600 ;For saving worklpace coordinate systems to file M501
Have you tried executing config.g using M98 P"config.g" from the DWC Console to see if any errors are reported?
Errors in the file during boot are usually not seen.
@too I've looked into this. Currently the M571 feature does not work when the extruder drive is driven from a CAN-connected expansion board. I will work on a fix.
Hey @dc42, just wondering if you have managed to fix this?
I couldn't see anything about that in the changelogs.. -
@too I'm sorry, this has not been fixed yet but it is on the list.
@dc42 alright, that's good to hear... Any idea when this will be fixed time-wise?
Any idea for a workaround in the meantime?
Could I add a second driver to the extruder axis that is mapped to a driver on the 6HC to make this run? I'll go ahead and give this a try.. -
I was hoping to get this working by adding a second driver from the 6HC to the E axis without luck. I am now not sure if this is because of some limitation of RRF that I didn't see or if I am implementing this wrong:
; Configuration file for Duet 3 (firmware version 3) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves ;Recommended by 1XD manual G4 S1 ;wait for expansion boards to start ; Drives M569 P20.0 S1 ; X forward on 20 M569 P21.0 S1 ; Y forward on 21 M569 P22.0 S1 ; Z forward on 22 M569 P23.0 S0 ; E forward on 23 M569 P24.0 S1 ; U forward on 24 M569 P0.0 S0 ; additional axis for OutOnExtrude M584 X20.0 Y21.0 Z22.0 R0 ; set drive mapping for linear axes M584 E23.0:0.0 U24.0 R1 ; set drive mapping for rotational axes [...] ;OMRON VALUES M350 X1 Y1 Z1 E1 U1 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z100 E100 U100 ; Set steps per mm M566 X3000 Y3000 Z100 U1200 E3000 ; Set maximum instantaneous speed changes (mm/min) M203 X15000 Y15000 Z2500 U6000 E50000 ; Set maximum speeds (mm/min) M201 X300 Y300 Z100 E1500 U300 ; Set accelerations (mm/s^2) [...] ;output on extrude M571 P"0.io3.out" S1 ; enable output on extrude
Is there any workaround or quickfix that you can come up with to control a pin according to extrusion moves? Could I somehow use a driver_Enable signal configured in a certain way?
@too said in M571 not recognizing extruder moves:
M584 E23.0:0.0
You've defined 2 extruders, but I only see settings values for one extruder.
Do you have a tool configured to use that extruder?
@phaedrux Yeah, so far I have only been using / configuring single-tool machines. The Extruder tool on 23.0 works fine. but because its on a CAN-extension board the
M571
command doesn't work.The tool is defined to use both drives:
M563 P0 D0:1
I have tried to configure the Extruder tool with drives 0.0 and 23.0 and had partial success: If I writeM584 E:0.0:23.0
then the output on extrude pin switches, but I don't see any STP/DIR signals on 23.0.
If I writeM584 E:23.0:0.0
however, I get no output on extrude pin switches, but I see STP/DIR signals on 23.0...; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 03 2020 17:01:27 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves ;Recommended by 1XD manual G4 S1 ;wait for expansion boards to start ; RESTART 1XD ;M98 P"0:/sys/COBOD_restart_expansionboards" ; reboot 1XD boards ; Drives M569 P20.0 S1 ; X forward on 20 M569 P21.0 S1 ; Y forward on 21 M569 P22.0 S1 ; Z forward on 22 M569 P23.0 S0 ; E forward on 23 M569 P24.0 S1 ; U forward on 24 ; additional E driver for output on extrude M569 P0.0 S0 M584 X20.0 Y21.0 Z22.0 E0.0:23.0 R0 ; set drive mapping for linear axes M584 U24.0 R1 ; set drive mapping for rotational axes ;CONCRETELAB VALUES M350 X1 Y1 Z1 E1:1 U1 I1 ; Configure microstepping with interpolation M92 X100 Y100 Z100 E100 U100 ; Set steps per mm M566 X3000 Y3000 Z100 E3000 U1200 ; Set maximum instantaneous speed changes (mm/min) M203 X15000 Y15000 Z2500 E50000 U6000 ; Set maximum speeds (mm/min) M201 X300 Y300 Z100 E1500 U300 ; Set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z000 E-99999:-99999 U-99999 S1 ; set axis minima M208 X5000 Y5000 Z3000 E999999:999999 U999999 S0 ; set axis maxima ; Endstops M574 X0 ; no X endstop M574 Y0 ; no Y endstop M574 Z0 ; no Z endstop M574 E0 ; no E endstop M574 U0 ; no U endstop M574 V0 ; no U endstop ; Z-Probe M558 P8 C"22.io0.in" H20 F750 T15000 R1 ; Set Z probe type to switch and the dive height + speeds G31 P500 X0 Y-200 Z156 ; Set Z probe trigger value, offset and trigger height M557 X0:3200 Y0:4200 S500 ; Define probing grid size and spacing M376 H500 ; define compensation taper ; Heaters M140 H-1 ; Disable heated bed ; Tools M563 P0 D0:1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Miscellaneous T0 ; Select first tool M302 P1 ; Allow cold extrusion ; Homing outputs M950 P0 C"20.out1" ; Homing request pin for X ;M950 P1 C"21.out1" ; Homing request pin for Y ;M950 P2 C"22.out1" ; Homing request pin for Z ;M950 P4 C"24.out1" ; Homing request pin for U ;M950 P5 C"25.out1" ; Homing request pin for V ; increase movement queque buffer size M595 P240 S500 ; get current position from PLC G28 ;For saving worklpace coordinate systems to file M501 ; output on extrude M571 P"0.io0.out" S1 ; enable output on extrude
Reading through the gcode wiki again I noticed that I probably need to define a mixing ratio, as our slicer doesn't output multiple E values...
I have added the corresponding command to the config.g:; set tool mixing ratio M567 P0 E1:1
........ and now it finally works!
I have added this block onto the end of the config.g; SETUP OUTPUT ON EXTRUDE ; additional "virtual" E driver M569 P0.0 S0 ; updated driver mapping M584 E0.0:23.0 R0 ; updated microstepping setting M350 E1:1 ; updated axis limits M208 E-99999:-99999 S1 ; set axis minima M208 E999999:999999 S0 ; set axis maxima ; updated Tool definition M563 P0 D0:1 ; set tool mixing rato M567 P0 E1:1 ; enable output on extrude M571 P"0.io0.out" S1
Thanks for sending me into the right direction @Phaedrux !
@too I'm sorry this has taken so long to resolve and I am glad you found a workaround. I am implementing a fix for M571 when the extruder is driven from a CAN-connected board in RRF 3.5beta2.
