Solved Duet 3 Mini 5+ VIN under-voltage issues in SBC mode
@Serbitar said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
"Warning: VIN under-voltage event (0.0V)"
Where are you seeing that errors?
What does your VIN connector look like?
The error is in the DWC console tab and in the logfile written to the card.
2021-03-09 16:32:07 Print auto-paused due to low voltage 2021-03-09 16:32:07 Warning: VIN under-voltage event (0.0V)
Cable to the power supply is 14AWG silicone cable with fork terminals on each end. Firmly bolted to the barrier strips on both the PSU and the controller.
I replaced the cables when I installed the new power supply because the previous ones were not long enough. -
Thanks. Looking into it.
I should have said, that when i run this in standalone mode I don't see the under-voltage warnings.
Thanks for that information, it's very useful. I have one other report of spurious under-voltage readings from a Duet 3 Mini, also in SBC mode.
Can you provide a photo showing the Duet, the Pi and the wiring?
Its all a bit of a mess due to the investigations... Power supply and controller are on opposite sides of the printer currently. Approx 50cm cable length in the main power cables.
Terminals on the psu from centre outwards are:
Controller, 10000uF capacitor, LED lighting.Capacitor was added as part of the investigations when i thought I was possibly suffering from mains failures. Ideally i would put it at the controller end of the cable run. LED lighting was not connected until late this afternoon (after the log messages i shared earlier).
Let me know if these aren't quite what you are looking for, I can probably shuffle things around tomorrow to give more context if necessary.
Thanks for your help!
I have been printing smaller parts for the last few days (<4h) and no power issues until running a longer job over night (24h).
Woke up to find the job was paused during a nozzle swap.
Mar 16 06:30:13 ender3 DuetControlServer[820]: [info] Print auto-paused due to low voltage Mar 16 06:30:13 ender3 DuetControlServer[820]: [warn] VIN under-voltage event (0.0V)
SBC however didn't loose power
root@smalldeprinter ~ # uptime 08:53:25 up 1 day, 11 min, 1 user, load average: 0.10, 0.08, 0.08
Nor did anything else in the house.
Better photo including all the power wiring:
The smaller power supply at the top of the photo is currently completely disconnected.
Another occurrence over night.
Is there anything I can do to contribute to investigation? If not I'm going to go back to standalone mode.m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (SBC mode) Board ID: W4ZW4-V296U-D65J0-40KM0-LR03Z-H6928 Used output buffers: 1 of 40 (30 max) === RTOS === Static ram: 98732 Dynamic ram: 100676 of which 60 recycled Never used RAM 45748, free system stack 126 words Tasks: Linux(ready,83) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,106) MAIN(running,380) IDLE(ready,20) AIN(blocked,262) Owned mutexes: HTTP(MAIN) === Platform === Last reset 09:35:39 ago, cause: software Last software reset at 2021-03-16 23:02, reason: User, none spinning, available RAM 46164, slot 2 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 Supply voltage: min 0.0, current 24.1, max 25.3, under voltage events: 505, over voltage events: 0, power good: yes Driver 0: position -1155, standstill, SG min/max 0/0, read errors 0, write errors 23, ifcnt 243, reads 41867, writes 4545, timeouts 7, DMA errors 0, failedOp 0x01 Driver 1: position -2187, standstill, SG min/max 0/44, read errors 0, write errors 23, ifcnt 79, reads 41848, writes 4545, timeouts 2, DMA errors 0, failedOp 0x71 Driver 2: position 9535, standstill, SG min/max 0/66, read errors 1, write errors 23, ifcnt 79, reads 41831, writes 4545, timeouts 3, DMA errors 0, failedOp 0x6a Driver 3: position 0, standstill, SG min/max 0/46, read errors 0, write errors 20, ifcnt 242, reads 41574, writes 4546, timeouts 5, DMA errors 0, failedOp 0x72 Driver 4: position 0, standstill, SG min/max 0/298, read errors 2, write errors 22, ifcnt 57, reads 41858, writes 4546, timeouts 5, DMA errors 0, failedOp 0x71 Driver 5: position 0, standstill, SG min/max 0/2, read errors 1, write errors 16, ifcnt 242, reads 41847, writes 4545, timeouts 3, DMA errors 0, failedOp 0x80 Driver 6: position 0, standstill, SG min/max 0/2, read errors 0, write errors 16, ifcnt 242, reads 41630, writes 4545, timeouts 30, DMA errors 0, failedOp 0x6f Date/time: 2021-03-17 08:38:39 Cache data hit count 4294967295 Slowest loop: 4.77ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 108660, completed moves 108660, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.0 Heater 2 is