12864 display (ST7920) on Duet 3 Mini5+
@diy-o-sphere the accelerometer is normally connected to the temperature daughter board connector. I think it should be possible to use the PanelDue connector instead, but I haven't tested that. It should work OK with the LCD card reader if the cables are short.
My pIan was, that by using IO.0 only one plug is required.
But it's just to play around.
I will buy the new toolboard as soon as it is available here.
Thanks for the announcement
I don't feel disadvantaged, quite the opposite. -
Hello i am in the process of making a small Production run based on @DIY-O-Sphere schematic. IT will be Board which will be directly olugged Into the Mini;)
Please upvote If you want one! -
The adapters are here and they work. I tested it with the classic Display, the BTT 35 and the BTT 70.
Please PN if you want one! You can choose between a plugin type or a "extension" one For plugin see the image above
@pcr how much is it?
@pcr not bad
@pcr Hi, adapters in compatible with mks mini12864 v2.1?
thanks -
@giannivox
If the LCD has a ST7567 chip, the adapter is not required. -
Does the adapter also work with a Duet2 Wifi (Ref. 1.04, Firmware 3.3)?
Thanks to the support of @pcr i was able to replace my prototype board.
Finally a clean wiring! -
Hello , just got adapterboards from PCR and I can not get things to work OK here.
Connected as below picture No shorts on 3-pin.; General preferences
M918 P1 E-4 F1999999
M575 P1 S0 B57600 ; enable support for PanelDue
M550 P"BigDelta" -
@tecno
As far as I can tell, the cables on the display are plugged in backwards. I think the noses on the plugs are under the cable and look upwards. But the noses must be above the white boxes. -
@DIY-O-Sphere
No go that way either. (Funny thing is that the display had the nose notches the other way! from factory)S O R R Y MY BAD Now working
@tecno
The jumper is only required to enable the sd-card reader. -
OK, what pins?
@tecno
For the Mini you can shorten CD_LCD and CD_D pin with the jumper. -
Just a information.
Have some left if somebody wants
