Duet3D PCB delta printer effector sneak preview
hi what's the price's estimation for the whole set (carriage, sensor if sold separately, and effector) ?
I hope to make an announcement regarding price and availability soon.
I have updated the assembly instructions at https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer to cover programming the sensitivity of the nozzle contact probe using the new M672 command, and to reflect changes between the prototype and production effector.
Will you be selling the arms and ball studs too or will these need to be sourced directly from Hayden?
I have a sneaky feeling you didnt actually read the whole thread, the quote below was taken from page ONE
cough
Any chance you or T3P3 will make custom length Haydn Huntley magnetic arms and sell it all as a kit with the PCB?
We will certainly explore collaborating with Haydn on purchasing his mag arms in larger volumes to bundle with the effectors, once we get closer to a production version. That makes sense for people in the UK/Europe at least (it makes less sense to import them from the US just to ship them back).
@CaLviNx:
cough
No, this answer says they would explore it, I'm now asking as they are almost ready to announce pricing/availability whether this will include an option on arms. If it doesn't then I can order from the US now so that I have them in good time for when the effector kits become available.
I have the utmost confidence in the fact that David, Tony & Roland will fully appraise us of the available combinations when they become available. no matter how infuriating it is (for me) to be waiting for the release.
Thi is being discussed right now, but Initially I think there will be these options:
1. PCB effector, carriage adapters and connector kit only. This is for customers who will not be using a E3Dv6 hot end.
2. As #1 plus custom heatsink to replace the standard E3Dv6 heatsink.
T3P3 (who do the order processing and shipping for Duet3D), Filastruder and some of our other distributors are also E3D resellers. So it's likely that they will provide an option to buy the rest of the E3Dv6 parts at the same time, probably with a choice of thermistor or PT100 temperature sensor.
As Tony said already, we are looking at stocking Haydn's magnetic rods for the benefit of customers in the UK and Europe. I don't know whether we will have them by the time we start shipping the effector.
Would it help if we pre-ordered or reserved these so a more accurate order count can be made?
Also, are there advantages to using a four-wire PT100 sensor or is that mostly for extremely fine tuned temperature ranges?
I hope we will have news on a possible pre-order for the effector soon. We don't need to have one for the numbers, we're having plenty made because we believe it will sell well. I should have the first production units to test at the end of this week.
The advantage of a 4-wire connection is that the resistance of the wires and connectors gets cancelled out so that it doesn't affect the reading. However, E3D doesn't make a 4-wire PT100 cartridge yet. So I have a 2-wire PT100 plugged into the effector, and 4 conductors in an an 8-core cable back to the Duet. The other 4 cores are used for the Z probe connections.
It will be nice to rule out bed tilt from the new probe with a fixed bed, the variable height readings at different probe locations is the only slight weakness of the FSR sensor arrangement (and it's only a .05mm variation in my experience, which can be effectively ignore for most things).
I need to create an OpenSCAD design for a belt attachment for the PCB carriage. What are the screws spacing for a standard linear rail / the PCB carriage? I can probably make a temporary design that people can use if they are waiting on an aluminum carriage tensioner to ship.
The fixing holes on the carriage adapter are four M3 size holes on a 20mm square.
Well unless it will be cost me an arm and two legs I will be ordering a few.
Sounds easy enough. If I create something useful, I'll post the design.
The hot end mounting hasn't changed. We managed to squeeze in 3 extra mounting holes in the production version, see https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Connectors_and_Wiring.
Might be worth giving the dimensions of the additional mounting Holes David.
Just so people can start working on mounting plates for different hotends.
Doug
DC42 - Just wondering if the wiring shown in the BOM for your Kossel design is still valid for the production version of the smart effector?
I have been looking at the Zesty Nimble remote direct drive extruder.
Would it be difficult getting this to work with the pcb effector?Any thoughts on making a dual hotend pcb effector?
It would be really nice to print supports with pva on extruder 2-Jannis
The Zesty Nimble already will work on this effector exactly what I have on my Beta test one.
Doug
Sorry for the poor image Quality but you get the Idea
Dumb question, there's a jumper to switch from 12 to 24v, is it just to select the VIN you've got right, it doesn't let you plug 12v fan on a 24 VIN ?
I Suspect and am sure David will confirm that it is to allow for the LED's to work of both a 12 and 24V system and that the Fans still need to be suitable for the Vin that you are using.
at least that's how I have mine set up.
Doug
It is absolutley the bees knees as well I am getting spot on results from my autocal on the delta of dev's of 6-7 microns and a pretty flat bed map as well.
Is there a spot to use a beard air system on the effector too not. It iced any holes for a pass through. I know Doug, myself, luckless and Brian to name a couple have this installed.
I'm jealous of Doug getting to try that lol I might go steal it lol