on, I-accum = 0.4 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X29.985001 Y-4.522000 E0.322590" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0 sensor: ok Extruder 1 sensor: ok === CAN === Messages queued 194722, send timeouts 194722, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16 === SBC interface === State: 4, failed transfers: 0 Last transfer: 5ms ago RX/TX seq numbers: 23696/23696 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x10eec Buffer RX/TX: 1464/2272-0 === Duet Control Server === Duet Control Server v3.2.2 File: Buffered code: G1 X29.985 Y-4.522 E0.32259 Buffered code: G1 X29.967 Y-5.211 F9000.000 Buffered code: G1 F1800.000 Buffered code: G1 X29.940 Y-5.511 E0.00858 Buffered code: G1 X29.914 Y-5.812 E0.00763 Buffered code: G1 X29.892 Y-6.011 E0.00444 Buffered code: G1 X29.871 Y-6.211 E0.00373 Buffered code: G1 X29.849 Y-6.410 E0.00302 Buffered code: G1 X29.827 Y-6.609 E0.00232 Buffered code: G1 X29.805 Y-6.809 E0.00161 Buffered code: G10 ; retract Buffered code: G1 X29.967 Y5.211 F9000.000 Buffered code: G11 ; unretract Buffered code: G1 F1800.000 Buffered code: G1 X29.940 Y5.511 E0.00858 Buffered code: G1 X29.914 Y5.812 E0.00763 Buffered code: G1 X29.892 Y6.011 E0.00444 Buffered code: G1 X29.871 Y6.211 E0.00373 Buffered code: G1 X29.849 Y6.410 E0.00302 ==> 800 bytes Code buffer space: 1824 Configured SPI speed: 8000000 Hz Full transfers per second: 36.74 Maximum length of RX/TX data transfers: 3777/1612 File /opt/dsf/sd/gcodes/stripyegg1_0.2mm_PLA_ENDER3_9h33m.gcode is selected, processing
Log looks a bit different this time! I added m122 to the power fail actions.
M911 S21 R23 P"M122 M913 X0 Y0; G10 P0 R0 S0 G10 P1 R0 S0 G91 M83 G1 Z3 E-5 F10000" ; set voltage thresholds and actions to run on power loss
2021-03-16 23:03:28 Error: G0/G1: insufficient axes homed 2021-03-17 02:38:04 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (SBC mode) Board ID: W4ZW4-V296U-D65J0-40KM0-LR03Z-H6928 Used output buffers: 2 of 40 (13 max) === RTOS === Static ram: 98732 Dynamic ram: 100676 of which 60 recycled Never used RAM 45748, free system stack 126 words Tasks: Linux(ready,99) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,362) TMC(blocked,106) MAIN(running,388) IDLE(ready,20) AIN(blocked,262) Owned mutexes: Autopause(MAIN) === Platform === Last reset 03:35:03 ago, cause: software Last software reset at 2021-03-16 23:02, reason: User, none spinning, available RAM 46164, slot 2 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 Supply voltage: min 0.0, current 20.9, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position -1155, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 139, reads 11001, writes 12, timeouts 8, DMA errors 0, failedOp 0x72 Driver 1: position -2187, standstill, SG min/max 0/242, read errors 0, write errors 1, ifcnt 201, reads 10987, writes 18, timeouts 16, DMA errors 0, failedOp 0x01 Driver 2: position 9535, standstill, SG min/max 0/250, read errors 0, write errors 1, ifcnt 187, reads 10991, writes 20, timeouts 10, DMA errors 0, failedOp 0x06 Driver 3: position 0, ok, SG min/max 0/356, read errors 0, write errors 1, ifcnt 229, reads 10914, writes 21, timeouts 86, DMA errors 0, failedOp 0x71 Driver 4: position 0, ok, SG min/max 0/346, read errors 0, write errors 1, ifcnt 235, reads 10862, writes 21, timeouts 138, DMA errors 0, failedOp 0x6a Driver 5: position 0, ok, SG min/max 0/100, read errors 0, write errors 1, ifcnt 246, reads 10990, writes 23, timeouts 8, DMA errors 0, failedOp 0x01 Driver 6: position 0, ok, SG min/max 0/110, read errors 0, write errors 1, ifcnt 246, reads 8032, writes 23, timeouts 2966, DMA errors 0, failedOp 0x01 Date/time: 2021-03-17 02:38:03 Cache data hit count 4294967295 Slowest loop: 163.49ms; fastest: 0.08ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 50255ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 108660, completed moves 108660, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.0 Heater 2 is on, I-accum = 0.6 === GCodes === Segments left: 0 Movement lock held by Autopause HTTP* is idle in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X29.985001 Y-4.522000 E0.322590" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is ready with "M122 M913 X0 Y0" in state(s) 64 Code queue is empty. === Filament sensors === Extruder 0 sensor: ok Extruder 1 sensor: ok === CAN === Messages queued 116136, send timeouts 116133, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16 === SBC interface === State: 0, failed transfers: 0 Last transfer: 17ms ago RX/TX seq numbers: 50168/50169 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x10eec Buffer RX/TX: 1464/2104-0 