[DSF Extension] Exec On MCode (was: Shutdown SBC)
@wilriker at what point in the bootup cycle is execonmcode ready? I created a custom mCode that I'd like to call at the beginning of config.g, but it says it's unsupported. If I call it separately, or at the very end of config.g, it works correctly.
Any thoughts?
@oozebot I think that primarily this depends on when execonmcode is started relative to startup of DCS. Or maybe DCS will even delay accepting API clients until a certain amount of startup tasks have been processed. @chrishamm should be able to give more insights on that.
@wilriker If ExecOnMCode is installed as a DSF plugin (will be officially supported in 3.3), it's started by DuetPluginService which is started by multi-user.target. Note that v3.3 will introduce
/sys/dsf-config.g
as well which is executed as soon as all the enabled plugins have been started.Previously plugins were started by DCS, so by basic.target AFAIR.
@oozeBot Either move your custom codes to
dsf-config.g
if you're on pre-3.3 and/or add a delay to the end of your config file to make sure ExecOnMCode has been fully started before they're executed. -
@chrishamm @wilriker - thank you both. We are just about to begin testing the 3.3 betas. This may need to be postponed until after it is released.
@chrishamm As of right now ExecOnMCode is a simple API client just connecting to the socket. It is not yet converted to an official plugin. It will be started by a user-provided systemd unit (or arbitrary other means) completely independent of DCS.
@wilriker
I once wrote you a PM in German. because I don't know if you understand what I am writing via google translator@All
I would like to send an http command using the Mxxxx command.Let's assume I've installed everything as shown in the video linked here.
What do I have to enter where and how around this line:
http://IP.Adrresse.Of.Shelly/relay/0?turn=off
to be able to send?
P.S or edit or next step
i installed the ExecOnMCode with help of the two videos. but the shutdown (poweroff) with M7722 don't work for me.
The Service is running:
but in DWC i see this message:
M7722
Warning: M7722: Command is not supportedAnd the Raspi is still working/running.
On Terminal (connected with Raspi) i see:
pi@CCC:~ $
2021/05/18 22:24:53 Connection to DCS closed
2021/05/18 22:24:53 EOF
pi@CCC:~ $ -
@crazycreator So, if you want to make a simple HTTP/GET call I'd say you need a
cURL
orwget
command:execonmcode -mCode 1234 -command 'wget -O /dev/null "http://IP.Adrresse.Of.Shelly/relay/0?turn=off"'
If you want to put that into the
ExecStart
line of a systemd unit you have to deal with systemd's escaping syntax. That will be a bit ugly but doable. Otherwise you could move thewget
call into a simple bash-script and call that - one foron
and one foroff
Ok .. sounds good.
But actually the script is not running correct ... the error popup on web-gui is the only reaction when I send M7722. The Raspi don't shut down or restart after this M7722 command.
the terminal show what you see on my terminal screen in my last posting
pi@CCC:/usr/local/bin $ sudo ./execonmcode -mCode 7722 -command "poweroff"
2021/05/19 20:47:59 Connection to DCS closed
2021/05/19 20:47:59 EOFI think that's the problem. But i have no idea how to fix this.
I did the installation exactly as shown in the video. -
nobody answer me?
when i try the command in terminal, connected with the Pi, with additional parameter
i see this outputpi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace 2021/05/20 15:54:21 7722: poweroff 2021/05/20 15:54:21 [DEBUG] <Recv> {"version":11,"id":20} 2021/05/20 15:54:21 [DEBUG] <Send> {"Mode":"Intercept","Version":7,"InterceptionMode":"Pre"} 2021/05/20 15:54:21 [DEBUG] <Recv> {"success":true} 2021/05/20 15:54:21 [DEBUG] <Connect> Connection established
but the Pi don't reboot or shut down ... no reaction
on dwc the same ... no reaction -
@crazycreator Can you check if the command
poweroff
does work on your system in the first place?Also please check
execonmcode
version (parameter-version
). It looks to me as if you are using an older version. -
@wilriker said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
Can you check if the command poweroff does work on your system in the first place?
How can i do this?
Also please check execonmcode version (parameter -version). It looks to me as if you are using an older version.
pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version 2021/05/20 16:20:43 0x24142bc pi@CCC:~ $
@crazycreator said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
How can i do this?
Run
sudo poweroff
and check what that does.pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version 2021/05/20 16:20:43 0x24142bc pi@CCC:~ $
That looks like a bug in previous version and it may be that DCS is rejecting this client. Please get the version 5.2.0 of
execonmcode
from GitHub and try again. -
@wilriker I used 5.1 so that I could imitate the tutorial 100%. now I'm back on 5.2
sudo poweroff
pi@CCC:~ $ sudo poweroff Connection to ccc.local closed by remote host. Connection to ccc.local closed.
Versionscheck
pi@CCC:~ $ sudo /usr/local/bin/execonmcode --version 5.2.0
Debug and Trace
pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command -poweroff -debug -trace 2021/05/20 16:35:27 7722: -poweroff 2021/05/20 16:35:27 [DEBUG] <Recv> {"version":11,"id":21} 2021/05/20 16:35:27 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false} 2021/05/20 16:35:27 [DEBUG] <Recv> {"success":true} 2021/05/20 16:35:27 [DEBUG] <Connect> Connection established
put the M7722 command in DWC Console ... show me this in terminal
2021/05/20 16:35:58 Connection to DCS closed 2021/05/20 16:35:58 [DEBUG] <Close> Closing connection 2021/05/20 16:35:58 EOF
At least this time you used
-poweroff
which most likely is not a valid command. -
@wilriker
but in shutdownsbc.service is used and in the video tutorial too.What should I write / use that instead?
What else can I try to get the script to work?
@crazycreator Just remove the dash from the start of
poweroff
then it should work. -
@wilriker
you mean so:pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace 2021/05/20 18:47:03 7722: poweroff 2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80} 2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false} 2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true} 2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
@wilriker
When I send M7722 in the DWC Console I get the familiar popup with the message:
M7722
Warning: M7722: Command is not supportedBut the Raspberry does not switch off or restarts!
When I send the M7722 command in the DWC console, I see the following lines in the terminal:
2021/05/20 18:47:47 Connection to DCS closed 2021/05/20 18:47:47 [DEBUG] <Close> Closing connection 2021/05/20 18:47:47 EOF
@crazycreator One note that I've found is that when rebooting or powering off the SBC from a custom mCode, DCW will report "Command not supported" as the API immediately shuts down. See this thread:
@oozebot
thanks for the hint. I've already read that while looking for a solution to my problem.if execonmcode would run, then the message would be pretty irrelevant to me;) ... but unfortunately I can't do that
