Solved Issues after prime
startGcode
M150 U255 P128 S60 ;LED gruen M150 R255 B235 U255 P128 S60 ;LED weiß G32 G29 S1 P"heightmap.csv" M83 G1 X5 Y5 Z30 F6000.0 G1 E50 F500 G1 E30 F200 G1 Y20 F2000 G1 Y50 Z0.2 F3000 G1 Y90 E20 F300 G1 Y120 F1200 M150 R255 B235 U255 P128 S60 ;LED weiß
endGcode
G10 P0 R0 S0 ; Set hotend temp to 0 M140 S0 ; Set bed temp to 0 G91 G1 Z10 G90 G92 E0 G1 E-1 F300 G92 E0 M106 S20 ; Fan to cool nozzle and bed M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M290 R0 S0 G1 X25 Y300 F6000 G1 E-9 F200 G92 E0 M300 S290 P1000 M150 U255 P128 S60 ;LED gruen G4 S60 ; wait 1 minute for nozzle to cool M107 ; turn off the fan G4 S30 M98 P"/macros/LED/LED_Aus" M18
@heartleander81 thanks! Do you have any tool change files on your system?
@dc42 no I don't have tool change file. The tool Board 1lc 1v1 is direkt conected to the duet6 6hc Board.
@dc42 in the last 2 file is only write M116 P0
@heartleander81 I am running the following file on my bench setup:
G90 M83 M302 P1 ;;dc T-1 ;;dc M106 S0 G4 S1 ;;dc ;;M140 S50 ;;M190 S50 ;;M104 S240 T0 ;;M109 S240 T0 T0 M98 P"startGcode" G92 E0.0 ; process CR3D 0.4 ; layer 1, Z = 0.200 T0 G1 E-0.6000 F1200 ; feature skirt ; tool H0.200 W0.440 G1 Z0.200 F600 G1 X118.950 Y122.494 F12600 ;G1 X19.489 Y53.567 F12600 ;G1 E0.6000 F1200 ;G1 X280.511 Y53.567 E8.9768 F1800 ; layer end T0 ;;dc M98 P"endGcode"
I don't see any problem. Does this cause the problem on your machine? Please note, I have modified it to do cold extrusion because my bench setup doesn't have any heaters connected. The Y movement shortly after the extruder prime move is quite fast (F12600), but is OK on my system after I increased the motor current.
I have put a single M116 P0 command n my tpre0.g and tpst0.g files, although of course it does nothing because I am not turning on any heaters.
yes it is my printer. After the conversion to the tool board, the error came after about 2 weeks. Then suddenly the error was gone for 2 prints and now it is permanent.I was able to observe once in the DWC that the extruder, although it is set to M83, turned from the 100mm extrusion to 0 and again to 100mm and then to 99.4mm built at the point where the retract G1 E-0.600 F1200 is, followed by the G1 XY Move. I'm trying to make a video of the DWC and extruder.
Ok my camera is to slow. I dount know what that is.
when I delete the first retract G1 E-0.600 F1200 the error is gone. But this is created by the slicer and I cannot prevent this.
@heartleander81 said in Issues after prime:
Just to be sure what slicer are you using?
@fcwilt Simplify3D . But 6 Montag runs All normal. And one of another Day was that problem
Well you can use a Post Processing command entered at the bottom of the Scripts page of S3D to remove that G1 command if you wish.
{STRIP "G1 E-0.600 F1200"}
@fcwilt but then all retract is delet G1 E-0.600 F1200 is my Filament retract
I wonder if the fast travel speeds are part of the issue? Have you checked your pulleys for a loose grub screw? With the high speed, accel, and jerk values maybe something is slipping?
Have you tried tamer values?
@phaedrux
Good point.
But I did that last week on the basis of maintenance when the error was pending.
This is still quite harmless for the design of the printer.
Others drive the printer with 6-8k acceleration and 300-400mm / s movementThe pulleyes All New.
I have test with M906 X1350 and Y1350.
My stepper have 1,7A Max.
And 60mm high. -
Can you enter your motor values and settings into this EMF calculator and see if maybe we're in the range where back emf becomes an issue.
@phaedrux Ok.
Oh I have Look on the wrong stepper. X and Y can 2.1A
That sounds similar to the reports from two other users: an axis move right after an extruder move on a tool boards shows the problem. I don't want you to remove the retractions, I want you to help me pin down the problem. by developing the simplest possible test case that causes the problem.
Did you try the test file I posted earlier?
@dc42 oh. No not. When my child sleep I can test it. In 15-30 min I give a feedback
should I use the g-code in the same way or turn the temperature on again and turn off cold extrusion?
@heartleander81 thanks. What I am looking for is the simplest possible test case. The ingredients that appear to cause it are:
- A tool change;
- A short extruder-only movement (typically a retraction), where the extruder is connected to a tool board;
- Then under some conditions, the following axis movement happens incorrectly.
The length of the extruder-only movement affects whether the problem occurs or not. I don't know whether the tool change is a necessary condition for the problem to happen, or if it is, whether the contents of the tool change files are relevant.
