[SBC] Version 3.4-b1 now available
We're happy to announce the first beta of v3.4 which brings accelerometer and generic file IO support to SBC mode. DWC remains basically the same as v3.3.0 except for preliminary Polish translations (thanks @Chri55). Please be aware that this beta remains experimental. New versions for SBC mode are now available (as always update via
apt update
/apt upgrade
once on the unstable package feed).Release notes are available as always for
Please be aware that this version brings no notable improvements for standalone users, although the Duet 3 binaries should remain functional in standalone mode. More improvements, in particular auto-resume on power loss, will follow in the next beta(s).
While attempting to upgrade, the installation is hanging at the following line:
The first time this happened I rebooted the PI4 and DSF had updated to 3.4-b1 but it did not update the firmware, was still showing 3.3 release. Firing an M999 would cause the whole system to hang and require a PI reboot in order for DCS to reconnect.
I was able to successfully downgrade back to 3.3 release. I have attempted the upgrade again and it hangs at the same place. I am usually running the latest betas to help test so this is no the first time I have been on the unstable package feed. Any thoughts moving forward?
Below is the log from: journalctl -u duetcontrolserver -e
pi@voron:~ $ journalctl -u duetcontrolserver -e Jul 10 17:32:25 voron DuetControlServer[3786]: [info] Environment initialized Jul 10 17:32:25 voron DuetControlServer[3786]: [warn] Incompatible firmware, ple Jul 10 17:32:25 voron DuetControlServer[3786]: [info] Connection to Duet establi Jul 10 17:32:25 voron DuetControlServer[3786]: [info] IPC socket created at /var Jul 10 17:32:26 voron systemd[1]: Started Duet Control Server. Jul 10 17:32:33 voron DuetControlServer[3786]: [info] Starting macro file daemon Jul 10 17:32:33 voron DuetControlServer[3786]: [warn] Daemon: Aborting orphaned Jul 10 17:32:33 voron DuetControlServer[3786]: [info] Aborted macro file daemon. Jul 10 17:32:34 voron DuetControlServer[3786]: [fatal] Abnormal program terminat Jul 10 17:32:34 voron DuetControlServer[3786]: [fatal] SPI task faulted Jul 10 17:32:34 voron DuetControlServer[3786]: System.NotSupportedException: Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDi Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDi Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.Model.Upd Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Inter Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Inter Jul 10 17:32:34 voron DuetControlServer[3786]: [fatal] SPI task faulted Jul 10 17:32:34 voron DuetControlServer[3786]: System.NotSupportedException: Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDi Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDi Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.Model.Upd Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Inter Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Inter lines 201-223/223 (END) Jul 10 17:32:25 voron DuetControlServer[3786]: [info] Environment initialized Jul 10 17:32:25 voron DuetControlServer[3786]: [warn] Incompatible firmware, please upgrade as soon as possible Jul 10 17:32:25 voron DuetControlServer[3786]: [info] Connection to Duet established Jul 10 17:32:25 voron DuetControlServer[3786]: [info] IPC socket created at /var/run/dsf/dcs.sock Jul 10 17:32:26 voron systemd[1]: Started Duet Control Server. Jul 10 17:32:33 voron DuetControlServer[3786]: [info] Starting macro file daemon.g on channel Daemon Jul 10 17:32:33 voron DuetControlServer[3786]: [warn] Daemon: Aborting orphaned macro file daemon.g Jul 10 17:32:33 voron DuetControlServer[3786]: [info] Aborted macro file daemon.g Jul 10 17:32:34 voron DuetControlServer[3786]: [fatal] Abnormal program termination Jul 10 17:32:34 voron DuetControlServer[3786]: [fatal] SPI task faulted Jul 10 17:32:34 voron DuetControlServer[3786]: System.NotSupportedException: Specified method is not supported. Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDictionary`1.Remove(String key) in /home/christ Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDictionary`1.Clear() in /home/christian/Duet3D/ Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.Model.Updater.ConnectionLost() in /home/christian/Duet Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Interface.Invalidate(String message) in /home/chri Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Interface.Run() in /home/christian/Duet3D/DuetSoft Jul 10 17:32:34 voron DuetControlServer[3786]: [fatal] SPI task faulted Jul 10 17:32:34 voron DuetControlServer[3786]: System.NotSupportedException: Specified method is not supported. Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDictionary`1.Remove(String key) in /home/christ Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetAPI.ObjectModel.ModelDictionary`1.Clear() in /home/christian/Duet3D/ Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.Model.Updater.ConnectionLost() in /home/christian/Duet Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Interface.Invalidate(String message) in /home/chri Jul 10 17:32:34 voron DuetControlServer[3786]: at DuetControlServer.SPI.Interface.Run() in /home/christian/Duet3D/DuetSoft lines 201-223/223 (END)
Edit: I should also include hardware: Pi4+6HC+3HC+1TL
I have just added the following list of known issues to the 3.4.0beta1 RRF release notes:
- If the slicer uses the M486 command to label objects in the GCode file, and there are more than 20 (Duet 2) or 40 (Duet 3) objects, then RRF crashes when printing the file. This bug is also present in release 3.2.x and 3.3.
