Homing X, Y, Z disconnects the Duet 3 3.3RC1 SBC
@phaedrux
But it does work ... All end stops react correctly.
From the PanelDue display I can use the Home X, Home y and Home Z as normal.
When I insert the SD card into the MB6HC, the homing from DWC also works too.
Only when I use the Raspberry does it not work.
Do you think that is really because the Z motors are on the 3HC and the EndStops are on the MB6HC?Then I'll have to rebuild it this afternoon.
I already used a different config for testing ... the one from the jubilee printer.
There were X, Y and 3xZ connected to the 6HC, but I had the same problem ...But I'll try again anyway
@crazycreator, I suspect that you have hit a known issue with a stack size in 3.3RC1. Please upgrade RRF to the 3.3RC1+1 binary at https://www.dropbox.com/sh/dlb58vkmu1u4fkx/AAAelkXSfRKVwI6_yqRnhGHPa?dl=0.
I upload the files per DWC on my Webbrowser
Duet3Firmware_MB6HC.bin
Duet3_SBCiap32_MB6HC.bin
Duet3_SDiap32_MB6HC.binNow the MB6HC is on Version 3.3RC1+1 but the 3HC on 3.3RC1
I can now X and Y home ... but after the click it will take 10-15 seconds for the printer to start moving.
when i press home z nothing happens. no error message and no movement only the "busy" status.Without testing Homing ....
X and Y continue to work and moving
The Z axis can no longer be moved -
@crazycreator said in Homing X, Y, Z disconnects the Duet 3 3.3RC1 SBC:
That is correct.
when i press home z nothing happens. no error message and no movement only the "busy" status.That is not right. Please do the following:
Send M122 P1004. The main board will reset.
When it connects again, home X and Y again. When that has completed, run M122 and post the report here.
We expect to release 3.3RC2 later today, so you may wish to wait and test with that version.
i went down to 3.2.2 and everything works fine.If you say there is a new release today then I'll wait for it and report here.
P.S. After installing your RC1 + 1, I restarted the entire system ... So it was de-energized.
I think this does the same thing as M122 P1004, right? -
@crazycreator I have this exact same issue. I have to restart the duetcontrolserver process on the pi to bring it back.
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sat Jan 09 2021 15:21:32 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Voron2" ; set printer name M669 K1 ; select CoreXY mode ; Drives M569 P0.0 S0 D2 ; physical drive 0.0 goes backwards M569 P0.1 S1 D2 ; physical drive 0.1 goes forwards M569 P0.2 S1 D2 ; physical drive 0.2 goes forwards M569 P0.3 S0 D2 ; physical drive 0.3 goes backwards M569 P0.4 S1 D2 ; physical drive 0.4 goes forwards M569 P0.5 S0 D2 ; physical drive 0.5 goes backwards M569 P1.0 S1 D2 ; physical drive 1.0 goes forwards M584 X0.1 Y0.0 Z0.2:0.3:0.4:0.5 E1.0 ; set drive mapping M671 X-50:-50:350:350 Y0:375:375:0 S2 ; Z Lead Screw Leveling probe Point Mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z400.00 E415.00 ; set steps per mm M566 X720.00 Y720.00 Z100.00 E4000.00 ; set maximum instantaneous speed changes (mm/min) AKA Jerk M203 X16800.00 Y16800.00 Z720.00 E6000.00 ; set maximum speeds (mm/min) M201 X2500.00 Y2500.00 Z250.00 E4000.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 E800 I40 ; set motor currents (mA)and motor idle factor in per cent M906 Z1400 I60 ; set motor currents (mA)and motor idle factor in per cent M84 S60 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X300 Y300 Z250 S0 ; set axis maxima ; Endstops M574 X1 S3 ; configure sensorless endstop for low end on X M574 Y1 S3 ; configure sensorless endstop for low end on Y M574 Z1 S2 ; configure Z-probe endstop for low end on Z M915 X Y S3 F0 R0 H400 ; configure stall detection for X and Y sensorless homing ; Z-Probe ;M950 S0 C"0.io7.out" ; create servo pin 0 for BLTouch ;M558 P9 C"0.io4.in" H3 F340 R0.2 T14400 ; set Z probe type to BLTouch and the dive height + speeds M558 P5 C"0.^io7.in" H2 F1200 T16800 A3 ; PINDA G31 P100 X0 Y21 Z1.37 ; set Z probe trigger value, offset and trigger height M557 X20:280 Y30:270 P4 ; Define mesh grid ; Bed Heater M308 S0 P"0.temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"0.out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S0.6 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ; Nozzle Heater M308 S1 P"1.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 1.temp0 M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"0.out4" Q10 ; create fan 0 on pin out4 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"0.out5" Q10 ; create fan 1 on pin out5 and set its frequency M106 P1 S0.8 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Case Fans M950 F2 C"0.out7" Q10 ; create fan 2 on pin out7 and set its frequency M106 P2 S0.4 C"Case Fan 1" M950 F3 C"0.out8" Q10 M106 P3 S0.4 C"Case Fan 2" M950 F4 C"0.out9" Q10 M106 P4 S0 C"Exhaust Fan" ; Tools M563 P0 S"Extruder" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous ;M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory T0 ; select first tool
@ctilley79 strangely enough. Home all works, and it calls the x y z macros with M98 and works fine.
@ctilley79 I will now wait for the release today, as recommended by @dc42 .
Then we see if it works and if not then @dc42 can continue to do magic -
3.3 RC2 is now available: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3RC2
@phaedrux Has it hit the package servers yet? I'm not seeing it. For clarification, if you're using SBC, you cannot update the board firmware via uploading in DWC correct? DuetSoftwareFramework has to be updated before every release?
@phaedrux Ok. It hit. RC2 Solved this issue for me. How about you @CrazyCreator?
It works
