bed mesh problem with Delta after upgrade to 3.3 from 2.05_1
here is your mesdh.g
; mesh.g M117 Bed Map - Heating Bed ; display message G28 ; home M140 S80 ; set bed temp M190 S80 ; wait for bed temp M140 S0 ; bed heat off G32 M558 P8 I0 A10 S0.01 R0.4 C"zprobe.in" H8 F1500 T6000 ; HOTEND PROBEset Z probe type to switch and the dive height + speeds M557 R140 S14 ; HOTEND PROBE define mesh grid G29 S2 ; clear height map G29 S0 ; run mesh calibration M500 ; save results to EEPROM ;G28 ; home M375 ; load heightmap ;M84 ; motors off M117 End Mesh Probe Calibration ; display message
You need to add G30 to probe the bed and establish a Z datum before starting the mesh
best to do that in the center of the bed so I would add a line to move the probe to the center of the bed, then probe with a single G30 at that point, the start the mesh bed levelling
Per the Duet Wiki: https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Establish_a_Z_0_datum_using_the_Z_probe the Delta AutoCalibration (G32) should produce a Z-0 and be used for Delta machines instead of G30.
G30 isn't the recommended way to set Z height for the delta configuration as it is basically a multiple z-axis bot.
If the Wiki is wrong I'm happy to try with a G30.
@baenwort I find its easiest to home using G28, then do a single probe with G30 and then run G32 and save the results. That gets the homed height correct. And then from there, a G32 should be all that's needed at the beginning of a print
@baenwort doing G32 immediately followed by G29 is the correct method. However, one thing I notice is that you change the probing speed (M558 F parameter) between the G32 and the G29 S0. What happens if you remove the M558 line from mesh.g so that you use the same parameters for G32 and G29?
Also, if you are going to use G29 S2, put it before G32 instead of after.
You don't need the M375 command in mesh.g because the height map will be loaded anyway after G29 S0.
@dc42 said in bed mesh problem with Delta after upgrade to 3.3 from 2.05_1:
If you do this, remove the G29 S1 from the end of your bed.g as well.
Thanks!
I'll give these a try tonight after I get the kids in bed.
This has been frustrating as I like my flex plate system overall but without mesh compensation it isn't as good as glass for large bed filling prints.
I didn't run G29 when I had just glass and a doping agent. But I find that the mag sticker and flex plate added enough nonuniformity that I need it once I get away from the center of the bed.
@dc42 So it seems that the F parameter being different or the G32/G29 S2 order change was what did it. I'm going to try testing tomorrow to see which of the two changes was the causative one.
I hope it is just the F parameter change as I'd like to keep the G29 S1 load in the bed.g as I run a G32 before every print and I'd rather not forget a G29 S1 load.
So I tried with only the F change and it fixed it. The G29 S2 positioning did not affect the mesh to cause the problem I am seeing.
@baenwort said in bed mesh problem with Delta after upgrade to 3.3 from 2.05_1:
I'm glad you solved it. I think what's happening is that the trigger height depends on the probing speed, at least at high speeds, because of the response characteristics of the sensor.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
Seems so. It is a Duet Smart Probe based system from SeeMeCNC. Being a strain probe I expected maybe some difference but this was a rather large difference in results.
It makes me think I might want to spend some time tuning the F parameter.