- If you home any axes when workplace coordinates are in use, then any absolute moves in the homing files have workplace coordinate offsets applied; whereas they should not. This bug is also present in release 3.3.
- When M955 reports the configuration of an accelerometer that is connected to the main board using SPI, the orientation is always reported as 20 even if a different orientation has been selected (and is being used) by means of the M955 I parameter. This bug is also present in release 3.3.
- Sending a M956 command that refers to an accelerometer on a CAN-connected board via the Pi (e.g. from DWC) does not work and reports that the accelerometer was not found. Workaround: send the command to the Duet from a PanelDue or via USB instead.
@alex-cr Please share the full DCS logs, the stack traces are truncated (
journalctl --no-pager -e duetcontrolserver
should print everything). Once I get them, I'll be happy to fix it. Also note that M997 updates RRF while M999 resets it. -
This should be better. Sorry for the truncation initially.
Jul 11 13:22:31 voron DuetControlServer[390]: [info] Starting macro file daemon.g on channel Daemon Jul 11 13:22:32 voron DuetControlServer[390]: [info] Finished macro file daemon.g Jul 11 13:22:42 voron DuetControlServer[390]: [info] Starting macro file daemon.g on channel Daemon Jul 11 13:22:42 voron DuetControlServer[390]: [info] Finished macro file daemon.g Jul 11 13:22:52 voron DuetControlServer[390]: [info] Starting macro file daemon.g on channel Daemon Jul 11 13:22:52 voron DuetControlServer[390]: [info] Finished macro file daemon.g Jul 11 13:23:02 voron DuetControlServer[390]: [info] Starting macro file daemon.g on channel Daemon Jul 11 13:23:02 voron DuetControlServer[390]: [info] Finished macro file daemon.g Jul 11 13:23:12 voron DuetControlServer[390]: [info] Starting macro file daemon.g on channel Daemon Jul 11 13:23:12 voron DuetControlServer[390]: [info] Finished macro file daemon.g Jul 11 13:23:20 voron systemd[1]: Stopping Duet Control Server... Jul 11 13:23:20 voron DuetControlServer[390]: [warn] Received SIGTERM, shutting down... Jul 11 13:23:20 voron DuetControlServer[390]: [info] Application has shut down Jul 11 13:23:20 voron systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=143/n/a Jul 11 13:23:20 voron systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'. Jul 11 13:23:20 voron systemd[1]: Stopped Duet Control Server. Jul 11 13:23:37 voron systemd[1]: Starting Duet Control Server... Jul 11 13:23:37 voron DuetControlServer[9915]: Duet Control Server v3.4-b1 Jul 11 13:23:37 voron DuetControlServer[9915]: Written by Christian Hammacher for Duet3D Jul 11 13:23:37 voron DuetControlServer[9915]: Licensed under the terms of the GNU Public License Version 3 Jul 11 13:23:38 voron DuetControlServer[9915]: [info] Settings loaded Jul 11 13:23:38 voron DuetControlServer[9915]: [info] Environment initialized Jul 11 13:23:39 voron DuetControlServer[9915]: [warn] Incompatible firmware, please upgrade as soon as possible Jul 11 13:23:39 voron DuetControlServer[9915]: [info] Connection to Duet established Jul 11 13:23:39 voron DuetControlServer[9915]: [info] IPC socket created at /var/run/dsf/dcs.sock Jul 11 13:23:39 voron systemd[1]: Started Duet Control Server. Jul 11 13:23:44 voron DuetControlServer[9915]: [info] Starting macro file daemon.g on channel Daemon Jul 11 13:23:45 voron DuetControlServer[9915]: [info] Finished macro file daemon.g Jul 11 13:23:47 voron DuetControlServer[9915]: [fatal] Abnormal program termination Jul 11 13:23:47 voron DuetControlServer[9915]: [fatal] SPI task faulted Jul 11 13:23:47 voron DuetControlServer[9915]: System.NotSupportedException: Specified method is not supported. Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetAPI.ObjectModel.ModelDictionary`1.Remove(String key) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/Base/ModelDictionary.cs:line 377 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetAPI.ObjectModel.ModelDictionary`1.Clear() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/Base/ModelDictionary.cs:line 231 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetControlServer.Model.Updater.ConnectionLost() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 453 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetControlServer.SPI.Interface.Invalidate(String message) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1780 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetControlServer.SPI.Interface.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 783 Jul 11 13:23:47 voron DuetControlServer[9915]: [fatal] SPI task faulted Jul 11 13:23:47 voron DuetControlServer[9915]: System.NotSupportedException: Specified method is not supported. Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetAPI.ObjectModel.ModelDictionary`1.Remove(String key) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/Base/ModelDictionary.cs:line 377 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetAPI.ObjectModel.ModelDictionary`1.Clear() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/ObjectModel/Base/ModelDictionary.cs:line 231 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetControlServer.Model.Updater.ConnectionLost() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 453 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetControlServer.SPI.Interface.Invalidate(String message) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1780 Jul 11 13:23:47 voron DuetControlServer[9915]: at DuetControlServer.SPI.Interface.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 783
Also yes I have tried M997 and M999 after this issue. Both cause DCS to crash and then not allow a reconnect without a reboot of the PI.
