After updating to 3.4.0beta2: faulty heater 1, -273.1C.
RRF3.4b2 on Duet3
Toolboard v 1.1m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
After toolboard firmware change
RRF3.4b2 on Duet3
Toolboard v 1.1unM122 B121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3+test1 (2021-08-20 16:51:53) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
I think it's fine
29=29 OK! -
My temperature is ok with this version. -
Thanks, all! Please can you now try the firmware file Duet3Firmware_TOOL1LC_test2.bin at https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0.
29=29 Ok -
Temps good on test2 -
Thanks again! Please try firmware Duet3Firmware_TOOL1LC_test3.bin at https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0. If the temperature readings are OK, please use M115 B<can address> to confirm that the firmware installed on the tool board is the test3 version.
Temps good.
I always check the firmware version but here it is:Duet TOOL1LC firmware version 3.3+test3 (2021-08-21 11:42:11) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
@jbarros thanks! Please try test4 at the same location.
@jbarros thanks, I'll prepare test5. Have a nice time at the beach!
@jbarros, test5 is now available, same location https://www.dropbox.com/sh/heg82sqvhpqb670/AAARGaD-zLptgnHj-PiqiwQBa?dl=0.
@Sotidii, please test these files too if you and your machine are free.
test3 , test4,test5 ==OK!
@sotidii thanks! test6 coming soon.
@sotidii please try the test6 file from the same location.
test6 =OK! -
Test 1 -OK
Test 2-OK
Test3-OK
Test4-OK
Test5-OK
Test6-OKm122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3+test6 (2021-08-21 13:29:44) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
Test7-OK -
test7=OK
