Pinda2 to Duet3 toolboard
@oc_geek same story I tried and i gives me false triggers on Pinda 2 too
EDIT
I did the first tests without cycling power, after a power cycle, now it works ok without Pullup -
@dc42 I still do not know if using ^ will damage my duet3
@martin7404 No I don't think it will damage the board. I think the worst case is just lowering the noise floor. But it seems to work BETTER for you?
@martin7404 said in Pinda2 to Duet3 toolboard:
No it won't.
TO warp up
In the end I found that it is working both ways with or without pullup.
I ended up changing pinda2 to superpinda, as far I got one delivered and super panda is working flawlessly with the same config -
@martin7404 Just curious, where were you able to purchase a superPinda? Prusa only sells them to registered owners. Asking because I would like to get one as well.
@kb58 prusa online shop, I have mk3 printer. You can always ask somebody local for you with original prusa to order 1 for you
Hi there,
I wonder if I can connect a original Prusa Super Pinda the same way the pinda 2 is connected?
The Super Pinda has only 3 wires instead of four (white is missing).I assume this is based on temperature independence now.
One thing in addition, does anyone know if the Super Pinda uses 5v only? I read a couple thing like 5v-24v and the higher the more accurate it should be.... is this a rumor, or proofed?
Thanks in advance.
Cheers
@sn1kk3r5 I switched to superpinda and it works. Just ignore the white wire on my drawing in first post
Thanks @martin7404
