Macros not showing on control page after updating from 1.24
@egon-net Did all the heater show up as well? I though that was a change in the PD firmware post 1.24 to show more heaters.
@nurgelrot said in Macros not showing on control page after updating from 1.24:
Yes, the very same config with all 4 heaters showing
@mfs12 Would be able to tell us the expected behavior.
@phaedrux i will have look into the and will be back.
Hey @Egon-Net,
The expected behavior is to display up 5 slots (either beds and/or other tools).
And i couldn't reproduce your issue. I tested differenct configurations using 2, 4, 5 and 6.
Only in case of 6 slots the macro buttons where hidden.
My PanelDue 7i with latest firmware also omits the macros (with 1 bed + 4 heaters).
@diamondback can you please share your configuration.
Ok, after adding another heater on a expansion board the macro buttons are not displayed anymore.
So i guess i can confirm the faulty behavior reported by @Diamondback and @Egon-Net.
Thanks for reporting and i will file a bug.
@mfs12 Ah nice. I'm using a Duet 2 Wifi + Duex 5 wit hvarious things connected to both of them, including two non heater PWM outputs.
@mfs12 said in Macros not showing on control page after updating from 1.24:
@Egon-Net can you test my configuration if this is working for you as well?
Here you have it. It shows weirdly...
Thank you very much!
Link to the github issue. Any development done on this topic will be reflected there.
Have also the same Problem with Duet2 + Exp.board, 1Bed, 4Printheads and Panel Due FW-Version 3.2.11 macros were not shown. Any progress there?
@philipp-r i could reproduce the issue. I hope to take care of that in the next release cycle. Check the gitlab issue. Any development concerning the problem is reflected there.
This post is deleted! -
Hey @egon-net, i think i could fix the problem you reported.
it would be really helpful if you could test it with your setup. I assume from your report you are using a PanelDue v3-7.0. So the image is exactly for that hardware. Looking forward to hear from you.
Thanks! I'll test it tomorrow morning and report!
@mfs12
Just updated, but PanelDue now does not connect... Do I have to do something else? -
@egon-net
Lowering to 57600 bauds connects, but still no macros buttons are shown. Updated also to 3.3.0 final, and got 115200 bauds working again, but also no macro buttons.
