3.0 Heater/Fan configuration
@phaedrux @phaedrux This isn't from the printer in question, but here is where FAN2 will appear. It's not there when the machine first boots up and the fan turns on when the hot end temp exceeds 40C. I haven't done enough to know exactly when FAN2 shows up, but when it does it seems the fan no longer responds to the hot-end temperature.
The tool fan slider will control the fan of the currently selected tool.
@phaedrux FAN2 is the issue. That's the fan on the hot end. How do I prevent that from showing up on DWC? It should only be temperature controlled from the extruder heater.
Is you DWC also updated to 3.2.2?
@zemlin said in 3.0 Heater/Fan configuration:
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H1 T40 ; set fan 2 value. Thermostatic control is turned onI can only remember darkly, but I think RRF3 once had a problem when the channels are not filled in ascending order.
I would suggest to rename the 2nd fan to F1 and channel to P1 -
@diy-o-sphere said in 3.0 Heater/Fan configuration:
That would make more sense. Fan1 is the recommended port for heatsink fan.
@phaedrux I did not take separate action to update DWC - just dropped the big firmware zip in the system folder. If DWC requires a separate update, I will do that.
@diy-o-sphere
I did not wire the machine. Will poke my head in the control box to confirm how things are wired and if I might need to switch a couple cables. -
M106 P2 S1 H1 T40 ; set fan 2 value. Thermostatic control is turned onWith RRF3, the wiring doesn't need to be changed.
Change the config toM950 F1 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P1 S1 H1 T40 ; set fan 2 value. Thermostatic control is turned on
Normally uploading the full zip should update everything, but if you are using a very old version it might not get picked up I guess.
You can try uploading the DWC zip file by itself and if that doesn't work, use that zip file to replace the contents of the /www folder on the SD card manually.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
I'm not exactly sure what triggers the change, but when I went to run a part, the hot-end fan doesn't start up - but in the Dashboard Fan2 appears, and the slider appears to override the thermostatic control and the fan doesn't run.
By "run a part", do you mean run a print job from SD card? If so, then perhaps something in the print job is reconfiguring the fan - in which case, please share the print file.
I really appreciate all the help.
I changed the can lines per @DIY-O-Sphere toM950 F1 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P1 S1 H1 T40 ; set fan 2 value. Thermostatic control is turned on
Functioning properly and not showing up on the dashboard slider.
The Z-Probe on this machine is accelerometer-based and that's a little flaky, but doesn't seem to be software related.Up and running now, so 'til next time ...
