E 3d BIGBOX Duel head
Hi @testpro, thanks for choosing Duet!
Here are some resources to get you started:
The online configuration generator at https://configtool.reprapfirmware.org/Start. This can generate a basic single-head configuration file and homing files for you. I suggest you use it to generate configuration and homing files using the left head only, and get the machine working using just the left head, with the right head parked at the right endstop switch.
When that's working, look at https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian. This will tell you how to change the configuration files to use the second print head, how to write the homing file for the right hand print head, and how to set up tools for ditto printing and mirror printing.
Hint: ditto and mirror printing are easiest to set up if you choose X=0 Y=0 to be at the centre of the bed.
If you have any problems making sense of those pages, ask here.
Not to discourage you from posting here or anything, but there's also the E3D big box forums that may prove helpful to you.
@testpro
If your printer actually has independent X-axes, the DuetWiFi will not have enough onboard stepper drivers. You might need the DUEX5 extension board, too? -
@dc42 Hay thank you. I just got the parts in and have the duet2 up and running after connecting to pc and doing a firmware update. i also have the 7" touch screen attached and working. Now it is down to wiring up the board and swapping it out.
the setting up one head head first then the second is a good idea. after i get it wired up and in i will be taking you up on the suggestions above. thanks
@phaedrux Thanks i did not realize that. there is a ton of info out there and it can get confusing.
@o_lampe
hello well if Y axis is front and back and X is left to right and standing in front of printer my X axis has 2 extruders attached together driven on to chrome bars with a cog belt. so i am going to say no not separate independent x axis but to extruder heads sharing same the same axis if that makes since. I believe there are just enough on the duet with 5 to get me there. -
@testpro there’s a long thread here https://forum.duet3d.com/topic/17995/unable-to-home-z-axis/76?_=1620854071811 with some example config files for a single extruder bigbox, which may help. Read the thread, but use the files from the end, they are the latest and correct ones, at least for that machine.
@testpro said in E 3d BIGBOX Duel head:
@o_lampe
hello well if Y axis is front and back and X is left to right and standing in front of printer my X axis has 2 extruders attached together driven on to chrome bars with a cog belt. so i am going to say no not separate independent x axis but to extruder heads sharing same the same axis if that makes since. I believe there are just enough on the duet with 5 to get me there.Correct, if the two extruders are on the same carriage then you have enough stepper drivers on the Duet. Some users converted their BigBox machines to IDEX but that was not an E3D product.
@dc42 hello ok i have got the duet 2 board and have it communicating with the PC. So i then wired up the board and everything is working as far as i can tell but when i go to configure as you suggested above and go through the steps to make a file for the printer and it gives me a zip file. i then have the zip file and upload under system then file and system files upload then the control software telling only one file can be read?
i then go to the dash board page and tell x to home and or Y to home the z motors act like they want to move and the x and y steppers are doing nothing? the program is also telling me the Failed to enable end stops.i have got to have something wrong.
@testpro ok after playing some and restarting the printer i can get the x and y axis to home somewhat.
the x home will make the extruder head move from right to left and the y axis from front of printer to back of printer. but once x homes and then i tell y to home the extruder moves from back of printer to front of printer and the extruder bounces trying to go left.I know this is not right i have something backwards but i know the wiring is correct i have checked it twice. i also think the end stop for x is not working properly either due to bouncing but no sure.
Can you post your config.g and homing files?
@phaedrux i will have to figure out how to do that. they can be exported to excel right?
@testpro in the mean time can you tell me how to check the sensor used on the z axis is good or not, the z axis will not home but it will run up to extruder and beyond it you allow it., so i do not if it bad or i have a bad setting.
@testpro config g file
; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue May 25 2021 18:51:26 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"big 3d box 1" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X5 Y5 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@testpro
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-235 Y-215 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-235 ; home X axis
G1 H1 Y-215 ; home Y axis
G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-215 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G1 X10 Y10 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-215 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X10 Y10 F6000 ; go to first probe point
;G90 ; absolute positioning -
Not exactly sure what you mean. What kind of probe is it? How is it wired?
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
@phaedrux
the Z sensor is what came with the printer but i have found the problem and now it works.i have been working on things and here is where i am at now with the printer.
X axis will home by moving to the left (from front of machine) after double bump on end stop
Y axis will home by moving to front of printer but this makes the X axis bounce in its end stop until Y reaches its end stop. this can not be right? can it?
Z axis will home after i flipped the wires so it runs in the up direction and not down.
the bed reads the correct temperature and it does heat but the program stops it from heating saying it is not heating up fast enough. there is a setting for this i assume?
So need to figure out Y axis home issue and heater faulting out because of not heating fast enough.
thank you for your response above it helped me figure out the sensor issue.
any suggettions on these issues?
Not sure what you mean by this. Can you show a video?
You'll need to PID tune the heater.
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control -
@phaedrux Getting a video file small enough to upload is a problem at this point.
basically i home x and the carriage goes to the left in the X direction but the Y direction is going to the back of the machine.
Now X is homed and then tell y to home and y moves to the front of the machine and the carriage is bouncing off the X end stop and makes the whole shake until Y hits its end stop on front of machine.
i will try video again
@testpro [0_1622156296017_MAH00089.avi](Uploading 100%)
vidoe shows the shacking or skipping going on while homing to Y.