@dc42 said in [SBC] Version 3.4-b1 now available:
- Sending a M955 command that refers to an accelerometer on a CAN-connected board via the Pi (e.g.rom DWC) does not work and report that the accelerometer was not found. Workaround: send the command to the Duet from a PanelDue or via USB instead.
In my case sending M955 from DWC works just fine -Duet3 +SBC
12.07.2021, 06:22:09 M955 P121.0 I41 Accelerometer 121:0 with orientation 41 samples at 1344Hz with 10-bit resolution
12.07.2021, 06:23:26 M122 B121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) Never used RAM 2680, free system stack 2762 words Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,57) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0% Last reset 00:08:33 ago, cause: VDD brownout Last software reset data not available Driver 0: position 0, 409.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 59923, writes 11, timeouts 0, DMA errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 0/4, peak Rx sync delay 216, resyncs 0/0, no step interrupt scheduled VIN: 24.9V MCU temperature: min 26.4C, current 42.8C, max 42.8C Ticks since heat task active 120, ADC conversions started 512757, completed 512755, timed out 0, errs 0 Last sensors broadcast 0x00000002 found 1 125 ticks ago, loop time 0 CAN messages queued 5914, send timeouts 0, received 4556, lost 0, free buffers 37, min 37, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer detected: yes, status: 00 I2C bus errors 0, naks 0, other errors 0
But when i tried to collect some data there is a problem:
12.07.2021, 06:25:44 G1 X-50 G4 S2 M956 P124.0 S1000 A0 G4 P10 G1 X50 F20000 Error: M956: Accelerometer not found
So, M955 works and there is a problem with M956?
Chris
@cadetc i believe this is a known issue that is being investigated
@jay_s_uk
Yes, the problem is known, I reported it earlier in another thread. This post is just to point out that in "list of known issues" there is talk about M955, where in my case everything is OK while there is no mention of M966 -
@cadetc said in [SBC] Version 3.4-b1 now available:
Correct. I have corrected the list of known issues.
@alex-cr Thanks, this problem is related to global variables and I've got a fix ready. To work-around this problem, start up your machine without any global variables and then upgrade the firmware. I've got a fix ready for M956, too.
Which beta will inverting PS_ON levels be included in? Thanks
@chrishamm said in [SBC] Version 3.4-b1 now available:
is this fix will be published soon?
@cadetc Yes, I hope I can do another prerelease on Thursday as I won't be available tomorrow.
@chrishamm hello, are there any news on the accelerometer not found error when using a toolboard v1.1 and sbc?
Kindly regards
Frederik -
Is there any change in accelerometer +SBC issue? First we hear that the problem is fixed, then that new firmware will be released on Thursday, and then there is silence and nothing happens.
It was released, but did not get announced here. Sorry about that.
https://github.com/Duet3D/DuetSoftwareFramework/releases/tag/v3.4-b1
@phaedrux said in [SBC] Version 3.4-b1 now available:
I think I may have misspoken, I know about version 3.4 b1, I even have it installed right after the release but there is a problem with the toolboard v1.1 +SBC . I described it above in this thread. Apparently the problem has been fixed and next prerelease was supposed to be released last Thursday
