BL Touch Installation what is Servo Pin?
Well the BLTouch has a set of 3 wires and a set of 2 wires.
Aside from Power and Ground going to the BLTouch there is an Output which needs a Duet Input and an Input which needs the servo output.
The servo output is what sends the commands to the BLTouch to deploy, retract, reset, etc.
If you're going to use io5 for the bltouch, connect the servo wire to the io5.out pin.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87#s336
@phaedrux I think I have the wiring right but it is not activating, I think because of the Code. I am not sure how I should have the called out the BL Touch.
Remove the
from io5.out and io5.in; Z-Probe M950 S0 C"io5.out" ; create servo pin 0 for BLTouch M558 P9 C"io5.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
You will also need deployprobe.g and retractprobe.g files in your system folder.
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.1 on Wed Aug 25 2021 14:29:48 GMT-0600 (Central Standard Time) M280 P0 S10 ; deploy BLTouch
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.1 on Wed Aug 25 2021 14:30:02 GMT-0600 (Central Standard Time) M280 P0 S90 ; retract BLTouch
Then you can test the pin movement with M401 and M402
@phaedrux Made the fixes to the code and added the retract and deploy.
I can delpoy and retract the probe manually but cannot get it to active upon Home All. The switch I have on the Z axis still works though -
@signpostman I am getting this error
@signpostman you will need to change your homing files to use a G30 probe command instead of the G1 H1 moves.
You can post your homing files here (copy paste the text and use the </> code snippet button when you post) and someone can help you change them.
Alternatively you could just create a new set of homing files that use the BLtouch using the RRF config generator tool.You might also find some of the guide useful from the dozuki:
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation (when you're ready to set up mesh comp) -
@engikeneer I created new file in the configuration tool but it didn't use the G30.
Could someone show me the changes needed?; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 21 2021 12:06:10 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z30 F6000 ; lift Z relative to current position G1 H1 X-2305 Y-1305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-2305 Y-1305 F180 ; move slowly to X and Y axis endstops once more (second pass) G1 X250 Y650 F3000 ;move probe to centre of bed G1 H1 Z-309 F360 ; move Z down stopping at the endstop (first pass) G1 H2 Z5 F6000 ; go back a few mm G1 H1 Z-20Y F180 ; move slowly to Z axis endstops once more (second pass) G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z20 F1800 ; lift Z relative to current position G90 ; absolute positioning
This should do. Note that you'll also need to change your homez.g to match.
Also, if you still have your z endstop installed at the low end, be careful that you aren't going to crash into it when probing
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 21 2021 12:06:10 GMT-0400 (Eastern Daylight Time) G91 ; relative positioning G1 H2 Z30 F6000 ; lift Z relative to current position G1 H1 X-2305 Y-1305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-2305 Y-1305 F180 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X250 Y650 F3000 ;move probe to centre of bed G30 ; probe bed ; Uncomment the following lines to lift Z after probing G91 ; relative positioning G1 Z20 F1800 ; lift Z relative to current position G90 ; absolute positioning
@signpostman said in BL Touch Installation what is Servo Pin?:
Are you using external drivers?
@engikeneer I think that got it! Thanks!
Is there a use for the existing endstop on my Z axis? as a max height? -
Is there a use for the existing endstop on my Z axis? as a max height?I have a Z endstop at Z=0 (Z min) on all of my printers (as well a a Z probe).
It makes for simpler and quicker homing code.
For example to home with a Z probe you first have to home X and Y. To do that safely requires a bit of Z movement when homing X and Y.
With a Z endstop you can home Z first and then X and Y.
Yes, you can move it to the Zmax position and use it in cases of power loss recovery where you need to home the z axis but can't use the probe because there is still a print on the bed. You need to set the Z max travel distance exactly using the probe to determine Z0 first in order to get it to be the right height to match the print position.
It seems I still have a issue with the BL Touch. it does deploy and retract, but the Z axis keep descending without stopping after BL Touch triggered, the BL Touch keeps resetting but not stopping Z Descent.
@phaedrux I think I will do that
Please copy-and-paste, using the </> tag, your current homeall.g file and and homez.g file.
@fcwilt ```
; homeall.g
; generated by RepRapFirmware Configuration Tool v3.3.0 on Sat Aug 21 2021 12:06:10 GMT-0400 (Eastern Daylight Time)G91 ; relative positioning
G1 H1 X-2305 Y-1305 F180 ; move slowly to X and Y axis endstops once more (second pass)G90 ; absolute positioning
G1 X250 Y650 F3000 ;move probe to centre of bedG30 ; probe bed
G90 ; absolute positioning -
And you say M401 and M402 work?
That would suggest that the signal from the BLTouch is not getting to the firmware.
Things to check:
- wiring
- BLTouch configuration commands (M950, M558 and G31)
@fcwilt M401 and M402 work, I wonder if having long cables could be the issue? My printer is huge and the cables are 5m long
5m - wow - that is rather long.
Did you verify that there is continuity on the wire that takes the signal from the probe back to the board?
