12864 display (ST7920) on Duet 3 Mini5+
The adapters are here and they work. I tested it with the classic Display, the BTT 35 and the BTT 70.
Please PN if you want one! You can choose between a plugin type or a "extension" one For plugin see the image above
@pcr how much is it?
@pcr not bad
@pcr Hi, adapters in compatible with mks mini12864 v2.1?
thanks -
@giannivox
If the LCD has a ST7567 chip, the adapter is not required. -
Does the adapter also work with a Duet2 Wifi (Ref. 1.04, Firmware 3.3)?
Thanks to the support of @pcr i was able to replace my prototype board.
Finally a clean wiring! -
Hello , just got adapterboards from PCR and I can not get things to work OK here.
Connected as below picture No shorts on 3-pin.; General preferences
M918 P1 E-4 F1999999
M575 P1 S0 B57600 ; enable support for PanelDue
M550 P"BigDelta" -
@tecno
As far as I can tell, the cables on the display are plugged in backwards. I think the noses on the plugs are under the cable and look upwards. But the noses must be above the white boxes. -
@DIY-O-Sphere
No go that way either. (Funny thing is that the display had the nose notches the other way! from factory)S O R R Y MY BAD Now working
@tecno
The jumper is only required to enable the sd-card reader. -
OK, what pins?
@tecno
For the Mini you can shorten CD_LCD and CD_D pin with the jumper. -
Just a information.
Have some left if somebody wants
@PCR I know this is old post, but if you have some left, I am interested
