After updating to 3.4.0beta2: faulty heater 1, -273.1C.
m122 b121 p1007 a {0x4200442c}
Address 0x00000000 value 0x20008000m122 b121 p1007 a {0x806020}
Address 0x00000000 value 0x20008000 -
@sotidii said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
Address 0x00000000 value 0x20008000Please run those commands again, without a space between 'a' and '{'.
m122 b121 p1007 a{0x806020}
Address 0x00806020 value 0x19147fbe
m122 b121 p1007 a{0x4200442c}
Address 0x4200442c value 0x00000607 -
@sotidii @CadetC @pixelpieper @Serge thanks for your patience.
I have tested the new firmware on 9 tool boards and I don't get a problem reading temperatures on any of them. So I would ask you for some more help. I will apply the changes made to the new tool board firmware a few at a time on top of version 3.3 in order to pin down which change introduced the problem.
I have put new tool board firmware at https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0. Please can you try installing this firmware on your tool boards and let me know whether the temperature readings are OK or not. It identifies itself as version 3.3+test1.
RRF3.4b2 on Duet3
Toolboard v 1.1m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
After toolboard firmware change
RRF3.4b2 on Duet3
Toolboard v 1.1unM122 B121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3+test1 (2021-08-20 16:51:53) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
I think it's fine
29=29 OK! -
My temperature is ok with this version. -
Thanks, all! Please can you now try the firmware file Duet3Firmware_TOOL1LC_test2.bin at https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0.
29=29 Ok -
Temps good on test2 -
Thanks again! Please try firmware Duet3Firmware_TOOL1LC_test3.bin at https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0. If the temperature readings are OK, please use M115 B<can address> to confirm that the firmware installed on the tool board is the test3 version.
Temps good.
I always check the firmware version but here it is:Duet TOOL1LC firmware version 3.3+test3 (2021-08-21 11:42:11) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
@jbarros thanks! Please try test4 at the same location.
@jbarros thanks, I'll prepare test5. Have a nice time at the beach!
@jbarros, test5 is now available, same location https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0.
@Sotidii, please test these files too if you and your machine are free.
test3 , test4,test5 ==OK!
@sotidii thanks! test6 coming soon.
@sotidii please try the test6 file from the same location.
test6 =OK!
