help for beginners
@sergei It won't be included until the next release. At the moment, I don't think there is any development going on, and no release is planned, so it may be some time before it gets included.
Unfortunately, I don't have the development environment set up (I'm not a programmer), so I can't compile it for you.
I can probably find time to integrate your translation and produce a binary for you to test.
that would be very good. if you do it
Hey @sergei, i would like to integrate the russian translation, can you send it to me?
Yes. you need a file called Strings.hpp ?
@sergei if you have it, this would be the easiest.
Yes, I have it ready. you just need to build the firmware. Will you send me the finished one later?
@sergei not sure if i will make it today.
which device do you have?
did you do a pull request on github? or how can you provide the file?
I have a touch screen panel duet 4.3
send your mail. i will send you a file
please upload it here. don't wanna post my email address publicly.
this file format is not loaded here. it is not supported
@sergei put .txt on the end, it should upload.
@sergei just rename it to .zip and upload it here. Anyone who downloads it can just rename it back to .hpp to use
EDIT: looks like @droftarts beat me to it
не получается отправить . не даёт это сделать
@sergei sorry, i am just starting to get into this.
other easy way is to paste it at https://pastebin.com/ and share the link here. this should work...
hpp file should work now as well. so you can try uploading the hpp file again.
Hello . You were adding Russian to the duet panel
@sergei I added the provided translation. Please check your email.