Print auto-paused due to low voltage 2021-03-17 02:38:07 Warning: VIN under-voltage event (9.3V) 2021-03-17 02:38:11 Warning: VIN under-voltage event (7.1V) 2021-03-17 02:38:16 Warning: VIN under-voltage event (7.9V) 2021-03-17 02:38:20 Warning: VIN under-voltage event (3.8V) 2021-03-17 02:38:24 Warning: VIN under-voltage event (5.1V) 2021-03-17 02:38:29 Warning: VIN under-voltage event (5.1V) 2021-03-17 02:38:33 Warning: VIN under-voltage event (5.1V) 2021-03-17 02:38:38 Warning: VIN under-voltage event (5.1V) 2021-03-17 02:38:42 Warning: VIN under-voltage event (5.2V) 2021-03-17 02:38:46 Warning: VIN under-voltage event (5.2V) 2021-03-17 02:38:51 Warning: VIN under-voltage event (5.2V) 2021-03-17 02:38:55 Warning: VIN under-voltage event (5.2V) 2021-03-17 02:39:00 Warning: VIN under-voltage event (5.2V) 2021-03-17 02:39:04 Warning: VIN under-voltage event (5.2V) 2021-03-17 02:39:09 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:13 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:18 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:22 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:27 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:31 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:36 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:40 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:45 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:49 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:54 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:39:58 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:40:03 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:40:07 Warning: VIN under-voltage event (5.3V) 2021-03-17 02:40:12 Warning: VIN under-voltage event (5.4V) 2021-03-17 02:40:16 Warning: VIN under-voltage event (5.4V) 2021-03-17 03:01:26 Warning: VIN under-voltage event (0.0V) 2021-03-17 06:28:49 Warning: VIN under-voltage event (0.0V)
@Serbitar Thanks for the report.
In SBC mode you could try enabling more detailed logging.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
I also had one this evening why performing home all
3.3b2 sbc mini 5 -
@carcamerarig, thanks for the additional data point.
My best guess at this point is that the DMA for the SPI transfers between the Pi and the Duet is somehow interfering with the DMA used by the ADC. Do any of you experiencing this problem see short-lived temperature jumps too?
@dc42 by the time i'm back at the printer, usually several hours have past since it stopped so the temperature charts have gone past.
I have a few prints to complete in standalone mode and then i will enable the extra monitoring. Is there any way to save logs of the temp values too?
Until I have pinned down the exact cause, it might be worth trying a lower SPI frequency. The frequency is set in the DCS configuration file on the Pi.
PS - if anyone who has experienced this has their machine idle, please can you run some simulated prints, to see whether they can trigger this issue. The increased SPI traffic rate from the Pi during a simulation might make it happen more often. OTOH it could turn out that step interrupts also need to happen for this issue to occur.
@dc42 Happy to try, how would this manifest during a simulation, just console messages showing low voltage detected? In which case I will make sure I have 24Vin active during simulation.
@WILD9 said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
I expect the indications of the problem to be:
- A console report of an under-voltage event, with the reported VIN being 0.0
- If you run M122 afterwards then it will report that one or more under-voltage events occurred and the minimum recorded VIN will be 0.0. Note, a subsequent M122 will only report under-voltage events and the minimum VIN that happened since the previous M122.
You will need to have VIN power applied throughout.
@dc42 said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
I’ve been spending quite a few hours daily of stop start printing while I’m still tuning and configuring (mostly learning) and have only seen the one which was at a home all, the effect was a crash into the left x carriage carrier, I’m unsure if the error was before during or after the crash.
I’ll be doing more of the same later if you want me to test or log anything, I’ll need some instructions though if I’m to alter some code. -
@dc42 Is 4MHz low enough?
Is it worth running some heaters duing a simulation. To give the PSU some load.
During a print my VIN can jump up and down a few points of a volt. But during a sim . She is bang on 24.2v and dont move. -
6ish hours of simulation so far with no issues
