Poor print quality with RRF3 - especially 3.2.2.
@deckingman said in Poor print quality with RRF3 - especially 3.2.2.:
@gloomyandy said in Poor print quality with RRF3 - especially 3.2.2.:
Hmm interesting but very frustrating.
I wonder if there is any correlation with bad prints and room temperature? It's been pretty cold here (in the UK) the last few days and I know my workshop space is much colder first thing and will get warmer as the day goes on. Does the temperature vary much where your printer is?
Ahh, now it's funny you should say that. The printer sits inside dust proof booth inside my garage. The garage is integral to the house, and is fitted with an insulated panel door (one of the best investments I ever made). there is also a small radiator connected to the house heating system and a freezer which helps to keep the place warm.
As it happens, as part of my ongoing home automation project (well I have to pass the time in lockdown somehow), I've made and fitted an ESP based garage door controller. As the ESP device had a few spare pins, I fitted a DHT22 sensor in the box as well, because why not?
So, I happen to have a record of the garage temperature (and humidity) over the last 24 hours. Now the sensor is up high, close to the garage door motor so it reads about 4 or 5 degrees higher than at "printer height".
But here is a snip from the ambient conditions tab of the Home Assistant dashboard on my PC.
The garage temperature and humidity are the purple lines. Min temp was 20.2, max was 26.7 but you can knock 4 or 5 degrees off that for the reasons given above. On the other hand, the printer sits inside a dust proof "booth" (about the size of double wardrobe) so the ambient inside there is little higher. Humidity is fairly constant (min 30, max 36).
So I can categorically say (and prove) that there were no wild excursions of ambient temperature or humidity.
I'll bet you didn't expect that sort of answer did you?
I'll also wager that some smart ar*s is going to say "what about barometric pressure"
What about cosmic ray radiation
I always find it hilarious when frequent forum members ask you to check some basic thing knowing well how crazy you are with your machine.
@deckingman I think your garage is warmer than my house most of the time!
Probably. That's what comes from many holidays on various Greek Islands and having a daughter who lives in Australia. One gets used to the heat. You should try my lounge when the wood burner has been going for an hour two!
I think that all of the bad prints you have had so far have been the "first print" for the day. Is that correct? Probably too small a sample set to draw conclusions but interesting.
That is actually true. Can't get my head around what that might be significant. I suspect it's purely coincidental. Of maybe the printer is like me - can't get going in the mornings until at least the third coffee......
@akstrfn said in Poor print quality with RRF3 - especially 3.2.2.:
Cmon now. He's wise and skillful, but not omnipotent. Even the best among us have been caught out by the simple things. Thorough troubleshooting shouldn't be taken as a slight.
@Phaedrux said in Poor print quality with RRF3 - especially 3.2.2.:
It is true that sometimes simple solutions hide in plain sight but he is debugging tricky firmware issue for a while so it is very unlikely that he didn't check obvious stuff. Additionally even after he debugs the temperature stuff he gets bunch of posts to debug temperature stuff. Reading some posts that he got over time I can understand why is he so frustrated.
@deckingman sometimes electronics works better when it heats up a bit, you know like good ol' machines
(this is btw not a joke)
Ahh, yes - I had thought about that. I forgot to mention that, taking Nasa's lead, I've lined the garage walls and ceiling with Hydrogenated boron nitride nanotubes. The basic principle being that the best way to stop an energetic particle is to run into something that is a similar size.
Do think I should line the floor as well?
Not sure how you missed the floor, space is after all flat.
This post is deleted! -
@JoergS5 I refer to my reply to another user above, timed at 17:41
honestly ,i think you're so obsessed with the firmware (even if its for obvious reasons) that you no longer check the basics .
there are so many things wrong with your "shyte" prints that no firmware bug can generate . -
@hackinistrator Easy now.
@hackinistrator said in Poor print quality with RRF3 - especially 3.2.2.:
there are so many things wrong with your "shyte" prints that no firmware bug can generate .I'm trying my best not to let the experiences of the last 19 months (which have been due to numerous firmware issues) cloud my judgement.
You will note that I haven't directly stated that I think the issues are due to firmware. I have been very careful in my choice of words, using terms like "this is coincidental with changing to firmware xyz". Other people in this thread have stated that it looks like firmware issues - not I. I've also been careful neither to agree nor disagree with such comments.
How do you explain the print to print variability when nothing changes between prints - not even the filament? It's fine saying there are lots of things wrong with the "shite" prints, but how do you explain that repeating the exact same print, with the exact same settings even down to using the same filament from the same reel, gives "acceptable" (not perfect) results?
It's impossible to assess the impact of any changes unless one can establish a reliable and repeatable baseline. Until I can get consistent print to print repeatability, I can never be sure that the results of any change I make would be due to that change or this mysterious "something else" (whatever something else might be).
One could argue that you are the one obsessed with it not being a firmware problem. But lets' not go down that road.
I remain open to any constructive suggestions.
It might be annoying but there has been situations for me, and more than once, where I overlooked the basics and was thankful to have been reminded of them.
firmware also didn't change between those prints .
i'm not saying the firmware is perfect . I'm just starting with duet3 and i can say that so far with all the various (minor) issues i had , the diagnostics (m122) was pretty much useless in my case .
i also didn't like the default homing files , which mark axis as homed even if i dont have a sensor attached to the board (no sensor = NO = HOMED...) . this could potentially cause damage as i'm using large high current motors .back to topic ,
your print has no layer shifts , so i guess the problem is extrusion related .if i were you , the first thing i would change is the filament . if you didn't print for 19 months , i guess that pla is more then 19 months old . pla degrades over time and its the easiest thing to change .that curling is good indication of degraded filament (if temps were ok).
next i would test extrusion / retraction (including firmware )
for example extrude 11mm and retract 1mm 10 times , measure if total is 100 . do this with various feed rates until you reach approx 1.5x your max printing feed rate.
if you think its something related to multi axis/ stepper movement then you can add movements during this test .your test print is pretty large , i would use something smaller for tests , even benchy would be better .
It can be setup either way - to stop the motors when homing is attempted or to allow them to run to the end of the axis.
You can of course use stall detection which doesn't rely on endstop sensors.
Yeah putting another unicorn printer in close proximity might get you into a heap of trouble with piles of little unicorn printers popping up everywhere - not a pretty sight!
(Couldn't help myself)
@deckingman, please try a print using 3.3beta1. After homing and before printing, run M122 on all 4 boards to clear the stats. Then start the print. If/when it's looking bad, pause the print, run M122 on all the boards again, and post the results here. What I am particularly looking for is whether you get send timeouts on the main board and/or nonzero 'oos' counts on any of the expansion boards.
@JoergS5 said in Poor print quality with RRF3 - especially 3.2.2.:
@hackinistrator I second that: I hesitated to propose to check something simple, because @deckingman is such an experienced user.
But if you look at the forum, there are often cases where, after a long search for complicated reasons, it was something simple like
- dirty pulley or damaged belt
- off-center pulley
- old filament, being too wet
- bent shaft of a stepper
- damaged nozzle
The easiest would be to have a clone printer and compare the results. Unfortunately it's not so easy with a unicorn printer! But somehow it's necessary to find a decision between hardware and firmware problem.
Oh, please. A dirty pulley which magically cleans itself? (And the printer is in a dustproof booth). An off centre pulley which magically makes itself centred. The filament is a brand new reel but it's hard to imagine some metres of that reel could be wet, yet for the next print, it will be dry. A bent stepper shaft which straightens itself for one print and bends again for the next? A damaged nozzle which undamaged itself for the next print then damages itself again?
