Thermistor,PT100, PT1000
I believe understand I need RTD interface board with MAX31865 chip on the Duet 3 for the bed because the NTC 100K is in the silicone of bed.
And now in the rff config tool I need chose in the between this four elements.
But I don't know which chooses.
And For the toolboard I need one PT1000.
What do you think?
@auré pt100 are not supported on the toolboard. So it's either a standard thermistor or a pt1000
@jay_s_uk Hi Jay, thanks I bought a PT100 Daughter Board for the Duet 3 because the NTC 100K is in the silicone of Keenovo and I search a pt1000 for my extruder.
Do you know where to connect the PT100 Daughter Board on the Duet 3 ?
@auré Your bed (NTC 100k) and hot end (Semitec 104NT-4-R025H42G) temperature sensors are both thermistors, though slightly different. Both are supported by Duet and RepRapfirmware.
Use these settings for your bed thermistor:
M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
Settings for your hot end:
M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
You can change to a PT100 or PT1000 if you want, see this page for a comparison of temperature sensors: https://duet3d.dozuki.com/Wiki/Temperature_sensors
For a PT100 (which you don't have) you do need a daughterboard.Ian
@auré NTC 100K is a thermistor, NOT a PT100
@droftarts Thank you I test tomorrow If I can, and I tell you the result
Hello, so I have this on my config.g but the toolboard don't see the thermistor
M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 121.temp0
M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
M143 H1 S280 ; set temperature limit for heater 1 to 280CI have chek the thermistor with a multimeter and it's ok
I found this
I change a command line with:
M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8
But don't work
Can you send M115 and M115 B121 and confirm that the firmware version on both the mainboard and toolboard match?
@auré you're running out of sync firmware. Try running M997 B121
@jay_s_uk said in Thermistor,PT100, PT1000:
M997 B121
Ok I send M997 B121:
The thermistore not work
I would like stop the fan and I have new error:
For the fan I found this post
I add F1:
M563 P0 D0 H1 F0 F1 ; define tool 0
And now the fan control work.
But not the thermistor.I don't know why but now the thermistor on the toolboard work.....
I have only add F1
@auré post your full config and send M115 B121 to confirm 3.2.2 is on the toolboard
Looks like he is now.
Full config.g would be nice.
I post tomorrow the config.g thank you for your help good night
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 20:14:20 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"Duet 3" ; set printer name
M552 S1
M669 K1 ; select CoreXY mode; Drives
G4 S1 ;wait for expansion boards to start
M569 P0.0 S0 ; physical drive 0.0 goes forwards
M569 P0.1 S0 ; physical drive 0.1 goes forwards
M569 P0.3 S0 ; physical drive 0.3 goes forwards
M569 P0.4 S0 ; physical drive 0.4 goes forwards
M569 P0.5 S0 ; physical drive 0.5 goes forwards
M569 P121.0 S1 ; physical drive 121.0 goes forwards
M584 X0.0 Y0.1 Z0.3:0.4:0.5 E121.0 ; set drive mapping
M671 X-30,109:171.1:372.309 Y-10,413:367,797:-10,413 S50
M92 X160.00 Y160.00 Z800.00 E335.40 ; set steps per mm
M566 X1200.00 Y1200.00 Z30.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z1800.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1600.00 Y1600.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1200 E840 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X365 Y365 Z335 S0 ; set axis maxima; Endstops
M574 X1 S1 P"121.io1.in" ; configure active-high endstop for low end on X via pin 121.io1.in
M574 Y1 S1 P"io0.in" ; configure active-high endstop for low end on Y via pin io0.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"^121.io0.in" H15 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X3 Y-41 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@auré said in Thermistor,PT100, PT1000:
G4 S1 ;wait for expansion boards to startcan you try increasing the G4 S1 to G4 S4 to give it a bit longer for the toolboard to be ready?
Yes thank you, I told myself that I had to extend the time because when I start the printer with DWC open, sometimes I have error communication of bus, but I forgot.
I think you're right 4 second it's ok.
