Bl touch "already triggered at the start of the probing move''
@grahamexp Remove the ! from the io7.in, if you put that in there. Sounds like the BLTouch's endstop connection isn't working as expected.
Here's my Z prode section of config.g, for my Duet 3 6HC w/Pi4 nad 1LC. The BLTouch is on the 1LC.
M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"^121.io0.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds -
@stephen6309 I removed the ! after the failed attempt already. Yesterday I had asked for help moving the one pin from the 26 pin connector. There was a suggestion that I simply unplug it as the second ground was not needed. I did this and it worked for the next Z homing. I suspect that the advice was not correct and may ne teh cause of my current problem. I have put the black wire back on pin 6 (ground) as it was in the hope that would correct the issue but it did not.
@grahamexp I used the wiring at https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3. Both grounds are connected together to the connectors ground. (I07 GND)
@stephen6309 yea I think I am also going to follow that approach. ''BL touch and Rasberry Pi at the same time?'' was the help from yesterday.
@grahamexp is there a way to reset the BL touch and see if that doesn't fix this
@grahamexp try a
M280 Pxxx S160
or
M280 Pxxx S60
I changed my retractprobe.g to
M280 P10 S90 G4 P200 M280 P10 S160
yesterday due to issues with a 3DTouch
The BLTouch has a command to clear and faults and reset the pin, but that's the same as powering it on.
The original error of it saying it's triggered at the start of the move means it was picking up the triggered signal on the white wire. So either there is a problem with the wiring on the white wire, or it's picking up some interference.
I'm not sure why they include two ground wires on the BLtouch, but I figure it must have been for a reason, so I connect both.
@stephen6309 said in Bl touch "already triggered at the start of the probing move'':
M558 P9 C"^121.io0.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speedsI have pretty much the same setup except with a Mini 5+ and the BLTouch is constantly going into error mode when probing. Aside from doing what @Marshal did to cancel the error every time I'm out of ideas. My config is the same and the wiring looks right. IDK! Maybe it's the Toolboard1LC. I did notice that my BLTouch is mounted at a very slight angle (maybe 5 degrees) but I wouldn't think that would cause a problem since it's stable.
@grahamexp said in Bl touch "already triggered at the start of the probing move'':
As the heading says I am getting an error when I try to home Z. The probe deploys and then retracts immediately and gives the error. It was working perfectly well yesterday and I have not changed any settings for the BL touch. No idea where how to solve this.
If you haven't changed anything, then most likely the white wire connected to io7.in isn't making good contact.
You should not enable the pullup resistor on io7.in because it already has a permanent pullup resistor, and enabling the internal one as well reduces the noise margin.
@dc42 Thanks for the additional info. Ok so how do I disable the internal pullup resistor? I have checked the white wire for a loose connection, cant find one. Resistance across the wire lead is same as the other pins when I check with my meter (1.6 ohms for white, brown, orange and yellow).
@grahamexp Weird, I removed the white and black wires from the plug on the bl touch end to check the crimps. Found no issue with the crimp. Then checked the plug on the duet end, again found no issue with the crimp. Put it all back together and switched on and now it works again. My testing the leads resistance didn't show any breaks or poor connections either. I am at a loss to explain this inconsistent behavior unless it is that internal pullup resistor.
